Текущее время: Сб окт 03, 2026 17:52
 Заголовок сообщения: DGS-3610-26G no buffer
СообщениеДобавлено: Вт июн 28, 2011 10:07
на DGS-3610-26G в статистике интерфейсов (GE, 10GE) растут счетчики "no buffer"
трафик небольшой, flow-control включен
в мануале ничего не нашел по этому поводу
помогите понять причину и как это устранить?
#sh ver
System description      : DGS-3610-26G Gigabit Ethernet Switch
System start time       : 2011-04-22 3:0:40
System uptime           : 66:22:59:34
System hardware version : A1.03
System software version : v10.3(4b3), Release(65758)
System BOOT version     : 10.3.65758
System CTRL version     : 10.3.65758
Device information:
  Device-1
    Hardware version : A1.03
    Software version : v10.3(4b3), Release(65758)
d3610-pr35#sh int g0/1
Index(dec):1 (hex):1
GigabitEthernet 0/1 is UP  , line protocol is UP
Hardware is Broadcom 5464 GigabitEthernet
Interface address is: no ip address
  MTU 1500 bytes, BW 1000000 Kbit
  Encapsulation protocol is Bridge, loopback not set
  Keepalive interval is 10 sec , set
  Carrier delay is 2 sec
  RXload is 3 ,Txload is 16
  Queueing strategy: FIFO
    Output queue 0/40, 0 drops;
    Input queue 0/75, 0 drops
  Switchport attributes:
    interface's description:""
    medium-type is fiber
    lastchange time:36 Day: 5 Hour:12 Minute:10 Second
    Priority is 0
    admin duplex mode is AUTO, oper duplex is Full
    admin speed is AUTO, oper speed is 1000M
    flow control admin status is ON,flow control oper status is ON
    broadcast Storm Control is OFF,multicast Storm Control is OFF,unicast Storm
Control is OFF
  5 minutes input rate 12547141 bits/sec, 3706 packets/sec
  5 minutes output rate 66627413 bits/sec, 7608 packets/sec
    16208220 packets input, 8409766968 bytes, 6213 no buffer, 0 dropped
    Received 3479 broadcasts, 0 runts, 0 giants
    0 input errors, 0 CRC, 0 frame, 0 overrun, 0 abort
    34228823 packets output, 35237383261 bytes, 0 underruns , 0 dropped
    0 output errors, 0 collisions, 0 interface resets
 Заголовок сообщения: Re: DGS-3610-26G no buffer
СообщениеДобавлено: Вт июн 28, 2011 11:42
Для начала обновите прошивку
ftp://ftp.dlink.ru/pub/Switch/DGS-3610%20Series/Firmware/dgs3610_DI_94612_install.bin
sh run int g0/1
sh int g0/1 count
СообщениеДобавлено: Ср июн 29, 2011 11:01
обновил прошивку - счетчики "no buffer" перестали расти
спасибо!
interface GigabitEthernet 0/1
 switchport mode trunk
 flowcontrol on
 mls qos trust cos none-modify
#sh int g0/1 count
Interface : GigabitEthernet 0/1
5 minutes input rate  :111406095 bits/sec, 15377 packets/sec
5 minutes output rate :99331210 bits/sec, 16646 packets/sec
InOctets             : 159402731614
InUcastPkts          : 173818945
InMulticastPkts      : 1488419
InBroadcastPkts      : 27291
OutOctets            : 164766715953
OutUcastPkts         : 155129515
OutMulticastPkts     : 49585108
OutBroadcastPkts     : 8970053
Undersize packets    : 0
Oversize packets     : 0
collisions           : 0
Fragments            : 0
Jabbers              : 0
CRC alignment errors : 0
AlignmentErrors      : 0
FCSErrors            : 0
dropped packet events (due to lack of resources): 0
packets received of length (in octets):
  64 : 5566834
  65-127 : 101885647
  128-255 : 28052120
  256-511 : 6435013
  512-1023 : 69260495
  1024-1518 : 89608604
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 129
