Текущее время: Чт сен 24, 2026 09:40
СообщениеДобавлено: Вт июн 07, 2011 10:32
Доброго времени суток. Сегодня случилась проблема перестал работать дом настроенный через GVRP. Схема - 3610 - 3627G в стеке. Неделю все работало прекрасно сегодняслучилась петля. 3610 с 3627 скомутированы через LACP.
Вот параметры GVRP 3610
gvrp enable
gvrp dynamic-vlan-creation enable
gvrp timer join 100
gvrp timer leave 300
gvrp timer leaveall 400
Вот LACP
interface GigabitEthernet 0/21
 lacp port-priority 1
 port-group 1 mode active
interface GigabitEthernet 0/22
interface GigabitEthernet 0/23
interface GigabitEthernet 0/24
interface AggregatePort 1
 switchport mode trunk
Вот вывод sh gvrp configuration
    DGS-3610#sh gvrp configuration
    Global GVRP Configuration:
    GVRP Feature:enabled
    GVRP dynamic VLAN creation:enabled
    Join Timers(ms):100
    Leave Timers(ms):300
    Leaveall Timers(ms):400
    Port based GVRP Configuration:
    PORT Applicant Status Registration Mode
    GigabitEthernet 0/1 normal normal
    GigabitEthernet 0/2 normal normal
    GigabitEthernet 0/3 normal normal
    GigabitEthernet 0/4 normal normal
    GigabitEthernet 0/5 normal normal
    GigabitEthernet 0/6 normal normal
    GigabitEthernet 0/7 normal normal
    GigabitEthernet 0/8 normal normal
    GigabitEthernet 0/9 normal normal
    GigabitEthernet 0/10 normal normal
    GigabitEthernet 0/11 normal normal
    GigabitEthernet 0/12 normal normal
    GigabitEthernet 0/13 normal normal
    GigabitEthernet 0/14 normal normal
    GigabitEthernet 0/15 normal normal
    GigabitEthernet 0/16 normal normal
    GigabitEthernet 0/17 normal normal
    GigabitEthernet 0/18 normal normal
    GigabitEthernet 0/19 normal normal
    GigabitEthernet 0/20 normal normal
    GigabitEthernet 0/21 normal normal
    GigabitEthernet 0/22 normal normal
    GigabitEthernet 0/23 normal normal
    GigabitEthernet 0/24 normal normal
    AggregatePort 1 normal normal
На 3627G
# VLAN
enable pvid auto_assign
config vlan default delete 1:1-1:25,2:1-2:25,3:1-3:25,4:1-4:48
config vlan default add tagged 1:21-1:24
config vlan default add untagged 1:1-1:17,1:19-1:20,1:25,2:1-2:25,3:1-3:25,4:1-4:48
config vlan default advertisement enable
create vlan Office tag 2
config vlan Office add tagged 1:21-1:24,4:18 advertisement enable
disable qinq
enable gvrp
disable vlan_trunk
config vlan_trunk ports 1:21-1:24 state enable
config gvrp 1:1-1:25 state enable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 2:1-2:25 state enable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 3:1-3:25 state enable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 4:1-4:48 state enable ingress_checking disable acceptable_frame admit_all pvid 1
Вот вывод sh vlan пропала куча остальных вланов...
    DGS-3627G:admin#sh vlan
    Command: show vlan
    VLAN Trunk State : Disabled
    VLAN Trunk Member Ports : 1:21-1:24
    VID : 1 VLAN Name : default
    VLAN Type : Static Advertisement : Enabled
    Member Ports : 1:1-1:17,1:19-1:25,2:1-2:25,3:1-3:25,4:1-4:48
    Static Ports : 1:1-1:17,1:19-1:25,2:1-2:25,3:1-3:25,4:1-4:48
    Current Tagged Ports : 1:21-1:24
    Current Untagged Ports: 1:1-1:17,1:19-1:20,1:25,2:1-2:25,3:1-3:25,4:1-4:48
    Static Tagged Ports : 1:21-1:24
    Static Untagged Ports : 1:1-1:17,1:19-1:20,1:25,2:1-2:25,3:1-3:25,4:1-4:48
    Forbidden Ports :
    VID : 2 VLAN Name : Office
    Member Ports : 1:21-1:24,4:18
    Static Ports : 1:21-1:24,4:18
    Current Tagged Ports : 1:21-1:24,4:18
    Static Tagged Ports : 1:21-1:24,4:18
    Forbidden Ports :
    VID : 305 VLAN Name :
    VLAN Type : Dynamic Advertisement : Enabled
    Member Ports : 2:7-2:12
    Static Ports :
    Current Tagged Ports : 2:7-2:12
    Forbidden Ports :
    Total Entries: 3
Вот лог с 3627G
    1277 2011-06-07 10:11:06 INFO(6) Port 1:24 LBD port recovered. Loop detection r
    estarted
    1276 2011-06-07 10:11:06 INFO(6) Port 1:23 LBD port recovered. Loop detection r
    estarted
    1275 2011-06-07 10:11:06 INFO(6) Port 1:22 LBD port recovered. Loop detection r
    estarted
    1274 2011-06-07 10:11:06 INFO(6) Port 1:21 LBD port recovered. Loop detection r
    estarted
    1273 2011-06-07 10:10:07 INFO(6) Port 1:24 link down
    1272 2011-06-07 10:10:07 INFO(6) Port 1:23 link down
    1271 2011-06-07 10:10:07 INFO(6) Port 1:22 link down
    1270 2011-06-07 10:10:07 INFO(6) Port 1:21 link down
    1269 2011-06-07 10:10:07 CRIT(2) Port 1:24 LBD loop occurred. Port blocked
    1268 2011-06-07 10:10:07 CRIT(2) Port 1:23 LBD loop occurred. Port blocked
    1267 2011-06-07 10:10:07 CRIT(2) Port 1:22 LBD loop occurred. Port blocked
    1266 2011-06-07 10:10:07 CRIT(2) Port 1:21 LBD loop occurred. Port blocked
Вот LACP
DGS-3627G:admin#show link_aggregation
Command: show link_aggregation
Link Aggregation Algorithm = IP-Source
Group ID      : 1
Type          : LACP
Master Port   : 1:23
Member Port   : 1:21-1:24
Active Port   : 1:21-1:24
Status        : Enabled
Flooding Port : 1:21
Ребутать стек? Конфиг не менялся нигде.. Посоветуйте пожалуйста.
СообщениеДобавлено: Вт июн 07, 2011 11:36
Полечил просто глобально выключил и включил GVRP. Какие параметры значения оптимальны для 3610 gvrp timer join gvrp timer leave gvrp timer leaveall ?
