Текущее время: Пт окт 02, 2026 12:43
 Заголовок сообщения: DES3526,Configuration had 9 syntax error and 4 execute error
СообщениеДобавлено: Ср апр 27, 2011 08:22
Здравствуйте, проблема с DES-3526
Boot PROM Version 5.00.011
Firmware Version 6.00.B36
Hardware Version A4
Serial Number DR2M4A8000458
при холодном старте в логе:
И не включается dhcp_relay, после теплой перезагрузки, все начинает работать.
вот конфиг
#                       DES-3526 Configuration
#                       Firmware: Build 6.00.B36
#        Copyright(C) 2008 D-Link Corporation. All rights reserved.
# BASIC
config serial_port baud_rate 9600 auto_logout 10_minutes
enable telnet 23
enable web 80
config terminal_line default
enable clipaging
debug error_log auto_reboot enabled
# ACCOUNT LIST
create account admin hrust encrypt sha_1 *
create account admin oleg encrypt sha_1 *
# PASSWORD ENCRYPTION
enable password encryption
# BNR
config command_prompt default
# STORM
config traffic control_trap both
config traffic control 1-4 broadcast disable multicast enable unicast disable action drop threshold 60
config traffic control 5 broadcast disable multicast disable unicast disable action drop threshold 128000
# LOOP_DETECT
enable loopdetect
config loopdetect recover_timer 60
config loopdetect interval 10
config loopdetect mode port-based
config loopdetect ports 1-24 state enabled
config loopdetect ports 25-26 state disabled
# GM
config sim candidate
disable sim
config sim dp_interval 30
config sim hold_time 100
# SYSLOG
disable syslog
config system_severity trap information
config system_severity log information
# QOS
config scheduling 0 max_packet 0 max_latency 0
config scheduling 1 max_packet 0 max_latency 0
config scheduling 2 max_packet 0 max_latency 0
config scheduling 3 max_packet 0 max_latency 0
config 802.1p user_priority 0  1
config 802.1p user_priority 1  0
config 802.1p user_priority 2  0
config 802.1p user_priority 3  1
config 802.1p user_priority 4  2
config 802.1p user_priority 5  2
config 802.1p user_priority 6  3
config 802.1p user_priority 7  3
config 802.1p default_priority 1-26 0
config bandwidth_control 1-26 rx_rate no_limit tx_rate no_limit
# MIRROR
disable mirror
# TRAF-SEGMENTATION
config traffic_segmentation 1-26 forward_list 1-26
# PORT
config ports 1 speed auto flow_control disable mdix auto learning enable state enable description "" trap enable
config ports 2 speed auto flow_control disable mdix auto learning enable state enable description "" trap enable
config ports 3 speed auto flow_control disable mdix auto learning enable state enable description "" trap enable
config ports 4 speed auto flow_control disable mdix auto learning enable state enable description "" trap enable
config ports 5 speed auto flow_control disable mdix auto learning enable state enable description "" trap enable
config ports 6 speed auto flow_control disable mdix auto learning enable state enable description "" trap enable
config ports 7 speed auto flow_control disable mdix auto learning enable state enable description "" trap enable
config ports 8-24 speed auto flow_control disable mdix auto learning enable state enable trap enable
config ports 25-26 medium_type copper speed auto flow_control disable mdix auto learning enable state enable trap enable
config ports 25-26 medium_type fiber speed auto flow_control disable learning enable state enable trap enable
# PORT_LOCK
disable port_security trap_log
config port_security ports 1-26 admin_state disable max_learning_addr 1 lock_address_mode DeleteOnReset
# 8021X
disable 802.1x
config 802.1x auth_protocol radius_eap
config 802.1x capability ports 1-26 none
config 802.1x auth_parameter ports 1-26 direction both port_control auto quiet_period 60 tx_period 30 supp_timeout 30 server_timeout 30 max_req 2 reauth_period 3600 enable_reauth disable
# SNMPv3
delete snmp community public
delete snmp community private
delete snmp user initial
delete snmp group initial
delete snmp view restricted all
delete snmp view CommunityView all
config snmp engineID 800000ab031cbdb9e5f55e
create snmp view restricted 1.3.6.1.2.1.1 view_type included
create snmp view restricted 1.3.6.1.2.1.11 view_type included
create snmp view restricted 1.3.6.1.6.3.10.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.11.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.15.1.1 view_type included
create snmp view CommunityView 1 view_type included
create snmp view CommunityView 1.3.6.1.6.3 view_type excluded
create snmp view CommunityView 1.3.6.1.6.3.1 view_type included
create snmp group public v1 read_view CommunityView notify_view CommunityView
create snmp group public v2c read_view CommunityView notify_view CommunityView
create snmp group initial v3  noauth_nopriv read_view restricted notify_view restricted
create snmp group private v1 read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group private v2c read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group ReadGroup v1 read_view CommunityView notify_view CommunityView
create snmp group ReadGroup v2c read_view CommunityView notify_view CommunityView
create snmp group WriteGroup v1 read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group WriteGroup v2c read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group gjitkyfabupublic v1 read_view CommunityView notify_view CommunityView
create snmp group gjitkyfabupublic v2c read_view CommunityView notify_view CommunityView
create snmp community * view CommunityView read_only
create snmp user initial initial
# MANAGEMENT
enable snmp traps
enable snmp authenticate traps
config snmp system_name test
config snmp system_location test
config snmp system_contact x
disable rmon
# VLAN
disable asymmetric_vlan
config vlan default delete 1-26
config vlan default add forbidden 1-26
config vlan default advertisement disable
create vlan mg tag 10
config vlan mg add tagged 25-26
config vlan mg add forbidden 1-24
config vlan mg advertisement disable
create vlan xx tag 200
config vlan xx add tagged 25-26
config vlan xx add untagged 1-24
config vlan xx advertisement disable
disable gvrp
config gvrp 1-24 state disable ingress_checking enable acceptable_frame admit_all pvid 200
config gvrp 25-26 state disable ingress_checking enable acceptable_frame admit_all pvid 1
# FDB
config fdb aging_time 300
config multicast port_filtering_mode 1-24 filter_unregistered_groups
config multicast port_filtering_mode 25-26 forward_unregistered_groups
# MAC_ADDRESS_TABLE_NOTIFICATION
config mac_notification interval 1 historysize 1
disable mac_notification
config mac_notification ports 1-26 disable
# STP
config stp version rstp
config stp maxage 20 maxhops 20 forwarddelay 15 txholdcount 6 fbpdu enable
config stp priority 32768 instance_id 0
config stp hellotime 2
config stp mst_config_id name 1C:BD:B9:E5:F5:5E revision_level 0
disable stp
config stp ports 1-26 externalCost auto edge false p2p auto state enable
config stp ports 1-26 fbpdu disable
config stp ports 1-26 restricted_role false
config stp ports 1-26 restricted_tcn false
config stp mst_ports 1-26 instance_id 0 internalCost auto priority 128
# SSH
config ssh server maxsession 8
config ssh server contimeout 300
config ssh server authfail 2
config ssh server rekey never
config ssh server port 22
disable ssh
# SSL
disable ssl
enable ssl ciphersuite RSA_with_RC4_128_MD5
enable ssl ciphersuite RSA_with_3DES_EDE_CBC_SHA
enable ssl ciphersuite DHE_DSS_with_3DES_EDE_CBC_SHA
enable ssl ciphersuite RSA_EXPORT_with_RC4_40_MD5
config ssl cachetimeout timeout 600
# SAFE_GUARD
config safeguard_engine state disable cpu_utilization rising_threshold 100 falling_threshold 20 trap_log disable
# TIMERANGE
# security_ACL
config address_binding ip_mac ports 1-24 state enable
config filter dhcp_server ports 1-24 state enable
config filter extensive_netbios 1-24 state enable
config filter netbios 1-24 state enable
enable dhcp_local_relay
enable address_binding dhcp_snoop
disable address_binding acl_mode
config pppoe circuit_id_insertion state disable
# ACL
disable cpu_interface_filtering
# SNTP
enable sntp
config time_zone operator + hour 8 min 0
config sntp primary 195.2.64.5 secondary 192.5.41.40 poll-interval 720
config dst disable
# IPBIND
config address_binding ip_mac ports 1-24 allow_zeroip enable
enable address_binding trap_log
config address_binding dhcp_snoop max_entry ports 1-24 limit 1
config address_binding dhcp_snoop max_entry ports 25-26 limit 5
config address_binding ip_mac ports 1-24 stop_learning_threshlod 1
# FILTER
# PPPoE_Circuit_ID_Insertion
config pppoe circuit_id_insertion ports 1-26 state enable circuit_id ip
# ROUTE
create iproute default 192.168.3.1 1
# SNOOP
disable igmp_snooping
config igmp_snooping vlan_name default host_timeout 260 router_timeout 260 leave_timer 2 state disable
config igmp_snooping querier vlan_name default query_interval 125 max_response_time 10 robustness_variable 2
config igmp_snooping querier vlan_name default last_member_query_interval 1 state disable
config igmp_snooping vlan_name mg host_timeout 260 router_timeout 260 leave_timer 2 state disable
config igmp_snooping querier vlan_name mg query_interval 125 max_response_time 10 robustness_variable 2
config igmp_snooping querier vlan_name mg last_member_query_interval 1 state disable
config igmp_snooping vlan_name filimonovo host_timeout 260 router_timeout 260 leave_timer 2 state disable
config igmp_snooping querier vlan_name filimonovo query_interval 125 max_response_time 10 robustness_variable 2
config igmp_snooping querier vlan_name filimonovo last_member_query_interval 1 state disable
config limited_multicast_addr ports 1-26 access deny state disable
# LACP
config link_aggregation algorithm mac_source
config lacp_port 1-26 mode passive
# GVLAN
# IP
config ipif System vlan mg ipaddress 192.168.3.45/24 state enable
disable autoconfig
config autoconfig timeout 50
config ipif System dhcp_option12 state disable
# ARP
config arp_aging time 20
config gratuitous_arp send ipif_status_up enable
config gratuitous_arp send dup_ip_detected enable
config gratuitous_arp learning enable
# LLDP
disable lldp
config lldp message_tx_interval 30
config lldp tx_delay 2
config lldp message_tx_hold_multiplier 4
config lldp reinit_delay 2
config lldp notification_interval 5
config lldp ports 1-26 notification disable
config lldp ports 1-26 admin_status tx_and_rx
# ACCESS_AUTHENTICATION_CONTROL
config authen_login default method local
config authen_enable default method local_enable
config authen application console login default
config authen application console enable default
config authen application telnet login default
config authen application telnet enable default
config authen application ssh login default
config authen application ssh enable default
config authen application http login default
config authen application http enable default
config authen parameter response_timeout 0
config authen parameter attempt 3
config authen enable_admin all state enable
disable authen_policy
# DHCP_RELAY
enable dhcp_relay
config dhcp_relay hops 4 time 0
config dhcp_relay option_82 state enable
config dhcp_relay option_82 check disable
config dhcp_relay option_82 policy keep
config dhcp_relay option_82 remote_id user_define "192.168.3.45"
config dhcp_relay option_60 state disable
config dhcp_relay option_60 default mode drop
config dhcp_relay option_61 state disable
config dhcp_relay option_61 default drop
config dhcp_relay add ipif System 192.168.3.1
# DHCP_LOCAL_RELAY
config dhcp_local_relay vlan vlanid 200 state enable
config dhcp_local_relay option_82 ports 1-26 policy replace
#             End of configuration file for DES-3526
Где у него прячутся эти "error"?
 Заголовок сообщения: Re: DES3526,Configuration had 9 syntax error and 4 execute e
СообщениеДобавлено: Ср апр 27, 2011 10:52
Для начала запросите последнюю прошивку в теме обновите и пробуйте. Если не поможет сбросьте на заводские умолчания конфиг и отконфигурируйте заново - должно помочь.
СообщениеДобавлено: Ср апр 27, 2011 13:01
Не хотелось бы пробовать, хочется знать в каких строчках ошибки и в чем, проверять построчно - можно, но долго.
СообщениеДобавлено: Ср апр 27, 2011 15:39
Пробуя построчно, нашел что строки с config igmp_snooping не выполняются, убрал их в конфиге, залил его на коммутатор, сохранил, перезагрузил, а они опять там.
СообщениеДобавлено: Ср апр 27, 2011 16:05
В первую очередь нужно обновить прошивку до актуальной, так как похожая проблема уже решалась. Запросить ее можно в специально для этого созданной теме: http://forum.dlink.ru/viewtopic.php?f=2&t=92700
СообщениеДобавлено: Ср апр 27, 2011 16:34
Этот вариант я знаю, похоже именно его и придется делать. Полностью сброшенный свитч по-прежнему ловит ошибки в конфиге.
