Текущее время: Пт окт 02, 2026 17:12
 Заголовок сообщения: DGS-3610 out of memory
СообщениеДобавлено: Вт фев 15, 2011 18:58
Раз в 2-3 месяца девайс выпадает из ospf. Заходим по ssh и:
DGS-3610>show logging
Syslog logging: enabled
  Console logging: level debugging, 554 messages logged
  Monitor logging: level debugging, 0 messages logged
  Buffer logging: level debugging, 555 messages logged
  Standard format: flase
  Timestamp debug messages: datetime
  Timestamp log messages: datetime
  Sequence-number log messages: disable
  Sysname log messages: disable
  Count log messages: disable
  Trap logging: level informational, 555 message lines logged,0 fail
Log Buffer (Total 4096 Bytes): have written 4096, Overwritten 2155
*Feb 15 13:06:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface VLAN 65, changed state to down.
*Feb 15 13:06:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface VLAN 100, changed state to down.
*Feb 15 13:06:46: %LINEPROTO-5-UPDOWN: Line protocol on Interface VLAN 359, changed state to down.
*Feb 15 13:06:47: %LINK-3-UPDOWN: Interface GigabitEthernet 0/2, changed state to down.
*Feb 15 13:06:47: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet 0/2, changed state to down.
*Feb 15 13:07:09: %LINEPROTO-5-UPDOWN: Line protocol on Interface VLAN 65, changed state to up.
*Feb 15 13:07:09: %LINEPROTO-5-UPDOWN: Line protocol on Interface VLAN 100, changed state to up.
*Feb 15 13:07:09: %LINEPROTO-5-UPDOWN: Line protocol on Interface VLAN 359, changed state to up.
*Feb 15 13:07:10: %LINK-3-UPDOWN: Interface GigabitEthernet 0/2, changed state to up.
*Feb 15 13:07:10: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet 0/2, changed state to up.
*Feb 15 14:06:55: %ARPGUARD-4-DOS_DETECTED: ARP DoS attack was detected.
*Feb 15 14:53:38: %ARPGUARD-4-DOS_DETECTED: ARP DoS attack was detected.
*Feb 15 17:25:17: %SYS-2-MEMORY: Lower-memory debug exception (lower=756 free=755)
*Feb 15 17:25:17: %OSPF-2-MEM_WARNING_START: OSPF down due to insufficient memory and will be restarting in 120s.
*Feb 15 17:25:17: %OSPF-5-ADJCHG: Process 1, Nbr xx.xx.0.2-VLAN 66 from Full to Down, KillNbr.
*Feb 15 17:25:17: %OSPF-5-ADJCHG: Process 1, Nbr xx.xx.0.11-VLAN 66 from Full to Down, KillNbr.
*Feb 15 17:25:17: %OSPF-5-ADJCHG: Process 1, Nbr xx.xx.0.30-VLAN 66 from Full to Down, KillNbr.
*Feb 15 17:25:17: %OSPF-5-ADJCHG: Process 1, Nbr xx.xx.0.31-VLAN 66 from Full to Down, KillNbr.
*Feb 15 17:25:17: %OSPF-5-ADJCHG: Process 1, Nbr xx.xx.0.33-VLAN 66 from Full to Down, KillNbr.
*Feb 15 17:25:17: %OSPF-5-ADJCHG: Process 1, Nbr xx.xx.0.34-VLAN 66 from Full to Down, KillNbr.
*Feb 15 17:27:17: %OSPF-4-MEM_WARNING_END: OSPF is restarting.
*Feb 15 17:27:17: %OSPF-5-ADJCHG: Process 1, Nbr xx.xx.0.31-VLAN 66 from Down to Init, HelloReceived.
*Feb 15 17:27:17: %OSPF-5-ADJCHG: Process 1, Nbr xx.xx.0.30-VLAN 66 from Down to Init, HelloReceived.
*Feb 15 17:27:17: %OSPF-5-ADJCHG: Process 1, Nbr xx.xx.0.2-VLAN 66 from Down to Init, HelloReceived.
*Feb 15 17:27:21: %OSPF-5-ADJCHG: Process 1, Nbr xx.xx.0.11-VLAN 66 from Down to Init, HelloReceived.
*Feb 15 17:27:25: %OSPF-5-ADJCHG: Process 1, Nbr xx.xx.0.34-VLAN 66 from Down to Init, HelloReceived.
*Feb 15 17:27:25: %OSPF-5-ADJCHG: Process 1, Nbr xx.xx.0.33-VLAN 66 from Down to Init, HelloReceived.
*Feb 15 17:27:25: %OSPF-2-OVERFLOW: OSPFv2[1] entered an exceptional overflow status.
*Feb 15 17:28:38: %AAA-5-USER_UNLOCKED: User root unlocked by .
*Feb 15 17:31:09: %AAA-5-USER_UNLOCKED: User root unlocked by .
DGS-3610>enable
not enough memory! cli excute fail!
DGS-3610>logout
DGS-3610>exit
DGS-3610>lol
DGS-3610>
Ребут по питанию решает
System description      : DGS-3610-26G Gigabit Ethernet Switch
System start time       : 2011-02-15 17:37:30
System uptime           : 0:0:16:12
System hardware version : A1.0
System software version : v10.3(5T16), Release(92751)
System BOOT version     : 10.3.92751
System CTRL version     : 10.3.92751
Device information:
  Device-1
    Hardware version : A1.0
    Software version : v10.3(5T16), Release(92751)
Что посоветуете?
 Заголовок сообщения: Re: DGS-3610 out of memory
СообщениеДобавлено: Ср фев 16, 2011 10:51
А еще иногда его дичайше колбасит, вот например:
DGS-3610#
DGS-3610#sh vlan id 4DGS-3610#
DGS-3610#
DGS-3610#sh vl 436
DGS-3610#
DGS-3610#
DGS-3610#
это попытки выполнить sh vlan id 436 по ssh
СообщениеДобавлено: Ср фев 16, 2011 11:00
DGS-3610#
DGS-3610#showan id 436
VLAN Name                             Status    Ports
DGS-3610#
DGS-3610#how vlan id 436
DGS-3610#DGS-3610#
DGS-3610#
 Заголовок сообщения: Re: DGS-3610 outмый of memory
СообщениеДобавлено: Ср фев 16, 2011 11:04
Уважаемый redxin
Большая просьба воздержаться на форуме от вставки различного рода картинок с не относящимся к делу содержанием.
Тут не увесилительный портал "фишки", т.к. прецедент не первый, сообщения будут просто удаляться целиком.
По-делу:
можно дать несколько пояснений?
Вижу что есть как минимум 6 ospf соседей судя по адресам из одной area предположительно 0.
Что это за соседи (все "ваши" или есть "чужие"- другой оператор)? Их 6 или больше? Какое количество префиксов приходит от всех соседей на 3610?
Что еще из ресурсоемких процессов работает на 3610 кроме ospf?
Можно увидеть конфигурацию целиком?
sh memory protocols
sh cpu type ospf-v2
sh cpu type all
Прошивка есть более новая в ПМ.
СообщениеДобавлено: Ср фев 16, 2011 12:04
Maxim Klyus писал(а):
По-делу:
area 10.0.0.0
префиксов 377 +-
соседи все свои, и среди них есть гораздо более скромные устройства, например DES-3828 с аптаймом 9 месяцев.
sh memory protocols
sh cpu type ospf-v2
sh cpu type all
Маршрутизирует только ipv4, также запущен dhcp-relay. Есть один aggregate-port из двух портов.
Показать пока ничего не могу, т к сейчас по ssh с ним ничего сделать невозможно, а другого доступа пока нет.
СообщениеДобавлено: Ср фев 16, 2011 12:24
на самом деле, то что вы описываете, похоже на проблему утечки памяти...
но утечка памяти возможна по самым разным причинам...
если принять за определение, что в данном случае утечка непосредственно из-за процесса ospf,
то можно попробовать сделать следующее, чтобы свитч не "вырубало" целиком.
глобально
DGS-3610(config)#memory-lack exit-policy ospf
в процессе osfp
DGS-3610(config-router)#overflow memory-lack
и еще задать ограничения на апдейты, тоже в процессе ospf
DGS-3610(config-router)#overflow database ?
<1-4294967294> Maximum number of LSAs
external External link states
Обновление ПО тоже, надеюсь, сыграет свою роль.
СообщениеДобавлено: Ср фев 16, 2011 13:23
Кстати, есть подозрение что проблема в ssh. После установки access-class на вход, стало возможно нормально работать по ssh.
Похоже что все падало от злостного брутфорса ссхи. Возможно это будет интересно разработчикам)
Если бы не *Feb 16 12:10:02: %AAA-5-USER_UNLOCKED: User root unlocked by . То и не подумал бы.
СообщениеДобавлено: Ср фев 16, 2011 14:37
Желания закрыть технологическую сеть управления совсем для посторонних у вас нет, чтобы таких проблем не возникало?
Оборудование сделано не для того чтобы обслуживать DoS атаки его задача в другом заключется.
СообщениеДобавлено: Ср фев 16, 2011 19:55
Да, я ждал этого ответа.
Конечно оборудование должно падать от брутфорса. Memleak и race condition в реализации SSH это нормально.
СообщениеДобавлено: Чт фев 17, 2011 10:20
Видимо всяческие firewall, IDS, SBC и т.д. придумали просто так и только всякие "недалекие" операторы их покупают, т.к. и без них жить можно...
А сети управления защищать это вообще дурной тон...
В дальнейшем диалоге смысла не вижу.
Сейчас этот форум просматривают: Google [Bot] и гости: 21
