Текущее время: Вс окт 04, 2026 06:42
СообщениеДобавлено: Вс дек 12, 2010 16:07
Всем доброго дня, коллеги.
Подскажите пожалуйста, что за косяк у меня в настройке STP. На коммутаторах видна такая ерунда:
DES-3028G:4#show stp instance  0
Command: show stp instance 0
 STP Instance Settings
 Instance Type          : CIST
 Instance Status        : Enabled
 Instance Priority      : 32768(Bridge Priority : 32768, sys ID ext : 0 )
 STP Instance Operational Status
 Designated Root Bridge : 8193 /00-04-DE-18-B4-00
 External Root Cost     : 20000
 Regional Root Bridge   : 32768/00-22-B0-67-4B-E9
 Internal Root Cost     : 0
 Designated Bridge      : 8193 /00-04-DE-18-B4-00
 Root Port              : 25
 Max Age                : 20
 Forward Delay          : 15
 Last Topology Change   : 452
 Topology Changes Count : 3978
DES-3028G:4#sh log
8380  2010-12-12 11:05:15 Topology changed (Instance:0 port:25)
8379  2010-12-12 11:03:59 Topology changed (Instance:0 port:25)
8378  2010-12-12 10:59:23 Topology changed (Instance:0 port:25)
8375  2010-12-12 10:49:54 Topology changed (Instance:0 port:25)
8374  2010-12-12 10:48:54 Topology changed (Instance:0 port:25)
8373  2010-12-12 10:48:12 Topology changed (Instance:0 port:25)
8372  2010-12-12 10:47:31 Topology changed (Instance:0 port:25)
8371  2010-12-12 10:46:53 Topology changed (Instance:0 port:25)
8370  2010-12-12 10:46:17 Topology changed (Instance:0 port:25)
8369  2010-12-12 10:45:37 Topology changed (Instance:0 port:25)
8367  2010-12-12 10:42:49 Topology changed (Instance:0 port:25)
8366  2010-12-12 10:41:31 Topology changed (Instance:0 port:25)
8365  2010-12-12 10:38:11 Topology changed (Instance:0 port:25)
8364  2010-12-12 10:27:02 Topology changed (Instance:0 port:25)
8363  2010-12-12 10:25:28 Topology changed (Instance:0 port:25)
8362  2010-12-12 10:23:54 Topology changed (Instance:0 port:25)
8361  2010-12-12 10:14:30 Topology changed (Instance:0 port:25)
8360  2010-12-12 10:10:28 Topology changed (Instance:0 port:25)
Коммутаторы в кольце серии DES-3028 и DES-3200 с такими настройками STP (транковые порты 25-28):
enable stp
config stp version stp
config stp maxage 20 maxhops 20 forwarddelay 15 txholdcount 6 fbpdu disable hellotime 2 lbd enable lbd_recover_timer 60
config stp priority 32768 instance_id 0
config stp ports 1 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 1 instance_id 0 internalCost auto priority 128
config stp ports 1 fbpdu enable
config stp ports 1 restricted_role false
config stp ports 1 restricted_tcn false
config stp ports 2 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 2 instance_id 0 internalCost auto priority 128
config stp ports 2 fbpdu enable
config stp ports 2 restricted_role false
config stp ports 2 restricted_tcn false
config stp ports 3 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 3 instance_id 0 internalCost auto priority 128
config stp ports 3 fbpdu enable
config stp ports 3 restricted_role false
config stp ports 3 restricted_tcn false
config stp ports 4 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 4 instance_id 0 internalCost auto priority 128
config stp ports 4 fbpdu enable
config stp ports 4 restricted_role false
config stp ports 4 restricted_tcn false
config stp ports 5 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 5 instance_id 0 internalCost auto priority 128
config stp ports 5 fbpdu enable
config stp ports 5 restricted_role false
config stp ports 5 restricted_tcn false
config stp ports 6 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 6 instance_id 0 internalCost auto priority 128
config stp ports 6 fbpdu enable
config stp ports 6 restricted_role false
config stp ports 6 restricted_tcn false
config stp ports 7 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 7 instance_id 0 internalCost auto priority 128
config stp ports 7 fbpdu enable
config stp ports 7 restricted_role false
config stp ports 7 restricted_tcn false
config stp ports 8 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 8 instance_id 0 internalCost auto priority 128
config stp ports 8 fbpdu enable
config stp ports 8 restricted_role false
config stp ports 8 restricted_tcn false
config stp ports 9 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 9 instance_id 0 internalCost auto priority 128
config stp ports 9 fbpdu enable
config stp ports 9 restricted_role false
config stp ports 9 restricted_tcn false
config stp ports 10 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 10 instance_id 0 internalCost auto priority 128
config stp ports 10 fbpdu enable
config stp ports 10 restricted_role false
config stp ports 10 restricted_tcn false
config stp ports 11 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 11 instance_id 0 internalCost auto priority 128
config stp ports 11 fbpdu enable
config stp ports 11 restricted_role false
config stp ports 11 restricted_tcn false
config stp ports 12 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 12 instance_id 0 internalCost auto priority 128
config stp ports 12 fbpdu enable
config stp ports 12 restricted_role false
config stp ports 12 restricted_tcn false
config stp ports 13 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 13 instance_id 0 internalCost auto priority 128
config stp ports 13 fbpdu enable
config stp ports 13 restricted_role false
config stp ports 13 restricted_tcn false
config stp ports 14 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 14 instance_id 0 internalCost auto priority 128
config stp ports 14 fbpdu enable
config stp ports 14 restricted_role false
config stp ports 14 restricted_tcn false
config stp ports 15 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 15 instance_id 0 internalCost auto priority 128
config stp ports 15 fbpdu enable
config stp ports 15 restricted_role false
config stp ports 15 restricted_tcn false
config stp ports 16 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 16 instance_id 0 internalCost auto priority 128
config stp ports 16 fbpdu enable
config stp ports 16 restricted_role false
config stp ports 16 restricted_tcn false
config stp ports 17 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 17 instance_id 0 internalCost auto priority 128
config stp ports 17 fbpdu enable
config stp ports 17 restricted_role false
config stp ports 17 restricted_tcn false
config stp ports 18 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 18 instance_id 0 internalCost auto priority 128
config stp ports 18 fbpdu enable
config stp ports 18 restricted_role false
config stp ports 18 restricted_tcn false
config stp ports 19 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 19 instance_id 0 internalCost auto priority 128
config stp ports 19 fbpdu enable
config stp ports 19 restricted_role false
config stp ports 19 restricted_tcn false
config stp ports 20 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 20 instance_id 0 internalCost auto priority 128
config stp ports 20 fbpdu enable
config stp ports 20 restricted_role false
config stp ports 20 restricted_tcn false
config stp ports 21 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 21 instance_id 0 internalCost auto priority 128
config stp ports 21 fbpdu enable
config stp ports 21 restricted_role false
config stp ports 21 restricted_tcn false
config stp ports 22 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 22 instance_id 0 internalCost auto priority 128
config stp ports 22 fbpdu enable
config stp ports 22 restricted_role false
config stp ports 22 restricted_tcn false
config stp ports 23 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 23 instance_id 0 internalCost auto priority 128
config stp ports 23 fbpdu enable
config stp ports 23 restricted_role false
config stp ports 23 restricted_tcn false
config stp ports 24 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 24 instance_id 0 internalCost auto priority 128
config stp ports 24 fbpdu enable
config stp ports 24 restricted_role false
config stp ports 24 restricted_tcn false
config stp ports 25 externalCost auto edge false p2p auto state enable lbd disable
config stp mst_ports 25 instance_id 0 internalCost auto priority 128
config stp ports 25 fbpdu enable
config stp ports 25 restricted_role false
config stp ports 25 restricted_tcn false
config stp ports 26 externalCost auto edge false p2p auto state enable lbd disable
config stp mst_ports 26 instance_id 0 internalCost auto priority 128
config stp ports 26 fbpdu enable
config stp ports 26 restricted_role false
config stp ports 26 restricted_tcn false
config stp ports 27 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 27 instance_id 0 internalCost auto priority 128
config stp ports 27 fbpdu enable
config stp ports 27 restricted_role false
config stp ports 27 restricted_tcn false
config stp ports 28 externalCost auto edge false p2p auto state disable lbd disable
config stp mst_ports 28 instance_id 0 internalCost auto priority 128
config stp ports 28 fbpdu enable
config stp ports 28 restricted_role false
config stp ports 28 restricted_tcn false
config stp mst_config_id name 00:22:B0:67:4B:E9 revision_level 0
В качестве ядра - Catalyst 6500. Его настройки STP и транковых портов этого кольца:
Core#sh run | i spanning
spanning-tree mode pvst
spanning-tree extend system-id
spanning-tree vlan 1 priority 8192
Core#sh spanning-tree summary
Switch is in pvst mode
Root bridge for: VLAN0001, VLAN0003-VLAN0006, VLAN0010-VLAN0011
  VLAN0014-VLAN0098, VLAN0100-VLAN0103, VLAN0105-VLAN0143, VLAN0157, VLAN0166
  VLAN0241, VLAN0251-VLAN0252, VLAN0345, VLAN0358, VLAN0439, VLAN0588
  VLAN0594-VLAN0595, VLAN0599, VLAN0617, VLAN0753, VLAN0772, VLAN0888
  VLAN0891, VLAN0965, VLAN0986, VLAN1000, VLAN1114, VLAN1126-VLAN1131
  VLAN1134, VLAN1144-VLAN1145, VLAN1147-VLAN1149, VLAN1165, VLAN1170-VLAN1171
  VLAN1173, VLAN1180-VLAN1181, VLAN1184, VLAN1187-VLAN1188, VLAN1193
  VLAN1195-VLAN1196, VLAN1198, VLAN1201-VLAN1202, VLAN1218, VLAN1224, VLAN123
  VLAN1239, VLAN1241, VLAN1273, VLAN1277-VLAN1278, VLAN1283, VLAN1292
  VLAN1297, VLAN1302, VLAN1307, VLAN1356, VLAN1408, VLAN1420-VLAN1421
  VLAN1430, VLAN1442, VLAN1449, VLAN1508
EtherChannel misconfig guard is enabled
Extended system ID           is enabled
Portfast Default             is disabled
PortFast BPDU Guard Default  is disabled
Portfast BPDU Filter Default is disabled
Loopguard Default            is disabled
UplinkFast                   is disabled
BackboneFast                 is disabled
Pathcost method used is short
Name                   Blocking Listening Learning Forwarding STP Active
VLAN0001                     0         0        0         30         30
VLAN0003                     1         0        0         30         31
VLAN0004                     0         0        0          2          2
VLAN0005                     0         0        0          7          7
VLAN0006                     0         0        0          3          3
VLAN0010                     0         0        0         24         24
VLAN0011                     0         0        0         23         23
VLAN0014                     0         0        0          2          2
VLAN0015                     0         0        0          2          2
VLAN0016                     0         0        0          2          2
VLAN0017                     0         0        0          2          2
VLAN0018                     0         0        0          2          2
VLAN0019                     0         0        0          2          2
VLAN0020                     0         0        0          2          2
VLAN0021                     0         0        0          2          2
VLAN0022                     0         0        0          2          2
VLAN0023                     0         0        0          2          2
VLAN0024                     0         0        0          2          2
VLAN0025                     0         0        0          2          2
VLAN0026                     0         0        0          2          2
VLAN0027                     0         0        0          2          2
VLAN0028                     0         0        0          2          2
VLAN0029                     0         0        0          2          2
VLAN0030                     0         0        0          2          2
VLAN0031                     0         0        0          2          2
VLAN0032                     0         0        0          2          2
VLAN0033                     0         0        0          2          2
VLAN0034                     0         0        0          2          2
VLAN0035                     0         0        0          2          2
VLAN0036                     0         0        0          2          2
interface GigabitEthernet2/3
 switchport
 switchport trunk encapsulation dot1q
 switchport trunk allowed vlan 1,3,10,11,45-53,98
 switchport mode trunk
 no ip address
 mls qos vlan-based
interface GigabitEthernet3/3
 switchport
 no ip address
 mls qos vlan-based
СообщениеДобавлено: Вс дек 12, 2010 16:40
Прошивка на длинке похоже древнючая. Надо обновить. Затем на всех клиентских портах:
restricted_role true
restricted_tcn true
edge true
СообщениеДобавлено: Вс дек 12, 2010 17:03
На 3200
Boot PROM Version  : Build 1.00.B003
Firmware Version   : Build 1.10.B015
На 3028
Boot PROM Version  : Build 1.00-B05
Firmware Version   : Build 2.00.B27
Похоже действительно старье. Какие порекомендуете прошить?
На клиентских портах наверно еще стоит отключить fbpdu?
СообщениеДобавлено: Вс дек 12, 2010 17:07
Свежие прошивки можно запросить в специальной прикрепленной теме. У меня же сейчас те, что в подписи.
Насчет fbpdu не скажу. А по проблеме предполагаю, что на каком то из дергающихся портов включен tcn (то есть restrict_tcn=false) и потому уведомления разлетаются по всей сети.
И еще: 3028 из кольца лучше убрать, если есть возможность :)
СообщениеДобавлено: Вс дек 12, 2010 20:24
Спасибо, попробуем
СообщениеДобавлено: Пн дек 13, 2010 11:19
У DES-3028 отключите на магистральных портах ingress_checking
СообщениеДобавлено: Пн дек 13, 2010 11:57
pvst это не stp :D (и не rstp)
сам сталкивался в итоге все было переведено на mstp так как у циски он сделан по стандарту, а не с какими то фирменными дополнениями от себя
Умная книжка по теории сетей и настройкам свичей:
ftp://ftp.dlink.ru/pub/Trainings/Switch_D-Link_newest_Basic.pdf
СообщениеДобавлено: Пн дек 13, 2010 12:05
Не могли бы подробней рассказать, как Вы перевели все на mstp? Кстати, текущая конфигурация работает, если не считать этого мусора, который заметил в логах. Но хотелось бы конечно сделать правильно, чтобы не наступить в последствии на какие нибудь грабли.
СообщениеДобавлено: Пн дек 13, 2010 17:45
mik0s, с Topology Change Notification когда то боролся и решил так, как описал выше - разрешил tcn только на магистральных портах, а иначе логи смотреть невозможно :)
СообщениеДобавлено: Вт дек 14, 2010 16:07
mik0s
две главные команды:
длинк
config stp version mstp
циско
spanning-tree mode mstp
СообщениеДобавлено: Вт дек 14, 2010 16:12
Не помогло :( Все равно срет в логи. Прошивки не менял.
СообщениеДобавлено: Вт дек 14, 2010 16:15
Это для gvrp? Оно у меня не используется.
СообщениеДобавлено: Вт дек 14, 2010 17:26
Нет, это не для gvrp, просто оно настраивается там же.
СообщениеДобавлено: Вт дек 14, 2010 19:17
25-28 транковые порты. Оно?
config gvrp 25-28 ingress_checking disable
СообщениеДобавлено: Ср дек 15, 2010 10:12
Да
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 101
