Текущее время: Пт окт 02, 2026 18:22
 Заголовок сообщения: DES-3016 и опять STP
СообщениеДобавлено: Чт июл 08, 2010 20:39
Что бы это значило ?
4.30.B20
113 2010-07-08,01:56:31 New Root selected (MAC: 00-0D-88-68-E7-00, Priority: 20480)
112 2010-07-08,01:56:27 New Root selected (MAC: 00-19-5B-8C-3B-97, Priority: 32768)
111 2010-07-08,01:56:13 New Root selected (MAC: 00-0D-88-68-E7-00, Priority: 20480)
110 2010-07-08,01:55:57 New Root selected (MAC: 00-19-5B-8C-3B-97, Priority: 32768)
109 2010-07-08,01:55:44 New Root selected (MAC: 00-0D-88-68-E7-00, Priority: 20480)
108 2010-07-08,01:55:43 New Root selected (MAC: 00-19-5B-8C-3B-97, Priority: 32768)
107 2010-07-08,01:35:43 New Root selected (MAC: 00-0D-88-68-E7-00, Priority: 20480)
106 2010-07-08,01:35:41 New Root selected (MAC: 00-19-5B-8C-3B-97, Priority: 32768)
[/quote]
# STP
config stp maxage 20 hellotime 2 forwarddelay 15 priority 32768 version rstp t
xholdcount 6 fbpdu enabled
enable stp
config stp ports 1 cost auto priority 128 edge true p2p auto state disabled fb
pdu disabled restricted_role true restricted_tcn true
config stp ports 2 cost auto priority 128 edge true p2p auto state enabled fbp
config stp ports 3 cost auto priority 128 edge false p2p auto state enabled fb
pdu enabled restricted_role false restricted_tcn false
config stp ports 4 cost auto priority 128 edge true p2p auto state disabled fb
config stp ports 5 cost auto priority 128 edge true p2p auto state disabled fb
config stp ports 6 cost auto priority 128 edge true p2p auto state disabled fb
config stp ports 7 cost auto priority 128 edge true p2p auto state disabled fb
config stp ports 8 cost auto priority 128 edge true p2p auto state disabled fb
config stp ports 9 cost auto priority 128 edge true p2p auto state disabled fb
config stp ports 10 cost auto priority 128 edge true p2p auto state disabled f
bpdu disabled restricted_role true restricted_tcn true
config stp ports 11 cost auto priority 128 edge true p2p auto state disabled f
config stp ports 12 cost auto priority 128 edge true p2p auto state disabled f
config stp ports 13 cost auto priority 128 edge true p2p auto state disabled f
config stp ports 14 cost auto priority 128 edge true p2p auto state disabled f
config stp ports 15 cost auto priority 128 edge true p2p auto state disabled f
config stp ports 16 cost auto priority 128 edge true p2p auto state disabled f
И ещё DES 3026
Заносит некоторых абонентов в блок лист при правильной связке айпи мак на порту на котором в общем 20 абонентов с такими же связками.
4.30.B20
СообщениеДобавлено: Пт июл 09, 2010 10:31
Коммутаторы почему-то не получают пакетов от рута и постоянно его перевыбирают.
У Вас в кольце только DES-3016? Сколько коммутаторов в кольце?
СообщениеДобавлено: Пт июл 09, 2010 11:39
Нет кольца, звезда.
И я извиняюсь, все комутаторы в сети писали тоже в это время.
