Текущее время: Вс сен 27, 2026 07:16
 Заголовок сообщения: ip-mac-port-binding & routers dlink
СообщениеДобавлено: Сб май 29, 2010 13:52
Есть конфиг свича дес 3028
Device Type        : DES-3028 Fast Ethernet Switch
MAC Address        : 00-1E-58-A6-AE-75
VLAN Name          : Control
Boot PROM Version  : Build 1.00-B04
Firmware Version   : Build 2.50.B08
Hardware Version   : A1
System Contact     :
Spanning Tree      : Disabled
GVRP               : Disabled
IGMP Snooping      : Disabled
VLAN trunk         : Disabled
802.1x             : Disabled
TELNET             : Enabled(TCP  23)
WEB                : Enabled(TCP  80)
RMON               : Disabled
SSH                : Disabled
SSL                : Disabled
Clipaging          : Enabled
Syslog Global State: Disabled
Dual Image         : Supported
Password Encryption Status : Enabled
enable address_binding dhcp_snoop
enable address_binding trap_log
config address_binding ip_mac ports 1-5,7-9,11-24 state enable loose allow_zeroip enable forward_dhcppkt enable
config address_binding ip_mac ports 1-28 mode arp stop_learning_threshold 500
config address_binding dhcp_snoop max_entry ports 1-5,7-28 limit 5
config address_binding ip_mac ports 6,10 state disable allow_zeroip enable forward_dhcppkt enable
config address_binding dhcp_snoop max_entry ports 6 limit no_limit
config address_binding ip_mac ports 25-28 state disable allow_zeroip disable forward_dhcppkt enable
НА 10 порту была включена фунцкия адрес биндинга(в конфиге выше уже отрубил)
вот что происходит:
May 29 14:48:21 dhcp3 dhcpd: DHCPDISCOVER from 00:04:76:91:44:e5 via 172.82.0.1
May 29 14:48:21 dhcp3 dhcpd: DHCPOFFER on 172.82.30.21 to 00:04:76:91:44:e5 via 172.82.0.1
May 29 14:48:23 dhcp3 dhcpd: DHCPDISCOVER from 00:04:76:91:44:e5 via 172.82.0.1
May 29 14:48:23 dhcp3 dhcpd: DHCPOFFER on 172.82.30.21 to 00:04:76:91:44:e5 via 172.82.0.1
May 29 14:48:27 dhcp3 dhcpd: DHCPDISCOVER from 00:04:76:91:44:e5 via 172.82.0.1
May 29 14:48:27 dhcp3 dhcpd: DHCPOFFER on 172.82.30.21 to 00:04:76:91:44:e5 via 172.82.0.1
May 29 14:48:35 dhcp3 dhcpd: DHCPDISCOVER from 00:04:76:91:44:e5 via 172.82.0.1
May 29 14:48:35 dhcp3 dhcpd: DHCPOFFER on 172.82.30.21 to 00:04:76:91:44:e5 via 172.82.0.1
May 29 14:48:51 dhcp3 dhcpd: DHCPDISCOVER from 00:04:76:91:44:e5 via 172.82.0.1
May 29 14:48:51 dhcp3 dhcpd: DHCPOFFER on 172.82.30.21 to 00:04:76:91:44:e5 via 172.82.0.1
При этом :
VID  VLAN Name                        MAC Address       Port Type
1102 users                            00-04-76-91-44-E5 10   Dynamic
Total Entries  : 1
Адрес не блокируется, но и не попадает в binding_entry
ps
после включения функции адрес биндинга эта проблема всплыла у тех, у кого есть роутеры))))
Прошу помощи
СообщениеДобавлено: Пн май 31, 2010 09:07
Уточните модели роутеров.Обновите прошивку,на ту которую я Вам выслал и используйте режим strict.
СообщениеДобавлено: Вт июн 01, 2010 16:53
Возникла аналогичная проблема. Есть des-3028(Firmware: Build 2.42.B01), есть роутер DIR-100(2.02). Также присутствует dhcp_snoop, и полностью аналогичные отношения с dhcp-сервером.
СообщениеДобавлено: Вт июн 01, 2010 16:57
