Текущее время: Пн сен 28, 2026 23:23
 Заголовок сообщения: DGS-3612G дубли пингов.
СообщениеДобавлено: Пт дек 04, 2009 14:36
Обнаружилась следующая проблема:
есть vlan office, на нем - два интерфейса (office & office_mgmt). В одной подсети - компьютер, в другой - свитч. Запускаю пинг, вижу следующее:
abram@uainet-netbook:~$ ping 10.1.100.2
PING 10.1.100.2 (10.1.100.2) 56(84) bytes of data.
64 bytes from 10.1.100.2: icmp_seq=1 ttl=63 time=0.570 ms
64 bytes from 10.1.100.2: icmp_seq=2 ttl=63 time=0.610 ms
64 bytes from 10.1.100.2: icmp_seq=3 ttl=63 time=0.586 ms
64 bytes from 10.1.100.2: icmp_seq=4 ttl=63 time=0.599 ms
64 bytes from 10.1.100.2: icmp_seq=5 ttl=63 time=0.600 ms
64 bytes from 10.1.100.2: icmp_seq=6 ttl=63 time=0.599 ms
64 bytes from 10.1.100.2: icmp_seq=6 ttl=63 time=270 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=6 ttl=63 time=290 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=6 ttl=63 time=427 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=7 ttl=63 time=0.604 ms
64 bytes from 10.1.100.2: icmp_seq=7 ttl=63 time=1.62 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=7 ttl=63 time=1.66 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=7 ttl=63 time=2.27 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=8 ttl=63 time=0.573 ms
64 bytes from 10.1.100.2: icmp_seq=8 ttl=63 time=1.57 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=8 ttl=63 time=1.62 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=8 ttl=63 time=2.23 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=9 ttl=63 time=0.574 ms
64 bytes from 10.1.100.2: icmp_seq=9 ttl=63 time=1.41 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=9 ttl=63 time=1.44 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=9 ttl=63 time=2.25 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=10 ttl=63 time=0.596 ms
64 bytes from 10.1.100.2: icmp_seq=10 ttl=63 time=1.43 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=10 ttl=63 time=1.47 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=10 ttl=63 time=2.08 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=11 ttl=63 time=0.580 ms
64 bytes from 10.1.100.2: icmp_seq=11 ttl=63 time=1.60 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=11 ttl=63 time=1.87 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=11 ttl=63 time=2.27 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=12 ttl=63 time=0.607 ms
64 bytes from 10.1.100.2: icmp_seq=12 ttl=63 time=1.42 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=12 ttl=63 time=1.45 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=12 ttl=63 time=2.09 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=13 ttl=63 time=0.575 ms
64 bytes from 10.1.100.2: icmp_seq=13 ttl=63 time=1.40 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=13 ttl=63 time=1.43 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=13 ttl=63 time=2.26 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=14 ttl=63 time=0.599 ms
64 bytes from 10.1.100.2: icmp_seq=14 ttl=63 time=1.40 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=14 ttl=63 time=1.43 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=14 ttl=63 time=2.06 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=15 ttl=63 time=0.592 ms
64 bytes from 10.1.100.2: icmp_seq=15 ttl=63 time=1.58 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=15 ttl=63 time=1.61 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=15 ttl=63 time=2.22 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=16 ttl=63 time=0.601 ms
64 bytes from 10.1.100.2: icmp_seq=16 ttl=63 time=1.43 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=16 ttl=63 time=1.47 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=16 ttl=63 time=2.09 ms (DUP!)
64 bytes from 10.1.100.2: icmp_seq=17 ttl=63 time=0.585 ms
64 bytes from 10.1.100.2: icmp_seq=18 ttl=63 time=0.609 ms
64 bytes from 10.1.100.2: icmp_seq=19 ttl=63 time=0.587 ms
64 bytes from 10.1.100.2: icmp_seq=20 ttl=63 time=0.607 ms
64 bytes from 10.1.100.2: icmp_seq=21 ttl=63 time=0.597 ms
Дубликатов других пакетов нет, только пинги.
На свитч 10.1.100.2 нареканий нет - тем более, то же встречается в других vlan-ах с теми же симптомами. Пинг между вланами ходит нормальный.
В чем проблема?
СообщениеДобавлено: Пт дек 04, 2009 14:57
Версия прошивки?
СообщениеДобавлено: Сб дек 05, 2009 00:00
Boot PROM Version : Build 1.10-B09
Firmware Version  : Build 2.50.B25
Hardware Version  : A1
СообщениеДобавлено: Сб дек 05, 2009 22:34
Попробуйте пожалуйста прошивку которую я Вам выслал.
СообщениеДобавлено: Вт дек 08, 2009 00:23
На днях попробую и отпишусь.
 Заголовок сообщения: DGS-3627 + DES-3526, 3550 - DUPы
СообщениеДобавлено: Пн дек 28, 2009 11:12
Тоже проблема с DUP'ами.
ping main-voip-floor1
PING main-voip-floor1.bfgryb.local (10.10.101.201) 56(84) bytes of data.
64 bytes from main-voip-floor1.bfgryb.local (10.10.101.201): icmp_seq=1 ttl=127 time=0.385 ms
64 bytes from main-voip-floor1.bfgryb.local (10.10.101.201): icmp_seq=1 ttl=127 time=1.07 ms (DUP!)
64 bytes from main-voip-floor1.bfgryb.local (10.10.101.201): icmp_seq=1 ttl=127 time=1.55 ms (DUP!)
64 bytes from main-voip-floor1.bfgryb.local (10.10.101.201): icmp_seq=1 ttl=127 time=1.89 ms (DUP!)
64 bytes from main-voip-floor1.bfgryb.local (10.10.101.201): icmp_seq=2 ttl=127 time=0.393 ms
64 bytes from main-voip-floor1.bfgryb.local (10.10.101.201): icmp_seq=2 ttl=127 time=1.13 ms (DUP!)
64 bytes from main-voip-floor1.bfgryb.local (10.10.101.201): icmp_seq=2 ttl=127 time=1.48 ms (DUP!)
64 bytes from main-voip-floor1.bfgryb.local (10.10.101.201): icmp_seq=2 ttl=127 time=1.82 ms (DUP!)
64 bytes from main-voip-floor1.bfgryb.local (10.10.101.201): icmp_seq=3 ttl=127 time=0.374 ms
64 bytes from main-voip-floor1.bfgryb.local (10.10.101.201): icmp_seq=3 ttl=127 time=1.32 ms (DUP!)
64 bytes from main-voip-floor1.bfgryb.local (10.10.101.201): icmp_seq=3 ttl=127 time=1.60 ms (DUP!)
64 bytes from main-voip-floor1.bfgryb.local (10.10.101.201): icmp_seq=3 ttl=127 time=2.06 ms (DUP!)
^C
--- main-voip-floor1.bfgryb.local ping statistics ---
3 packets transmitted, 3 received, +9 duplicates, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 0.374/1.258/2.067/0.575 ms
Сетка такая. В центре стоит DGS-3627:
Device Type : DGS-3627 Gigabit Ethernet Switch
В помещениях DES-3550:
Device Type : DES-3550 Fast-Ethernet Switch
Boot PROM Version : Build 5.00.009
Firmware Version : Build 6.00.B25
Hardware Version : A4G
или DES-3526:
Device Type : DES-3526 Fast-Ethernet Switch
Firmware Version : Build 5.01.B52
Hardware Version : 3A1
или более свежий 3526:
Дубы наблюдаются при транзитных пингах сквозь DGS-3627. Внутри настроено два vlan'а и 4 интерфейса.
VID : 1 VLAN Name : default
VLAN Type : Static Advertisement : Disabled
Member Ports : 1-4,6-19,21-27
Static Ports : 1-4,6-19,21-27
Current Tagged Ports :
Current Untagged Ports: 1-4,6-19,21-27
Static Tagged Ports :
Static Untagged Ports : 1-4,6-19,21-27
Forbidden Ports :
VID : 2 VLAN Name : main_central
Member Ports : 5,20
Static Ports : 5,20
Current Untagged Ports: 5,20
Static Untagged Ports : 5,20
Forbidden Ports :
IP Interface : System
VLAN Name : default
Interface Admin state : Enabled
IPv4 Address : 10.10.101.1/24 (Manual) Primary
Proxy ARP : Disabled (Local : Disabled)
IP MTU : 1500
IP Interface : main_users1
VLAN Name : default
IPv4 Address : 10.10.2.21/25 (Manual) Secondary
IP MTU : 1500
IP Interface : main_users2
VLAN Name : default
IPv4 Address : 10.100.0.1/16 (Manual) Secondary
IP MTU : 1500
IP Interface : main_central
IPv4 Address : 10.10.102.249/29 (Manual) Primary
IP MTU : 1500
Надо сказать, что сеть в процессе реформы. Раньше DGS вообще не было, было меньше свичей 35ХХ, соединённых напрямую. С одним VLAN'ом. Аномалий не наблюдалось. Но надо расти и возникли потребности в делении. В будущем планируется разнести подсети IP по VLAN'ам, и возможно их станет ещё больше.
ДУПы наблюдаются при межсетевых пингах с точки зрения IP, то есть когда 3627 работает как маршрутизатор. Когда как чистый коммутатор, пусть даже пакеты идут через него по той же физической траектории, всё нормально. Пример, аналогичный предыдущему, но в той же подсети:
ping ofl-comp1
PING ofl-comp1.bfgryb.local (10.10.2.69) 56(84) bytes of data.
64 bytes from ofl-comp1.bfgryb.local (10.10.2.69): icmp_seq=1 ttl=128 time=0.191 ms
64 bytes from ofl-comp1.bfgryb.local (10.10.2.69): icmp_seq=2 ttl=128 time=0.189 ms
64 bytes from ofl-comp1.bfgryb.local (10.10.2.69): icmp_seq=3 ttl=128 time=0.194 ms
64 bytes from ofl-comp1.bfgryb.local (10.10.2.69): icmp_seq=4 ttl=128 time=0.205 ms
64 bytes from ofl-comp1.bfgryb.local (10.10.2.69): icmp_seq=5 ttl=128 time=0.206 ms
64 bytes from ofl-comp1.bfgryb.local (10.10.2.69): icmp_seq=6 ttl=128 time=0.203 ms
^C
--- ofl-comp1.bfgryb.local ping statistics ---
6 packets transmitted, 6 received, 0% packet loss, time 5000ms
rtt min/avg/max/mdev = 0.189/0.198/0.206/0.006 ms
Ещё у нас по сети ходит IP-телефония (SIP). И замечено, что когда пакеты идут по "больным" маршрутам, голос стал иногда "заикаться".
Прошу помочь. Вероятно - прошивкой для DGS-3627, или ещё как.
 Заголовок сообщения: Re: DGS-3627 + DES-3526, 3550 - DUPы
СообщениеДобавлено: Пн дек 28, 2009 11:59
Клиентский трафик и мультикаст не должны маршрутизироваться через ipif System.
Бигаров Руслан.
СообщениеДобавлено: Пн дек 28, 2009 13:43
То есть мне надо ещё раз create ipif, и чтобы подсетка 10.10.101.0/24 висела на новом, а на System что-то вновь придуманное специально для свича. Я правильно понял?
Только вот такая незадача: пингаю так, что оба адреса к System не относятся:
PING 10.100.0.2 (10.100.0.2) 56(84) bytes of data.
64 bytes from 10.100.0.2: icmp_seq=1 ttl=64 time=0.196 ms
64 bytes from 10.100.0.2: icmp_seq=1 ttl=64 time=0.851 ms (DUP!)
64 bytes from 10.100.0.2: icmp_seq=2 ttl=64 time=0.192 ms
64 bytes from 10.100.0.2: icmp_seq=2 ttl=64 time=0.843 ms (DUP!)
^C
--- 10.100.0.2 ping statistics ---
2 packets transmitted, 2 received, +2 duplicates, 0% packet loss, time 1000ms
rtt min/avg/max/mdev = 0.192/0.520/0.851/0.327 ms
Исходный адрес 10.10.2.99 (ipif main_users1). Конечный - на main_users2. А ДУПы всё-таки тут!
А если обращаться к IP самого свича, причём к любым из любой подсетки, то всё "чисто", пакеты один-в-один.
СообщениеДобавлено: Пн дек 28, 2009 15:11
again писал(а):
То есть мне надо ещё раз create ipif, и чтобы подсетка 10.10.101.0/24 висела на новом, а на System что-то вновь придуманное специально для свича. Я правильно понял? ...
Да, ipif System нужно использовать только для управления коммутатором и для служебных функций.
P.S.: Также нужно обновить прошивку, я выслал Вам её на почту. После обновления прошивки нужно сбросить настройки командой "reset" и залить конфигурационный файл с сохранением настроек.
Бигаров Руслан.
СообщениеДобавлено: Пн дек 28, 2009 15:34
P.S.: Также нужно обновить прошивку, я выслал Вам её на почту. После обновления прошивки нужно сбросить настройки командой "reset" и залить конфигурационный файл с сохранением настроек.[/quote]
Спасибо, получил. Только чувствую что-либо поменять мне пока не дадут. Конец года, всем как обычно в последний момент сеть подавай с утра до позднего вечера, хоть какую-нибудь. Только в праздники.
СообщениеДобавлено: Пн дек 28, 2009 15:47
Хорошо, тогда жду ответ после праздника.
Бигаров Руслан.
СообщениеДобавлено: Вт янв 12, 2010 12:15
Обновился - переконфигурился. ДУПы исчезли сразу же. Сейчас люди работают, нареканий нет. Большое спасибо.
СообщениеДобавлено: Вт янв 12, 2010 12:38
Рад слышать!
СообщениеДобавлено: Ср апр 07, 2010 14:21
У меня на почте лежит высланная вами 2.52. Как-то не было времени и прошивку я так и не обновлял.
Сейчас есть другая проблема: частые разрывы PPTP. Заметил, что свитч иногда дропает ICMP (то ли не успевает ARP-запрос пройти, то ли что?), возможно, и другие пакеты.
Были ли от 2.50 до 2.52 ещё какие фиксы?
СообщениеДобавлено: Ср апр 07, 2010 15:59
Уже есть прошивки R2.55
Бигаров Руслан.
