Текущее время: Чт окт 01, 2026 19:06
 Заголовок сообщения: DXS-3326GSR, SFP Port 1:1 I2C componet or bus is abnormal
СообщениеДобавлено: Чт апр 01, 2010 13:41
В логах:
72643 2010-04-01 13:41:16 SFP Port 1:1 I2C componet or bus is abnormal
72642 2010-04-01 13:41:16 SFP Port 1:20 I2C componet or bus is abnormal
72641 2010-04-01 13:41:16 SFP Port 1:19 I2C componet or bus is abnormal
72640 2010-04-01 13:41:16 SFP Port 1:18 I2C componet or bus is abnormal
72639 2010-04-01 13:41:16 SFP Port 1:17 I2C componet or bus is abnormal
72638 2010-04-01 13:41:16 SFP Port 1:16 I2C componet or bus is abnormal
72637 2010-04-01 13:41:16 SFP Port 1:15 I2C componet or bus is abnormal
72636 2010-04-01 13:41:16 SFP Port 1:14 I2C componet or bus is abnormal
72635 2010-04-01 13:41:16 SFP Port 1:13 I2C componet or bus is abnormal
72634 2010-04-01 13:41:16 SFP Port 1:12 I2C componet or bus is abnormal
72633 2010-04-01 13:41:16 SFP Port 1:11 I2C componet or bus is abnormal
72632 2010-04-01 13:41:16 SFP Port 1:10 I2C componet or bus is abnormal
72631 2010-04-01 13:41:16 SFP Port 1:9 I2C componet or bus is abnormal
72630 2010-04-01 13:41:16 SFP Port 1:8 I2C componet or bus is abnormal
72629 2010-04-01 13:41:16 SFP Port 1:7 I2C componet or bus is abnormal
72628 2010-04-01 13:41:16 SFP Port 1:6 I2C componet or bus is abnormal
72627 2010-04-01 13:41:16 SFP Port 1:5 I2C componet or bus is abnormal
72626 2010-04-01 13:41:16 SFP Port 1:4 I2C componet or bus is abnormal
72625 2010-04-01 13:41:16 SFP Port 1:3 I2C componet or bus is abnormal
72624 2010-04-01 13:41:16 SFP Port 1:2 I2C componet or bus is abnormal
Кто сталкивался с такой проблемой ? Железо подохло ?
Device Type : DXS-3326GSR Stackable Ethernet Switch
Firmware Version : Build 4.40-B26
 Заголовок сообщения: Re: DXS-3326GSR, SFP Port 1:1 I2C componet or bus is abnormal
СообщениеДобавлено: Чт апр 01, 2010 14:34
Да, судя по логу аппаратная проблема. Сколько лет в эксплуатации коммутатор?
Бигаров Руслан.
СообщениеДобавлено: Чт апр 01, 2010 14:46
Лет 5-6
СообщениеДобавлено: Чт апр 01, 2010 17:27
Тогда точно в аппаратной части дело, можно в СЦ сдать для анализа.
Бигаров Руслан.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 73
cron
