Текущее время: Ср сен 23, 2026 12:12
 Заголовок сообщения: DGS-3130-54S RX dropped Pkts
СообщениеДобавлено: Ср янв 29, 2025 10:02
Здравствуйте.
есть:
Unit ID Module Name Versions
1 DGS-3130-54S H/W:B1
Bootloader:1.00.011
Runtime:2.00.B052
Фиксируем на портах RX dropped Pkts.
Switch#show interfaces ethernet 1/0/11
Eth1/0/11 is enabled link status is up (error disabled: LBD)
Interface type: 1000BASE-X
Interface description: unm.msk.Teslatel.isp--port1
MAC Address: 64-29-43-f1-9d-9c
Auto-duplex, Auto-speed, Auto-MDIX
Send flow-control: off, receive flow-control: off
Send flow-control oper: off, receive flow-control oper: off
Full-duplex, 1000Mb/s
Maximum transmit unit: 9216 bytes
Last Linkchange 0:2:14:73
Current Link Duration: 6 day 7 hr 50 min 33 sec
RX rate: 87216 bits/sec, TX rate: 39488 bits/sec
RX bytes: 30407147329, TX bytes: 38396775146
RX rate: 60 packets/sec, TX rate: 39 packets/sec
RX packets: 71989285, TX packets: 58128422
RX multicast: 3034251, RX broadcast: 13139339
RX CRC error: 0, RX undersize: 0
RX fragment: 0, RX dropped Pkts: 9806893
RX MTU exceeded: 0
TX CRC error: 0, TX excessive deferral: 0
TX single collision: 0, TX excessive collision: 0
TX late collision: 0, TX collision: 0
Switch#show counters interface ethernet 1/0/11
eth1/0/11 counters
rxHCTotalPkts : 71992564
txHCTotalPkts : 58130921
rxHCUnicastPkts : 55818578
txHCUnicastPkts : 57857360
rxHCMulticastPkts : 3034270
txHCMulticastPkts : 181832
rxHCBroadcastPkts : 13139716
txHCBroadcastPkts : 91729
rxHCOctets : 30408386176
txHCOctets : 38397467272
rxHCPkt64Octets : 46
rxHCPkt65to127Octets : 31344816
rxHCPkt128to255Octets : 10737489
rxHCPkt256to511Octets : 14157569
rxHCPkt512to1023Octets : 1499844
rxHCPkt1024to1518Octets : 14249644
rxHCPkt1519to1522Octets : 0
rxHCPkt1519to2047Octets : 3156
rxHCPkt2048to4095Octets : 0
rxHCPkt4096to9216Octets : 0
txHCPkt64Octets : 1192359
txHCPkt65to127Octets : 24234974
txHCPkt128to255Octets : 7861856
txHCPkt256to511Octets : 1097371
txHCPkt512to1023Octets : 416802
txHCPkt1024to1518Octets : 23326346
txHCPkt1519to1522Octets : 0
txHCPkt1519to2047Octets : 1213
txHCPkt2048to4095Octets : 0
txHCPkt4096to9216Octets : 0
rxCRCAlignErrors : 0
rxUndersizedPkts : 0
rxFragmentPkts : 0
rxSymbolErrors : 0
rxBufferFullDropPkts : 0
rxMulticastDropPkts : 0
rxVLANIngressCheckDropPkts : 12004300
rxIpv6DropPkts : 1979
rxSTPDropPkts : 21
rxStormAndFDBDropPkts : 3723
rxMTUDropPkts : 0
txCollisions : 0
ifInErrors : 0
ifOutErrors : 0
ifInDiscards : 9806923
ifOutDiscards : 0
txDelayExceededDiscards : 0
txCRC : 0
txSTPDropPkts : 2
txHOLDropPkts : 0
txCoS0DropPkts : 0
txCoS1DropPkts : 0
txCoS2DropPkts : 0
txCoS3DropPkts : 0
txCoS4DropPkts : 0
txCoS5DropPkts : 0
txCoS6DropPkts : 0
txCoS7DropPkts : 0
dot3StatsSingleColFrames : 0
dot3StatsMultiColFrames : 0
dot3StatsDeferredTransmissions : 0
dot3StatsLateCollisions : 0
dot3StatsExcessiveCollisions : 0
dot3StatsInternalMacTransmitErrors : 0
dot3StatsFrameTooLongs : 0
linkChange : 3
Ошибки на некоторых портах сыпятся постоянно, на некоторых нет.
В частности на указанном выше ethernet 1/0/11, не постоянно сыпятся ошибки.
Порт 1G, sfp, загрузка порта - до 20 мбит/с.
Что такое ifInDiscards : 9806923 ?
 Заголовок сообщения: Re: DGS-3130-54S RX dropped Pkts
СообщениеДобавлено: Вт май 13, 2025 11:54
krasnonogov писал(а):
Здравствуйте.
есть:
Bootloader:1.00.011
Runtime:2.00.B052
RX MTU exceeded: 0
eth1/0/11 counters
rxFragmentPkts : 0
rxSymbolErrors : 0
rxSTPDropPkts : 21
rxMTUDropPkts : 0
txCollisions : 0
ifInErrors : 0
ifOutErrors : 0
ifOutDiscards : 0
txCRC : 0
txSTPDropPkts : 2
txHOLDropPkts : 0
txCoS0DropPkts : 0
txCoS1DropPkts : 0
txCoS2DropPkts : 0
txCoS3DropPkts : 0
txCoS4DropPkts : 0
txCoS5DropPkts : 0
txCoS6DropPkts : 0
txCoS7DropPkts : 0
linkChange : 3
Ошибка ifInDiscards указывает на то, что пакет был получен портом, но по какой-то причине отброшен.
Входной буфер — это выделенная область памяти на коммутаторе, куда записываются пакеты, пока они ожидают обработки. Если трафик превышает возможности обработки или передачу дальше, буфер переполняется, и пакеты начинают отбрасываться.
Причиной может быть превышение пропускной способности порта, несоответствие согласования Speed/Duplex, ошибки в настройках VLAN.
Проверьте настройки на порту этого коммутатора и на устройстве подключенном в него. Включите flowcontrol на порту:
interface eth1/0/11
flowcontrol on
Смущает сам счетчик или наблюдаются проблемы в сети?
