Текущее время: Пт сен 25, 2026 07:49
 Заголовок сообщения: Certificate Decode Failure
СообщениеДобавлено: Пт июн 26, 2020 10:56
Всем здравствуйте!
Имеется устройство
show switch
DGS-3000-26TC:admin#sh sw
Command: show switch
Device Type : DGS-3000-26TC Gigabit Ethernet Switch
MAC Address : 00-AD-24-74-B3-40
IP Address : 10.90.90.90 (Manual)
VLAN Name : default
Subnet Mask : 255.0.0.0
Default Gateway : 0.0.0.0
Boot PROM Version : Build 2.00.001
Firmware Version : Build 2.05.B008
Hardware Version : A2
С текущими настройками
show ssh algoritm
DGS-3000-26TC:admin#show ssh algorithm
Command: show ssh algorithm
Encryption Algorithm
3DES : Enabled
AES128 : Enabled
AES192 : Enabled
AES256 : Enabled
Arcfour : Enabled
Blowfish : Enabled
Cast128 : Enabled
Twofish128 : Enabled
Twofish192 : Enabled
Twofish256 : Enabled
Data Integrity Algorithm
MD5 : Enabled
SHA1 : Enabled
Public Key Algorithm
RSA : Enabled
DSA : Enabled
show ssh auth
DGS-3000-26TC:admin#show ssh auth
Command: show ssh authmode
The SSH Authentication Method:
Password : Enabled
Public Key : Enabled
Host-based : Enabled
show ssh server
DGS-3000-26TC:admin#show ssh server
Command: show ssh server
The SSH Server Configuration
Maximum Session : 8
Connection Timeout : 120
Authentication Fail Attempts : 2
Rekey Timeout : Never
TCP Port Number : 22
show ssh user authmode
DGS-3000-26TC:admin#show ssh user authmode
Command: show ssh user authmode
Current Accounts:
User Name Authentication Host Name Host IP
xyz Public Key
Total Entries : 1
show account
DGS-3000-26TC:admin#sh account
Command: show account
Current Accounts:
Username Access Level
xyz Admin
Total Entries : 1
show ssl
dgs3000-26TC:admin#sh ssl
Command: show ssl
SSL Status Enabled
SSL 3.0 Enabled
TLS 1.0 Enabled
TLS 1.1 Enabled
TLS 1.2 Enabled
Cipher Suites:
RSA_WITH_RC4_128_MD5 0x0004 Enabled
RSA_WITH_3DES_EDE_CBC_SHA 0x000A Enabled
DHE_DSS_WITH_3DES_EDE_CBC_SHA 0x0013 Enabled
RSA_EXPORT_WITH_RC4_40_MD5 0x0003 Enabled
RSA_WITH_AES_128_CBC_SHA 0x002F Enabled
RSA_WITH_AES_256_CBC_SHA 0x0035 Enabled
RSA_WITH_AES_128_CBC_SHA256 0x003C Enabled
RSA_WITH_AES_256_CBC_SHA256 0x003D Enabled
DHE_DSS_WITH_AES_256_CBC_SHA 0x0038 Enabled
DHE_RSA_WITH_AES_256_CBC_SHA 0x0039 Enabled
show wac
dgs3000-26TC:admin#sh w
Command: show wac
Web-based Access Control
State : Disabled
Method : Local
Redirect Path :
Virtual IP : 0.0.0.0
Virtual IPv6 : ::
Switch HTTP Port : 80 (HTTP)
RADIUS Authorization : Enabled
Local Authorization : Enabled
Trap State : Enabled
При попытке загрузке ssl, выдаёт ошибку
DGS-3000-26TC:admin#download ssl certificate  10.90.90.111 certfilename id_rsa keyfilename id_rsa.pub
Command: download ssl certificate 10.90.90.111 certfilename id_rsa keyfilename id_rsa.pub
Certificate Decode Failure!
Fail!
Настройки со стороны FTP
ifconfig
xyz@xyz-PC ~ $ ifconfig
enp3s0 Link encap:Ethernet HWaddr ac:22:0b:27:fa:84
inet addr:10.90.90.111 Bcast:10.90.90.255 Mask:255.255.255.0
inet6 addr: fe80::2f17:d5c3:1df1:3a96/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:428321 errors:0 dropped:0 overruns:0 frame:0
TX packets:31970 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:93843180 (93.8 MB) TX bytes:2614978 (2.6 MB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:25533 errors:0 dropped:0 overruns:0 frame:0
TX packets:25533 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1674957 (1.6 MB) TX bytes:1674957 (1.6 MB)
systemctl status atftp
xyz@xyz-PC ~ $ systemctl status atftp
● atftp.service
Loaded: not-found (Reason: No such file or directory)
Active: inactive (dead)
lmv@lmv-PC ~ $ systemctl status atftpd
● atftpd.service - LSB: Launch atftpd server
Loaded: loaded (/etc/init.d/atftpd; bad; vendor preset: enabled)
Active: active (running) since Чт 2020-06-25 09:23:49 +04; 6h ago
Docs: man:systemd-sysv-generator(8)
Process: 2697 ExecStart=/etc/init.d/atftpd start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/atftpd.service
└─2704 /usr/sbin/atftpd --daemon --tftpd-timeout 300 --retry-timeout 5 --mcast-port 1758 --mcast-addr 239.239.239.0-255 --mcast-ttl 1 --maxthread 100 --verbose=5 /home/xyz/dirFTP
июн 25 15:03:16 xyz-PC atftpd[2704]: Serving id_rsa.pub to 10.90.90.90:50001
июн 25 15:03:17 xyz-PC atftpd[2704]: Serving id_rsa to 10.90.90.90:50001
ls -la
xyz@xyz-PC ~ $ ls -la /home/xyz/dirFTP
total 8896
drwxrwxrwx 2 xyz xyz 4096 июн 25 13:03 .
drwxr-xr-x 39 xyz xyz 4096 июн 25 08:53 ..
-rwxrwxrwx 1 xyz xyz 1679 июн 16 15:12 id_rsa
-rwxrwxrwx 1 xyz xyz 392 июн 16 15:12 id_rsa.pub
Окажите помощь! Никак не пойму в чём дело...
Спасибо!
 Заголовок сообщения: Re: Certificate Decode Failure
СообщениеДобавлено: Ср янв 13, 2021 16:08
Здравствуйте. Уточните, что Вы пытаетесь сделать?
Судя по Вашему примеру Вы пытаетесь ключ от ssh загрузить как ssl сертификат.
СообщениеДобавлено: Чт янв 14, 2021 06:11
Да.
В идеале хотелось бы и того и другого.
