Текущее время: Чт сен 24, 2026 04:19
 Заголовок сообщения: DES-3200 phydetect
СообщениеДобавлено: Вт окт 22, 2019 11:11
Обновился до прошивки 1.91.B006, и появилась такая плюшка:
DES-3200-28:5#sh ports 1 ?
Command: show ports 1
Next possible completions:
{}                  description         err_disabled        phydetect
При вводе команды:
DES-3200-28:5#config ports 1-24 phydetect enable
В лог выпало это
37    2019-10-22 10:54:15 Port 24 perform the phy recovery
36    2019-10-22 10:54:15 Port 23 perform the phy recovery
35    2019-10-22 10:54:15 Port 22 perform the phy recovery
34    2019-10-22 10:54:15 Port 21 perform the phy recovery
33    2019-10-22 10:54:15 Port 20 perform the phy recovery
32    2019-10-22 10:54:15 Port 19 perform the phy recovery
31    2019-10-22 10:54:15 Port 18 perform the phy recovery
30    2019-10-22 10:54:15 Port 17 perform the phy recovery
29    2019-10-22 10:54:15 Port 16 perform the phy recovery
28    2019-10-22 10:54:15 Port 15 perform the phy recovery
27    2019-10-22 10:54:15 Port 14 perform the phy recovery
26    2019-10-22 10:54:15 Port 13 perform the phy recovery
25    2019-10-22 10:54:15 Port 12 perform the phy recovery
24    2019-10-22 10:54:15 Port 11 perform the phy recovery
23    2019-10-22 10:54:15 Port 10 perform the phy recovery
22    2019-10-22 10:54:15 Port 9 perform the phy recovery
21    2019-10-22 10:54:15 Port 8 perform the phy recovery
20    2019-10-22 10:54:15 Port 7 perform the phy recovery
19    2019-10-22 10:54:15 Port 6 perform the phy recovery
18    2019-10-22 10:54:15 Port 5 perform the phy recovery
17    2019-10-22 10:54:15 Port 4 perform the phy recovery
16    2019-10-22 10:54:15 Port 3 perform the phy recovery
15    2019-10-22 10:54:15 Port 2 perform the phy recovery
14    2019-10-22 10:54:15 Port 1 perform the phy recovery
Что за команда? Не гуглится (
Железка
DES-3200-28:5#sh sw
Command: show switch
Device Type        : DES-3200-28 Fast Ethernet Switch
Boot PROM Version  : Build 1.00.R004
Firmware Version   : Build 1.91.B006
Hardware Version   : A1
Внимательность! Это было на букву "Э"!
DES/DGS-3200-XX(A1/B1/C1), DGS-3627G(A1), DGS-3426(A1), DGS-3120-24SC(A1/A2/B1), DES-1210-28/ME(B2/B3)
 Заголовок сообщения: Re: DES-3200 phydetect
СообщениеДобавлено: Пн окт 28, 2019 10:24
Команда добавлена для предотвращения несовместимости с некоторыми устройствами. По нашим данным встречаются устройства, которые могут иногда терять связь с коммутатором, выглядит это как пропадание линка, после которого поднять линк на 100Мбит невозможно. Команда, если она включена, переинициализирует порт и поднимает его снова.
Если вы не встречались с такими проблемами, то включать функцию нет необходимости.
СообщениеДобавлено: Чт ноя 14, 2019 12:56
Спасибо.
Сейчас этот форум просматривают: Google [Bot] и гости: 18
