Текущее время: Чт сен 24, 2026 07:52
 Заголовок сообщения: nni ports and QinQ
СообщениеДобавлено: Пн фев 11, 2019 10:29
Hello everyone,,
As using one port on the switch, add SVID to outgoing packets with CVID, and to incoming ones that already shoot SVID, leaving only CVID (UNI port works the other way around)
There is a
<-> DGS-1210-20 / ME (port1) scheme <-> operator's network <-> (port1) DGS-1210-20 / ME
Ports1 in nni mode and pass two types of qinq and q packets.
For a number tech news free netflix of reasons, two things need to be done
1. qinq packets are allowed to pass without change,
2. in outgoing packets q add the upper tag so that they become qinq packets and pass through the operator’s network, and after the operator’s network do the opposite,
remove the upper tag in the incoming packets .
a crooked solution can be made by creating a "loop" between two other ports on each switch, one uni port of the second nni.
But is it possible to do this without a crooked solution?
Последний раз редактировалось DarylDixon Вт фев 12, 2019 09:07, всего редактировалось 1 раз.
 Заголовок сообщения: Re: nni ports and QinQ
СообщениеДобавлено: Пн фев 11, 2019 15:12
Use port-based and selective qinq as well
For example:
qinq vlan with svid tag 1111 is forwarded without changes, to all other packets vlan 999 is added
config vlan vlanid 1 delete 21
create vlan vlanid 999
config vlan vlanid 999 add untagged 21
config vlan vlanid 999 add tagged 22
config qinq ports 1-28 outer_tpid 0x8100
enable qinq
config qinq ports 21 role uni
config qinq ports 22 role nni
create vlan 1111 tag 1111
config vlan 1111 add tagged 21-22 advertisement disable
create vlan_translation ports 21 replace cvid 1111 svid 1111
