Текущее время: Пт июн 12, 2026 23:27
 Заголовок сообщения: DGS-3200-10 и ERPS
СообщениеДобавлено: Вт апр 10, 2018 21:29
Есть свич
DGS-3200-10:4#show switch
Command: show switch
Device Type       : DGS-3200-10 Gigabit Ethernet Switch
Boot PROM Version : Build 1.00.B013
Firmware Version  : Build 2.20.B007
Hardware Version  : B1
его конфигурация
 create erps raps_vlan 10
 config erps raps_vlan 10 timer holdoff_time 0 guard_time 500 wtr_time 5
 config erps raps_vlan 10 rpl_port west
 config erps raps_vlan 10 rpl_owner enable
 config erps raps_vlan 10 ring_mel 1
config erps raps_vlan 10 revertive mode enable
 config erps raps_vlan 10 ring_port west 1
 config erps raps_vlan 10 ring_port east 2
 config erps raps_vlan 10 protected_vlan add vlanid 255
 config erps raps_vlan 10 protected_vlan add vlanid 333
 enable erps
 config erps log enable
 config erps trap disable
но по выводу
DGS-3200-10:4#show erps
Command: show erps
 Global Status            : Enabled
 Log Status               : Enabled
 Trap Status              : Disabled
 R-APS VLAN               : 10
 ERPS Status              : Disabled
 Admin West Port          : 1
 Operational West Port    : 1    (Forwarding)
 Admin East Port          : 2
 Operational East Port    : 2    (Forwarding)
 Admin RPL Port           : West port
 Operational RPL Port     : West port
 Admin Owner              : Enabled
 Operational Owner        : Enabled
 Protected VLANs          : 255, 333
 Ring MEL                 : 1
 Holdoff Time             : 0 milliseconds
 Guard Time               : 500 milliseconds
 WTR Time                 : 5 minutes
 Revertive mode           : Enabled
 Current Ring State       : -
Второй свич
config erps raps_vlan 10 rpl_port none
config erps raps_vlan 10 rpl_owner disable
config erps raps_vlan 10 ring_port west 17
config erps raps_vlan 10 ring_port east 18
enable erps
DES-3200-18:5#show erps
Command: show erps
 ERPS Information
 ERPS Status          : Enabled
 R-APS VLAN           : 10
 West Port            : 17 (Blocking)
 East Port            : 18 (Forwarding)
 RPL Port             : None
 Owner                : Disabled
 Protection VLANs     : 255, 333
 Ring MEL             : 1
 Holdoff Time         : 0 ms
 Guard Time           : 500 ms
 Log                  : Enabled
 Trap                 : Disabled
 Current Ring State   : Protection
Device Type        : DES-3200-18 Fast Ethernet Switch
Boot PROM Version  : Build 1.00.B004
Firmware Version   : Build 1.83.B008
Hardware Version   : A1
Не могу понять почему у rpl_owner оба порта в статусе Forwarding, а второй свич не rpl_owner блокирует порт с своей стороны. Порт блокировать должен же rpl_owner, а у него оба порта в статусе Forwarding
Кольцо при етом работает.
 Заголовок сообщения: Re: DGS-3200-10 и ERPS
СообщениеДобавлено: Вт апр 10, 2018 21:42
извиняюсь.
забыл
config erps raps_vlan 10 state enable
теперь ок статусы стали.
можно закрыть тему.
СообщениеДобавлено: Ср апр 11, 2018 15:21
Закрыто
