Текущее время: Чт сен 24, 2026 17:27
 Заголовок сообщения: des-3028 gvrp
СообщениеДобавлено: Пт ноя 17, 2017 10:27
Имеем свич DES-3028, Firmware: Build 2.94.B16
DES-3028:5#show gvrp
Command: show gvrp
Global GVRP  : Disabled
Port    PVID      GVRP     Ingress Checking      Acceptable Frame Type
1       868     Disabled        Disabled         All Frames
2       868     Disabled        Disabled         All Frames
3       868     Disabled        Disabled         All Frames
4       868     Disabled        Disabled         All Frames
5       868     Disabled        Disabled         All Frames
6       868     Disabled        Disabled         All Frames
7       868     Disabled        Disabled         All Frames
8       868     Disabled        Disabled         All Frames
9       868     Disabled        Disabled         All Frames
10      868     Disabled        Disabled         All Frames
11      868     Disabled        Disabled         All Frames
12      868     Disabled        Disabled         All Frames
13      868     Disabled        Disabled         All Frames
14      868     Disabled        Disabled         All Frames
15      868     Disabled        Disabled         All Frames
16      868     Disabled        Disabled         All Frames
17      868     Disabled        Disabled         All Frames
18      868     Disabled        Disabled         All Frames
19      868     Disabled        Disabled         All Frames
20      868     Disabled        Disabled         All Frames
21      868     Disabled        Disabled         All Frames
22      868     Disabled        Disabled         All Frames
23      868     Disabled        Disabled         All Frames
24      868     Disabled        Disabled         All Frames
25      1       Disabled        Disabled         All Frames
26      1       Disabled        Disabled         All Frames
27      1       Disabled        Disabled         All Frames
28      1       Disabled        Disabled         All Frames
Total Entries  : 28
DES-3028:5#config gvrp all ingress_checking enable
Command: config gvrp all ingress_checking enable
Warning:Ingress checking only support global mode!
Success.
Command: show gvrp
Global GVRP  : Enabled
1       868     Disabled        Enabled          All Frames
2       868     Disabled        Enabled          All Frames
3       868     Disabled        Enabled          All Frames
4       868     Disabled        Enabled          All Frames
5       868     Disabled        Enabled          All Frames
6       868     Disabled        Enabled          All Frames
7       868     Disabled        Enabled          All Frames
8       868     Disabled        Enabled          All Frames
9       868     Disabled        Enabled          All Frames
10      868     Disabled        Enabled          All Frames
11      868     Disabled        Enabled          All Frames
12      868     Disabled        Enabled          All Frames
13      868     Disabled        Enabled          All Frames
14      868     Disabled        Enabled          All Frames
15      868     Disabled        Enabled          All Frames
16      868     Disabled        Enabled          All Frames
17      868     Disabled        Enabled          All Frames
18      868     Disabled        Enabled          All Frames
Сам по себе магическим образом включился gvrp.
