Текущее время: Сб сен 26, 2026 12:40
 Заголовок сообщения: DES-1210-28/ME Replace Source IP not working
СообщениеДобавлено: Чт дек 22, 2016 15:21
Использую DES-1210-28/ME в качестве коммутатора доступа.
Настроен igmp snooping multicast vlan.
# ISM vlan
enable igmp_snooping multicast_vlan
create igmp_snooping multicast_vlan IPTV  10
config igmp_snooping multicast_vlan IPTV  add member_port 1-24
config igmp_snooping multicast_vlan IPTV  add source_port 26
config igmp_snooping multicast_vlan IPTV  state enable
config igmp_snooping multicast_vlan IPTV  replace_source_ip 172.72.72.72
config mld_snooping multicast_vlan IPTV  replace_source_ipv6 none
config igmp_snooping multicast_vlan IPTV  remap_priority 5 replace_priority
config igmp_snooping multicast_vlan IPTV  source_port_dynamical_learn state disable
config igmp_snooping multicast_vlan IPTV  replace_cvid none
# IGMP snooping
config igmp_snooping all router_timeout 125
config igmp_snooping all host_timeout 260
config igmp_snooping data_driven_learning max_learned_entry 200
disable igmp_snooping forward_mcrouter_only
config igmp_snooping vlanid 1,141 state disable fast_leave disable proxy_reporting state disable report_suppression enable
config igmp_snooping vlanid 1,10,141 proxy_reporting source_ip 0.0.0.0
config igmp_snooping vlanid 10 state enable fast_leave disable proxy_reporting state disable report_suppression disable
config igmp_snooping data_driven_learning vlanid 1,141 state disable
config igmp_snooping data_driven_learning vlanid 1,141 aged_out disable
config igmp_snooping data_driven_learning vlanid 10 state enable
config igmp_snooping data_driven_learning vlanid 10 aged_out enable
config igmp_snooping querier vlanid 1,141 state disable querier_version 2 last_member_query_interval 1 max_response_time 10 query_interval 125 robustness_variable 2
config igmp_snooping querier vlanid 10 state disable querier_version 3 last_member_query_interval 1 max_response_time 10 query_interval 125 robustness_variable 2
config router_ports vlan_name IPTV  add 26
config igmp access_authentication ports 1-28 state disable
Первая проблема:
У клиента постоянно пропадает теряется igmp group, тем самым идет потеря канала в хаотичное время на 1,2 секунды.
Второе:
При выводе команды заметил следующее:
sh igmp_sn host
Command: show igmp_snooping host
VLAN ID Group Port No IGMP Host
10 224.1.1.1 1 192.168.0.1
По логике когда коммутатор получает IGMP запрос от клиента, он заменяет метку клиентского vlan на метку ISM vlan и ip address клиента на свой ip address, но к сожалению на данной модели этого не происходит.
Согласно конфигурации replace_source_ip 172.72.72.72, а как мы видем из команды выше IGMP HOST остается 192.168.0.1
Помогите разобраться...
P.S: Firmware Version 6.10.B005 Hardware Version B2
Порты находятся в Filtering Unregistered Groups.
