Текущее время: Сб сен 26, 2026 16:37
СообщениеДобавлено: Вт ноя 22, 2016 18:12
Не выводит информации по 100 мб оптическим портам.
1. Во такой статус портов при этом порты 1-12 живые и за ними есть активность/трафик:
Command: show ports
 Port      State/          Settings             Connection          Address
           MDIX      Speed/Duplex/FlowCtrl  Speed/Duplex/FlowCtrl   Learning
 1        Enabled   Auto/Disabled          Link Down               Enabled
 2        Enabled   Auto/Disabled          Link Down               Enabled
 3        Enabled   Auto/Disabled          Link Down               Enabled
 4        Enabled   Auto/Disabled          Link Down               Enabled
 5        Enabled   Auto/Disabled          Link Down               Enabled
 6        Enabled   Auto/Disabled          Link Down               Enabled
 7        Enabled   Auto/Disabled          Link Down               Enabled
 8        Enabled   Auto/Disabled          Link Down               Enabled
 9        Enabled   Auto/Disabled          Link Down               Enabled
 10       Enabled   Auto/Disabled          Link Down               Enabled
 11       Enabled   Auto/Disabled          Link Down               Enabled
 12       Enabled   Auto/Disabled          Link Down               Enabled
 13       Enabled   Auto/Disabled          Link Down               Enabled
 14       Enabled   Auto/Disabled          Link Down               Enabled
 15       Enabled   Auto/Disabled          Link Down               Enabled
 16       Enabled   Auto/Disabled          Link Down               Enabled
 17       Enabled   Auto/Disabled          Link Down               Enabled
 18       Enabled   Auto/Disabled          Link Down               Enabled
 19       Enabled   Auto/Disabled          Link Down               Enabled
 20       Enabled   Auto/Disabled          Link Down               Enabled
 21       Enabled   Auto/Disabled          Link Down               Enabled
 22       Enabled   Auto/Disabled          Link Down               Enabled
 23       Enabled   Auto/Disabled          Link Down               Enabled
 24       Enabled   Auto/Disabled          Link Down               Enabled
 25   (C) Enabled   Auto/Disabled          1000M/Full/None         Enabled
          Auto
 25   (F) Disabled  Auto/Disabled          Link Down               Enabled
 26   (C) Enabled   Auto/Disabled          Link Down               Enabled
          Auto
 26   (F) Enabled   Auto/Disabled          Link Down               Enabled
 27   (C) Enabled   Auto/Disabled          Link Down               Enabled
          Auto
 27   (F) Enabled   Auto/Disabled          Link Down               Enabled
 28   (C) Enabled   Auto/Disabled          Link Down               Enabled
          Auto
 28   (F) Enabled   Auto/Disabled          Link Down               Enabled
2. Утилизация портов так-же пустая:
Command: show utilization ports
 Port     TX/sec     RX/sec   Util      Port     TX/sec     RX/sec   Util
 1      0          0          0         21     0          0          0
 2      0          0          0         22     0          0          0
 3      0          0          0         23     0          0          0
 4      0          0          0         24     0          0          0
 5      0          0          0         25     279        193        1
 6      0          0          0         26     0          0          0
 7      0          0          0         27     0          0          0
 8      0          0          0         28     0          0          0
 9      0          0          0
 10     0          0          0
 11     0          0          0
 12     0          0          0
 13     0          0          0
 14     0          0          0
 15     0          0          0
 16     0          0          0
 17     0          0          0
 18     0          0          0
 19     0          0          0
 20     0          0          0
информация по оборудованию:
Device Type                   : DES-3200-28F Fast Ethernet Switch
Boot PROM Version         : Build 4.00.002
Firmware Version           : Build 4.46.B004
Hardware Version           : C1
Все проще чем кажется...
СообщениеДобавлено: Вт ноя 22, 2016 23:36
Это лечится очень просто .
config ports 1-24 speed 100_full
ISP LuxLite
СообщениеДобавлено: Ср ноя 23, 2016 08:39
помогло, спасибо.
можно закрыть тему.
