Текущее время: Сб сен 26, 2026 20:45
 Заголовок сообщения: DES-3028 Conflict IP was detected with this device
СообщениеДобавлено: Пн июн 06, 2016 14:06
Добрый день!
У нас случилась беда со свичем:
S/N: P1CV189040628
Device Type : DES-3028 Fast Ethernet Switch
MAC Address : 00-22-B0-04-61-BF
IP Address : 172.16.15.183 (Manual)
VLAN Name : default
Subnet Mask : 255.255.255.0
Default Gateway : 0.0.0.0
Boot PROM Version : Build 1.00.B06
Firmware Version : Build 2.80.B10
Hardware Version : A1
Логи с самого свича при любом установленном IP адресе:
30613 0000-00-00 00:43:49 Conflict IP was detected with this device (IP: 172.16.
15.183, MAC: 00-22-B0-04-61-BF, Port 6, Interface: Sys
tem)
30612 0000-00-00 00:43:49 Conflict IP was detected with this device (IP: 172.16.
15.183, MAC: 00-22-B0-04-61-BF, Port 1, Interface: Sys
tem)
30611 0000-00-00 00:43:49 Conflict IP was detected with this device (IP: 172.16.
tem)
Логи со смежного свича:
*Nov 21 03:07:34.502: %SW_MATM-4-MACFLAP_NOTIF: Host 8875.5607.79ae in vlan 1202 is flapping between port Gi1/0/3 and port Gi1/0/1
*Nov 21 03:07:34.871: %SW_MATM-4-MACFLAP_NOTIF: Host 000e.08df.6b36 in vlan 1202 is flapping between port Gi1/0/3 and port Gi1/0/2
*Nov 21 03:07:34.904: %SW_MATM-4-MACFLAP_NOTIF: Host 00c0.df0f.0ea5 in vlan 1202 is flapping between port Gi1/0/3 and port Gi1/0/1
*Nov 21 03:07:35.475: %SW_MATM-4-MACFLAP_NOTIF: Host 8875.5607.79b2 in vlan 1202 is flapping between port Gi1/0/3 and port Gi1/0/2
*Nov 21 03:07:35.508: %SW_MATM-4-MACFLAP_NOTIF: Host 000e.08df.6b2e in vlan 1202 is flapping between port Gi1/0/3 and port Gi1/0/1
Дамп при подключении компьютера к любому порту коммутатора:
16:20:49.105589 ARP, Request who-has 172.16.15.183 (Broadcast) tell 172.16.15.183, length 46
16:20:49.105590 ARP, Request who-has 172.16.15.183 (Broadcast) tell 172.16.15.183, length 46
16:20:49.105591 ARP, Request who-has 172.16.15.183 (Broadcast) tell 172.16.15.183, length 46
16:20:49.105592 ARP, Request who-has 172.16.15.183 (Broadcast) tell 172.16.15.183, length 46
16:20:49.105594 ARP, Request who-has 172.16.15.183 (Broadcast) tell 172.16.15.183, length 46
После обновления прошивки через zmodem ситуация не изменилась
VLAN Name : default
Firmware Version : Build 2.94.B12
Свич подключается одним портом, адрес никем более не используется.
Возможно ли исправить ситуацию?
 Заголовок сообщения: Re: DES-3028 Conflict IP was detected with this device
СообщениеДобавлено: Пн июн 06, 2016 16:27
Обратитесь пожалуйста в СЦ, скорее всего неисправность аппаратная.
СообщениеДобавлено: Вт июн 07, 2016 00:35
config ports 1,6 state disable
СообщениеДобавлено: Ср июн 15, 2016 04:39
config loop p 1,6 s e
я так думаю порты сгоревшие и там петля
2008-2015г. компания Экстрим Интернет. Технический директор/Главный системный администратор.
2015-по н.в. компания "Подряд". Инженер сети ШПД
СообщениеДобавлено: Ср июн 15, 2016 11:57
вот поэтому и нужно config ports 1,6 state disable
