Текущее время: Ср сен 30, 2026 18:09
 Заголовок сообщения: DGS-3620-28SC и OSPF
СообщениеДобавлено: Ср окт 30, 2013 16:55
На одном из участков сети в качестве узлов агрегации установлены DELL 6024F
Вот конфиг
spanning-tree mode mstp
interface port-channel 1
spanning-tree disable
exit
description UPLINK
exit
switchport mode trunk
exit
interface range ethernet g(1-20,22,24)
exit
vlan database
vlan 2,101-122,135,200
exit
interface range port-channel 1
switchport trunk native vlan 2
exit
interface ethernet g24
switchport trunk allowed vlan add 2
exit
interface ethernet g1
switchport trunk native vlan 101
exit
switchport trunk native vlan 102
exit
interface ethernet g3
switchport trunk native vlan 103
exit
interface ethernet g4
switchport trunk native vlan 104
exit
interface ethernet g5
switchport trunk native vlan 105
exit
interface ethernet g6
switchport trunk native vlan 106
exit
interface ethernet g7
switchport trunk native vlan 107
exit
interface ethernet g8
switchport trunk native vlan 108
exit
interface ethernet g9
switchport trunk native vlan 109
exit
interface ethernet g10
switchport trunk native vlan 110
exit
interface ethernet g11
switchport trunk native vlan 111
exit
interface ethernet g12
switchport trunk native vlan 112
exit
interface ethernet g13
switchport trunk native vlan 113
exit
interface ethernet g14
switchport trunk native vlan 114
exit
interface ethernet g15
switchport trunk native vlan 115
exit
interface ethernet g16
switchport trunk native vlan 116
exit
interface ethernet g17
switchport trunk native vlan 117
exit
interface ethernet g18
switchport trunk native vlan 118
exit
interface ethernet g19
switchport trunk native vlan 119
exit
interface ethernet g20
switchport trunk native vlan 120
exit
interface ethernet g22
switchport trunk native vlan 122
exit
interface range ethernet g(1-20,22)
switchport trunk allowed vlan add 135
exit
switchport trunk allowed vlan add 200
exit
interface vlan 2
name Servers
exit
interface vlan 135
name mgmt
exit
interface vlan 200
name Office
exit
interface range ethernet g(21,23)
channel-group 1 mode auto
exit
no negotiation
exit
interface ethernet g23
negotiation 1000f
exit
interface vlan 2
ip address 10.0.0.35 255.255.255.0
exit
interface vlan 101
ip address 10.20.25.1 255.255.255.0
exit
interface vlan 102
ip address 10.20.2.1 255.255.255.0
exit
interface vlan 103
ip address 10.20.3.1 255.255.255.0
exit
interface vlan 104
ip address 10.20.4.1 255.255.255.0
exit
interface vlan 105
ip address 10.20.5.1 255.255.255.0
exit
interface vlan 106
ip address 10.20.6.1 255.255.255.0
exit
interface vlan 107
ip address 10.20.7.1 255.255.255.0
exit
interface vlan 108
ip address 10.20.8.1 255.255.255.0
exit
interface vlan 109
ip address 10.20.9.1 255.255.255.0
exit
interface vlan 110
ip address 10.20.10.1 255.255.255.0
exit
interface vlan 111
ip address 10.20.11.1 255.255.255.0
exit
interface vlan 112
ip address 10.20.12.1 255.255.255.0
exit
interface vlan 113
ip address 10.20.13.1 255.255.255.0
exit
interface vlan 114
ip address 10.20.14.1 255.255.255.0
exit
interface vlan 115
ip address 10.20.15.1 255.255.255.0
exit
interface vlan 116
ip address 10.20.16.1 255.255.255.0
exit
interface vlan 117
ip address 10.20.17.1 255.255.255.0
exit
interface vlan 118
ip address 10.20.18.1 255.255.255.0
exit
interface vlan 119
ip address 10.20.19.1 255.255.255.0
exit
interface vlan 120
ip address 10.20.20.1 255.255.255.0
exit
interface vlan 121
ip address 10.20.21.1 255.255.255.0
exit
interface vlan 122
ip address 10.20.22.1 255.255.255.0
exit
interface vlan 135
ip address 10.20.235.1 255.255.255.0
exit
interface vlan 200
ip address 10.1.1.1 255.255.255.0
exit
ip route 0.0.0.0 0.0.0.0 10.0.0.34
router ospf enable
router ospf redistribute connected
router ospf router-id 10.0.0.35
interface ip 10.0.0.35
ospf
exit
Будем менять оборудование на DGS-3620-28SC и DGS-3120-24SC
Общая настройка понятна, кроме одного момента, как на DGS правильно реализовать вот эти строки кода:
router ospf enable
ospf
Экспериментировать на живо, навряд ли получится. Можете подсказать как этот кусок конфига должен выглядеть на D-Link
 Заголовок сообщения: Re: DGS-3620-28SC и OSPF
СообщениеДобавлено: Пт ноя 01, 2013 12:53
С Dell не сталкивался, но на DGS-3620-28SC будет как-то так (Firmware: Build 2.60.B017):
enable ospf
config ospf router_id 10.0.0.35
config ospf ipif Servers area <x.x.x.x> priority <> hello_interval <> dead_interval <>
config ospf ipif Servers authentication <> metric <> state enable passive disable
Про перераспределение маршрутов сказать ничего не могу, нужно больше информации.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 106
