Текущее время: Ср сен 30, 2026 19:12
 Заголовок сообщения: DES3526 igmp snooping router ports
СообщениеДобавлено: Пт июл 26, 2013 12:03
Здравствуйте, на коммутаторе DES3526 c версией прошивки 6.20.B18 и конфигом
# DES-3526 Configuration
# Firmware: Build 6.20.B18
# Copyright(C) 2011 D-Link Corporation. All rights reserved.
# BASIC
config serial_port baud_rate 9600 auto_logout 10_minutes
enable telnet 23
enable web 80
config terminal_line default
enable clipaging
debug error_log auto_reboot enabled
disable broadcast_ping_reply
# ACCOUNT LIST
# PASSWORD ENCRYPTION
disable password encryption
# COMMAND LOGGING
disable command logging
# PASSWORD RECOVERY
enable password_recovery
# BNR
config command_prompt default
# STORM
config traffic control_trap none
config traffic control 1-5 broadcast disable multicast disable unicast disable action drop threshold 128000
# GM
config sim candidate
disable sim
config sim dp_interval 30
config sim hold_time 100
# SYSLOG
disable syslog
config system_severity trap information
config system_severity log information
# QOS
config scheduling 0 max_packet 0 max_latency 0
config scheduling 1 max_packet 0 max_latency 0
config scheduling 2 max_packet 0 max_latency 0
config scheduling 3 max_packet 0 max_latency 0
config 802.1p user_priority 0 1
config 802.1p user_priority 1 0
config 802.1p user_priority 2 0
config 802.1p user_priority 3 1
config 802.1p user_priority 4 2
config 802.1p user_priority 5 2
config 802.1p user_priority 6 3
config 802.1p user_priority 7 3
config 802.1p default_priority 1-26 0
config bandwidth_control 1-26 rx_rate no_limit tx_rate no_limit
# MIRROR
disable mirror
# TRAF-SEGMENTATION
config traffic_segmentation 1-26 forward_list 1-26
# PORT
config ports 1-24 speed auto flow_control disable mdix auto learning enable state enable trap enable
config ports 25-26 medium_type copper speed auto flow_control disable mdix auto learning enable state enable trap enable
config ports 25-26 medium_type fiber speed auto flow_control disable learning enable state enable trap enable
# DDM
config ddm trap disable
config ddm log enable
config ddm ports 25-26 state enable
config ddm ports 25-26 shutdown none
# PORT_LOCK
disable port_security trap_log
config port_security ports 1-26 admin_state disable max_learning_addr 1 lock_address_mode DeleteOnReset
# 8021X
disable 802.1x
config 802.1x auth_protocol radius_eap
config radius add 1 10.90.90.100 key mysecretkey auth_port 1812 acct_port 1813
config radius parameter timeout 5 retransmit 1
config 802.1x capability ports 1-26 none
config 802.1x auth_parameter ports 1-26 direction both port_control auto quiet_period 60 tx_period 30 supp_timeout 30 server_timeout 30 max_req 2 reauth_period 3600 enable_reauth disable
# SNMPv3
delete snmp community public
delete snmp community private
delete snmp user initial
delete snmp group initial
delete snmp group ReadGroup
delete snmp group WriteGroup
delete snmp view restricted all
delete snmp view CommunityView all
config snmp engineID 8000000003001bffb8d600
create snmp view restricted 1.3.6.1.2.1.1 view_type included
create snmp view restricted 1.3.6.1.2.1.11 view_type included
create snmp view restricted 1.3.6.1.6.3.10.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.11.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.15.1.1 view_type included
create snmp view CommunityView 1 view_type included
create snmp view CommunityView 1.3.6.1.6.3 view_type excluded
create snmp view CommunityView 1.3.6.1.6.3.1 view_type included
create snmp group public v1 read_view CommunityView notify_view CommunityView
create snmp group public v2c read_view CommunityView notify_view CommunityView
create snmp group initial v3 noauth_nopriv read_view restricted notify_view restricted
create snmp group private v1 read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group private v2c read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group ReadGroup v1 read_view CommunityView notify_view CommunityView
create snmp group ReadGroup v2c read_view CommunityView notify_view CommunityView
create snmp group WriteGroup v1 read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group WriteGroup v2c read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp community private view CommunityView read_write
create snmp community public view CommunityView read_only
create snmp user initial initial
config snmp coldstart_traps enable
config snmp warmstart_traps enable
enable snmp linkchange traps
# Firm
config configuration trap save disable
config configuration trap upload disable
config configuration trap download disable
# MANAGEMENT
enable snmp traps
enable snmp authenticate traps
config snmp system_name D-Link
disable rmon
# VLAN
disable asymmetric_vlan
config vlan default delete 1-24
config vlan default advertisement enable
create vlan vlan227 tag 227
config vlan vlan227 add tagged 25-26
config vlan vlan227 add untagged 1-24
config vlan vlan227 advertisement disable
disable gvrp
config gvrp 1-24 state disable ingress_checking enable acceptable_frame admit_all pvid 227
config gvrp 25-26 state disable ingress_checking enable acceptable_frame admit_all pvid 1
# FDB
config fdb aging_time 300
config multicast port_filtering_mode 1-26 filter_unregistered_groups
# LOOP_DETECT
disable loopdetect
config loopdetect recover_timer 60
config loopdetect interval 10
config loopdetect mode port-based
config loopdetect ports 1-26 state disabled
# MAC_ADDRESS_TABLE_NOTIFICATION
config mac_notification interval 1 historysize 1
disable mac_notification
config mac_notification ports 1-26 disable
# STP
config stp version rstp
config stp maxage 20 maxhops 20 forwarddelay 15 txholdcount 6 fbpdu enable
config stp priority 32768 instance_id 0
config stp hellotime 2
config stp mst_config_id name 00:1B:11:B8:D6:E4 revision_level 0
config stp trap new_root enable topo_change enable
config stp ports 1-26 state enable
disable stp
config stp ports 1-26 externalCost auto edge false p2p auto
config stp ports 1-26 fbpdu disable
config stp ports 1-26 restricted_role false
config stp ports 1-26 restricted_tcn false
config stp mst_ports 1-26 instance_id 0 internalCost auto priority 128
# MULTI FILTER
config max_mcast_group vlanid 1,227 action drop
config max_mcast_group vlanid 1,227 max_group infinite
config max_mcast_group ports 1-26 action drop
config max_mcast_group ports 1-26 max_group infinite
# SSH
config ssh server maxsession 8
config ssh server contimeout 300
config ssh server authfail 2
config ssh server rekey never
config ssh server port 22
disable ssh
# SSL
disable ssl
enable ssl ciphersuite RSA_with_RC4_128_MD5
enable ssl ciphersuite RSA_with_3DES_EDE_CBC_SHA
enable ssl ciphersuite DHE_DSS_with_3DES_EDE_CBC_SHA
enable ssl ciphersuite RSA_EXPORT_with_RC4_40_MD5
config ssl cachetimeout timeout 600
# DNS_RESOLVER
enable dns_resolver
config name_server timeout 3
# SAFE_GUARD
config safeguard_engine state disable cpu_utilization rising_threshold 100 falling_threshold 20 trap_log disable
# TIMERANGE
# security_ACL
create access_profile ethernet ethernet_type profile_id 254
config access_profile profile_id 254 add access_id 1 ethernet ethernet_type 0x800 port 1 permit
config access_profile profile_id 254 add access_id 2 ethernet ethernet_type 0x800 port 2 permit
config access_profile profile_id 254 add access_id 3 ethernet ethernet_type 0x800 port 3 permit
config access_profile profile_id 254 add access_id 4 ethernet ethernet_type 0x800 port 4 permit
config access_profile profile_id 254 add access_id 5 ethernet ethernet_type 0x800 port 5 permit
config access_profile profile_id 254 add access_id 6 ethernet ethernet_type 0x800 port 6 permit
config access_profile profile_id 254 add access_id 7 ethernet ethernet_type 0x800 port 7 permit
config access_profile profile_id 254 add access_id 8 ethernet ethernet_type 0x800 port 8 permit
config access_profile profile_id 254 add access_id 9 ethernet ethernet_type 0x800 port 9 permit
config access_profile profile_id 254 add access_id 10 ethernet ethernet_type 0x800 port 10 permit
config access_profile profile_id 254 add access_id 11 ethernet ethernet_type 0x800 port 11 permit
config access_profile profile_id 254 add access_id 12 ethernet ethernet_type 0x800 port 12 permit
config access_profile profile_id 254 add access_id 13 ethernet ethernet_type 0x800 port 13 permit
config access_profile profile_id 254 add access_id 14 ethernet ethernet_type 0x800 port 14 permit
config access_profile profile_id 254 add access_id 15 ethernet ethernet_type 0x800 port 15 permit
config access_profile profile_id 254 add access_id 16 ethernet ethernet_type 0x800 port 16 permit
config access_profile profile_id 254 add access_id 17 ethernet ethernet_type 0x800 port 17 permit
config access_profile profile_id 254 add access_id 18 ethernet ethernet_type 0x800 port 18 permit
config access_profile profile_id 254 add access_id 19 ethernet ethernet_type 0x800 port 19 permit
config access_profile profile_id 254 add access_id 20 ethernet ethernet_type 0x800 port 20 permit
config access_profile profile_id 254 add access_id 21 ethernet ethernet_type 0x800 port 21 permit
config access_profile profile_id 254 add access_id 22 ethernet ethernet_type 0x800 port 22 permit
config access_profile profile_id 254 add access_id 23 ethernet ethernet_type 0x800 port 23 permit
config access_profile profile_id 254 add access_id 24 ethernet ethernet_type 0x800 port 24 permit
config access_profile profile_id 254 add access_id 25 ethernet ethernet_type 0x806 port 1 permit
config access_profile profile_id 254 add access_id 26 ethernet ethernet_type 0x806 port 2 permit
config access_profile profile_id 254 add access_id 27 ethernet ethernet_type 0x806 port 3 permit
config access_profile profile_id 254 add access_id 28 ethernet ethernet_type 0x806 port 4 permit
config access_profile profile_id 254 add access_id 29 ethernet ethernet_type 0x806 port 5 permit
config access_profile profile_id 254 add access_id 30 ethernet ethernet_type 0x806 port 6 permit
config access_profile profile_id 254 add access_id 31 ethernet ethernet_type 0x806 port 7 permit
config access_profile profile_id 254 add access_id 32 ethernet ethernet_type 0x806 port 8 permit
config access_profile profile_id 254 add access_id 33 ethernet ethernet_type 0x806 port 9 permit
config access_profile profile_id 254 add access_id 34 ethernet ethernet_type 0x806 port 10 permit
config access_profile profile_id 254 add access_id 35 ethernet ethernet_type 0x806 port 11 permit
config access_profile profile_id 254 add access_id 36 ethernet ethernet_type 0x806 port 12 permit
config access_profile profile_id 254 add access_id 37 ethernet ethernet_type 0x806 port 13 permit
config access_profile profile_id 254 add access_id 38 ethernet ethernet_type 0x806 port 14 permit
config access_profile profile_id 254 add access_id 39 ethernet ethernet_type 0x806 port 15 permit
config access_profile profile_id 254 add access_id 40 ethernet ethernet_type 0x806 port 16 permit
config access_profile profile_id 254 add access_id 41 ethernet ethernet_type 0x806 port 17 permit
config access_profile profile_id 254 add access_id 42 ethernet ethernet_type 0x806 port 18 permit
config access_profile profile_id 254 add access_id 43 ethernet ethernet_type 0x806 port 19 permit
config access_profile profile_id 254 add access_id 44 ethernet ethernet_type 0x806 port 20 permit
config access_profile profile_id 254 add access_id 45 ethernet ethernet_type 0x806 port 21 permit
config access_profile profile_id 254 add access_id 46 ethernet ethernet_type 0x806 port 22 permit
config access_profile profile_id 254 add access_id 47 ethernet ethernet_type 0x806 port 23 permit
config access_profile profile_id 254 add access_id 48 ethernet ethernet_type 0x806 port 24 permit
config access_profile profile_id 254 add access_id 49 ethernet ethernet_type 0x8683 port 1 permit
config access_profile profile_id 254 add access_id 50 ethernet ethernet_type 0x8683 port 2 permit
config access_profile profile_id 254 add access_id 51 ethernet ethernet_type 0x8683 port 3 permit
config access_profile profile_id 254 add access_id 52 ethernet ethernet_type 0x8683 port 4 permit
config access_profile profile_id 254 add access_id 53 ethernet ethernet_type 0x8683 port 5 permit
config access_profile profile_id 254 add access_id 54 ethernet ethernet_type 0x8683 port 6 permit
config access_profile profile_id 254 add access_id 55 ethernet ethernet_type 0x8683 port 7 permit
config access_profile profile_id 254 add access_id 56 ethernet ethernet_type 0x8683 port 8 permit
config access_profile profile_id 254 add access_id 57 ethernet ethernet_type 0x8683 port 9 permit
config access_profile profile_id 254 add access_id 58 ethernet ethernet_type 0x8683 port 10 permit
config access_profile profile_id 254 add access_id 59 ethernet ethernet_type 0x8683 port 11 permit
config access_profile profile_id 254 add access_id 60 ethernet ethernet_type 0x8683 port 12 permit
config access_profile profile_id 254 add access_id 61 ethernet ethernet_type 0x8683 port 13 permit
config access_profile profile_id 254 add access_id 62 ethernet ethernet_type 0x8683 port 14 permit
config access_profile profile_id 254 add access_id 63 ethernet ethernet_type 0x8683 port 15 permit
config access_profile profile_id 254 add access_id 64 ethernet ethernet_type 0x8683 port 16 permit
config access_profile profile_id 254 add access_id 65 ethernet ethernet_type 0x8683 port 17 permit
config access_profile profile_id 254 add access_id 66 ethernet ethernet_type 0x8683 port 18 permit
config access_profile profile_id 254 add access_id 67 ethernet ethernet_type 0x8683 port 19 permit
config access_profile profile_id 254 add access_id 68 ethernet ethernet_type 0x8683 port 20 permit
config access_profile profile_id 254 add access_id 69 ethernet ethernet_type 0x8683 port 21 permit
config access_profile profile_id 254 add access_id 70 ethernet ethernet_type 0x8683 port 22 permit
config access_profile profile_id 254 add access_id 71 ethernet ethernet_type 0x8683 port 23 permit
config access_profile profile_id 254 add access_id 72 ethernet ethernet_type 0x8683 port 24 permit
config access_profile profile_id 254 add access_id 73 ethernet ethernet_type 0x8684 port 1 permit
config access_profile profile_id 254 add access_id 74 ethernet ethernet_type 0x8684 port 2 permit
config access_profile profile_id 254 add access_id 75 ethernet ethernet_type 0x8684 port 3 permit
config access_profile profile_id 254 add access_id 76 ethernet ethernet_type 0x8684 port 4 permit
config access_profile profile_id 254 add access_id 77 ethernet ethernet_type 0x8684 port 5 permit
config access_profile profile_id 254 add access_id 78 ethernet ethernet_type 0x8684 port 6 permit
config access_profile profile_id 254 add access_id 79 ethernet ethernet_type 0x8684 port 7 permit
config access_profile profile_id 254 add access_id 80 ethernet ethernet_type 0x8684 port 8 permit
config access_profile profile_id 254 add access_id 81 ethernet ethernet_type 0x8684 port 9 permit
config access_profile profile_id 254 add access_id 82 ethernet ethernet_type 0x8684 port 10 permit
config access_profile profile_id 254 add access_id 83 ethernet ethernet_type 0x8684 port 11 permit
config access_profile profile_id 254 add access_id 84 ethernet ethernet_type 0x8684 port 12 permit
config access_profile profile_id 254 add access_id 85 ethernet ethernet_type 0x8684 port 13 permit
config access_profile profile_id 254 add access_id 86 ethernet ethernet_type 0x8684 port 14 permit
config access_profile profile_id 254 add access_id 87 ethernet ethernet_type 0x8684 port 15 permit
config access_profile profile_id 254 add access_id 88 ethernet ethernet_type 0x8684 port 16 permit
config access_profile profile_id 254 add access_id 89 ethernet ethernet_type 0x8684 port 17 permit
config access_profile profile_id 254 add access_id 90 ethernet ethernet_type 0x8684 port 18 permit
config access_profile profile_id 254 add access_id 91 ethernet ethernet_type 0x8684 port 19 permit
config access_profile profile_id 254 add access_id 92 ethernet ethernet_type 0x8684 port 20 permit
config access_profile profile_id 254 add access_id 93 ethernet ethernet_type 0x8684 port 21 permit
config access_profile profile_id 254 add access_id 94 ethernet ethernet_type 0x8684 port 22 permit
config access_profile profile_id 254 add access_id 95 ethernet ethernet_type 0x8684 port 23 permit
config access_profile profile_id 254 add access_id 96 ethernet ethernet_type 0x8684 port 24 permit
config access_profile profile_id 254 add access_id 97 ethernet ethernet_type 0x8863 port 1 permit
config access_profile profile_id 254 add access_id 98 ethernet ethernet_type 0x8863 port 2 permit
config access_profile profile_id 254 add access_id 99 ethernet ethernet_type 0x8863 port 3 permit
config access_profile profile_id 254 add access_id 100 ethernet ethernet_type 0x8863 port 4 permit
config access_profile profile_id 254 add access_id 101 ethernet ethernet_type 0x8863 port 5 permit
config access_profile profile_id 254 add access_id 102 ethernet ethernet_type 0x8863 port 6 permit
config access_profile profile_id 254 add access_id 103 ethernet ethernet_type 0x8863 port 7 permit
config access_profile profile_id 254 add access_id 104 ethernet ethernet_type 0x8863 port 8 permit
config access_profile profile_id 254 add access_id 105 ethernet ethernet_type 0x8863 port 9 permit
config access_profile profile_id 254 add access_id 106 ethernet ethernet_type 0x8863 port 10 permit
config access_profile profile_id 254 add access_id 107 ethernet ethernet_type 0x8863 port 11 permit
config access_profile profile_id 254 add access_id 108 ethernet ethernet_type 0x8863 port 12 permit
config access_profile profile_id 254 add access_id 109 ethernet ethernet_type 0x8863 port 13 permit
config access_profile profile_id 254 add access_id 110 ethernet ethernet_type 0x8863 port 14 permit
config access_profile profile_id 254 add access_id 111 ethernet ethernet_type 0x8863 port 15 permit
config access_profile profile_id 254 add access_id 112 ethernet ethernet_type 0x8863 port 16 permit
config access_profile profile_id 254 add access_id 113 ethernet ethernet_type 0x8863 port 17 permit
config access_profile profile_id 254 add access_id 114 ethernet ethernet_type 0x8863 port 18 permit
config access_profile profile_id 254 add access_id 115 ethernet ethernet_type 0x8863 port 19 permit
config access_profile profile_id 254 add access_id 116 ethernet ethernet_type 0x8863 port 20 permit
config access_profile profile_id 254 add access_id 117 ethernet ethernet_type 0x8863 port 21 permit
config access_profile profile_id 254 add access_id 118 ethernet ethernet_type 0x8863 port 22 permit
config access_profile profile_id 254 add access_id 119 ethernet ethernet_type 0x8863 port 23 permit
config access_profile profile_id 254 add access_id 120 ethernet ethernet_type 0x8863 port 24 permit
config access_profile profile_id 254 add access_id 121 ethernet ethernet_type 0x8864 port 1 permit
config access_profile profile_id 254 add access_id 122 ethernet ethernet_type 0x8864 port 2 permit
config access_profile profile_id 254 add access_id 123 ethernet ethernet_type 0x8864 port 3 permit
config access_profile profile_id 254 add access_id 124 ethernet ethernet_type 0x8864 port 4 permit
config access_profile profile_id 254 add access_id 125 ethernet ethernet_type 0x8864 port 5 permit
config access_profile profile_id 254 add access_id 126 ethernet ethernet_type 0x8864 port 6 permit
config access_profile profile_id 254 add access_id 127 ethernet ethernet_type 0x8864 port 7 permit
config access_profile profile_id 254 add access_id 128 ethernet ethernet_type 0x8864 port 8 permit
config access_profile profile_id 254 add access_id 129 ethernet ethernet_type 0x8864 port 9 permit
config access_profile profile_id 254 add access_id 130 ethernet ethernet_type 0x8864 port 10 permit
config access_profile profile_id 254 add access_id 131 ethernet ethernet_type 0x8864 port 11 permit
config access_profile profile_id 254 add access_id 132 ethernet ethernet_type 0x8864 port 12 permit
config access_profile profile_id 254 add access_id 133 ethernet ethernet_type 0x8864 port 13 permit
config access_profile profile_id 254 add access_id 134 ethernet ethernet_type 0x8864 port 14 permit
config access_profile profile_id 254 add access_id 135 ethernet ethernet_type 0x8864 port 15 permit
config access_profile profile_id 254 add access_id 136 ethernet ethernet_type 0x8864 port 16 permit
config access_profile profile_id 254 add access_id 137 ethernet ethernet_type 0x8864 port 17 permit
config access_profile profile_id 254 add access_id 138 ethernet ethernet_type 0x8864 port 18 permit
config access_profile profile_id 254 add access_id 139 ethernet ethernet_type 0x8864 port 19 permit
config access_profile profile_id 254 add access_id 140 ethernet ethernet_type 0x8864 port 20 permit
config access_profile profile_id 254 add access_id 141 ethernet ethernet_type 0x8864 port 21 permit
config access_profile profile_id 254 add access_id 142 ethernet ethernet_type 0x8864 port 22 permit
config access_profile profile_id 254 add access_id 143 ethernet ethernet_type 0x8864 port 23 permit
config access_profile profile_id 254 add access_id 144 ethernet ethernet_type 0x8864 port 24 permit
create access_profile ethernet source_mac 00-00-00-00-00-00 profile_id 255
config access_profile profile_id 255 add access_id 1 ethernet source_mac 00-00-00-00-00-00 port 1 deny
config access_profile profile_id 255 add access_id 2 ethernet source_mac 00-00-00-00-00-00 port 2 deny
config access_profile profile_id 255 add access_id 3 ethernet source_mac 00-00-00-00-00-00 port 3 deny
config access_profile profile_id 255 add access_id 4 ethernet source_mac 00-00-00-00-00-00 port 4 deny
config access_profile profile_id 255 add access_id 5 ethernet source_mac 00-00-00-00-00-00 port 5 deny
config access_profile profile_id 255 add access_id 6 ethernet source_mac 00-00-00-00-00-00 port 6 deny
config access_profile profile_id 255 add access_id 7 ethernet source_mac 00-00-00-00-00-00 port 7 deny
config access_profile profile_id 255 add access_id 8 ethernet source_mac 00-00-00-00-00-00 port 8 deny
config access_profile profile_id 255 add access_id 9 ethernet source_mac 00-00-00-00-00-00 port 9 deny
config access_profile profile_id 255 add access_id 10 ethernet source_mac 00-00-00-00-00-00 port 10 deny
config access_profile profile_id 255 add access_id 11 ethernet source_mac 00-00-00-00-00-00 port 11 deny
config access_profile profile_id 255 add access_id 12 ethernet source_mac 00-00-00-00-00-00 port 12 deny
config access_profile profile_id 255 add access_id 13 ethernet source_mac 00-00-00-00-00-00 port 13 deny
config access_profile profile_id 255 add access_id 14 ethernet source_mac 00-00-00-00-00-00 port 14 deny
config access_profile profile_id 255 add access_id 15 ethernet source_mac 00-00-00-00-00-00 port 15 deny
config access_profile profile_id 255 add access_id 16 ethernet source_mac 00-00-00-00-00-00 port 16 deny
config access_profile profile_id 255 add access_id 17 ethernet source_mac 00-00-00-00-00-00 port 17 deny
config access_profile profile_id 255 add access_id 18 ethernet source_mac 00-00-00-00-00-00 port 18 deny
config access_profile profile_id 255 add access_id 19 ethernet source_mac 00-00-00-00-00-00 port 19 deny
config access_profile profile_id 255 add access_id 20 ethernet source_mac 00-00-00-00-00-00 port 20 deny
config access_profile profile_id 255 add access_id 21 ethernet source_mac 00-00-00-00-00-00 port 21 deny
config access_profile profile_id 255 add access_id 22 ethernet source_mac 00-00-00-00-00-00 port 22 deny
config access_profile profile_id 255 add access_id 23 ethernet source_mac 00-00-00-00-00-00 port 23 deny
config access_profile profile_id 255 add access_id 24 ethernet source_mac 00-00-00-00-00-00 port 24 deny
disable address_binding acl_mode
disable address_binding dhcp_snoop
disable dhcp_relay
disable dhcp_local_relay
config pppoe circuit_id_insertion state disable
disable address_binding arp_inspection
# ACL
disable cpu_interface_filtering
# SNTP
disable sntp
config time_zone operator - hour 6 min 0
config sntp primary 0.0.0.0 secondary 0.0.0.0 poll-interval 720
config dst disable
# IPBIND
disable address_binding trap_log
config address_binding dhcp_snoop max_entry ports 1-26 limit 5
# FILTER
# PPPoE_Circuit_ID_Insertion
config pppoe circuit_id_insertion ports 1-26 state enable circuit_id ip
# ROUTE
create iproute default 10.90.90.90 1
# SNOOP
enable igmp_snooping
create igmp_snooping multicast_vlan mvr 24
config igmp_snooping multicast_vlan mvr state enable replace_source_ip 0.0.0.0 member_port 1-24 source_port 25-26
config igmp_snooping mvr host_timeout 260 router_timeout 260 leave_timer 2 state enable
config igmp_snooping querier mvr query_interval 125 max_response_time 10 robustness_variable 2
config igmp_snooping querier mvr last_member_query_interval 1 state disable
config router_ports mvr add 25-26
config router_ports_forbidden mvr add 1-24
create multicast_range system from 224.0.0.1 to 224.0.0.2
create multicast_range iptv from 224.5.5.0 to 224.5.5.255
create multicast_range iptv1 from 224.5.1.0 to 224.5.1.255
create multicast_range iptv2 from 224.5.2.0 to 224.5.2.255
create multicast_range iptv3 from 224.5.3.0 to 224.5.3.255
create multicast_range iptv4 from 224.5.4.0 to 224.5.4.255
create multicast_range iptv5 from 224.5.5.0 to 224.5.5.255
create multicast_range itv5 from 224.5.5.0 to 224.5.5.255
config limited_multicast_addr ports 1-24 add multicast_range system
config limited_multicast_addr ports 1-24 add multicast_range iptv
config limited_multicast_addr ports 1-24 add multicast_range iptv1
config limited_multicast_addr ports 1-24 add multicast_range iptv2
config limited_multicast_addr ports 1-24 add multicast_range iptv3
config limited_multicast_addr ports 1-24 add multicast_range iptv4
config limited_multicast_addr ports 1-24 add multicast_range iptv5
config limited_multicast_addr ports 1-24 access permit state disable
config limited_multicast_addr ports 25-26 access deny state disable
config igmp access_authentication ports 1-24 state enable
config igmp access_authentication ports 25-26 state disable
# LACP
config link_aggregation algorithm mac_source
config lacp_port 1-26 mode passive
# GVLAN
# IP
config ipif System vlan default ipaddress 10.90.90.91/24 state enable
disable autoconfig
config autoconfig timeout 50
config ipif System dhcp_option12 state disable
# ARP
config arp_aging time 1200
config gratuitous_arp send ipif_status_up enable
config gratuitous_arp send dup_ip_detected enable
config gratuitous_arp learning enable
# LLDP
disable lldp
config lldp message_tx_interval 30
config lldp tx_delay 2
config lldp message_tx_hold_multiplier 4
config lldp reinit_delay 2
config lldp notification_interval 5
config lldp ports 1-26 notification disable
config lldp ports 1-26 admin_status tx_and_rx
# ACCESS_AUTHENTICATION_CONTROL
config authen_login default method local
config authen_enable default method local_enable
config authen application console login default
config authen application console enable default
config authen application telnet login default
config authen application telnet enable default
config authen application ssh login default
config authen application ssh enable default
config authen application http login default
config authen application http enable default
config authen parameter response_timeout 0
config authen parameter attempt 3
config authen enable_admin all state enable
config authen enable_operator all state enable
disable authen_policy
config admin local_enable
config operator local_enable
# DHCP_RELAY
config dhcp_relay hops 4 time 0
config dhcp_relay option_82 state disable
config dhcp_relay option_82 check disable
config dhcp_relay option_82 policy replace
config dhcp_relay option_82 remote_id default
config dhcp_relay option_60 state disable
config dhcp_relay option_60 default mode drop
config dhcp_relay option_61 state disable
config dhcp_relay option_61 default drop
# DHCP_LOCAL_RELAY
config dhcp_local_relay option_82 remote_id default
config dhcp_local_relay option_82 ports 1-26 policy keep
# End of configuration file for DES-3526
25 и 26 порт в Multicast VLAN настроены как source port. 25 приход, в 26 порту находится DES3200-10.
Наблюдается следующее.
При включение IPTV на DES3526 c 1 порта, мультикаст поток начинает форвардится на 25 и 26 порт. В итоге на приходящий порт DES3200-10 льется тот же поток.
show igmp_snooping forwarding с DES3526
VLAN Name : mvr
Multicast group : 224.5.2.123
MAC address : 01-00-5E-05-02-7B
Port Member : 1,25-26
Total Entries : 1
show router_ports на DES3526
VLAN Name : mvr
Static router port : 25-26
Dynamic router port :
Forbidden router port: 1-24
на DES3200-10 видим:
DES-3200-10:5#show igmp_snooping group
Source/Group : NULL/224.5.2.123
VLAN Name/VID : IPTV/24
Reports : 26
Member Ports : 9
Router Ports : 9
Up time : 2737
Expire Time : 241
Filter Mode : EXCLUDE
Total Entries : 1
В предыдущих версиях такого поведения не наблюдалось и 25 порт был в динамике, Установить 26 в router_ports_forbidden невозможно.
В DES3200 версиях есть установка портов в tagged memeber ports, что устраняет данную неисправность.
Как быть с DES3526?
 Заголовок сообщения: Re: DES3526 igmp snooping router ports
СообщениеДобавлено: Пт июл 26, 2013 13:20
Таково поведение 6.20 прошивок и штаю-квартира не планирует его менять.
Такой особенности не было в R6.0, ее и можно использовать.
СообщениеДобавлено: Пт июл 26, 2013 13:32
да но в R.6 нет igmp access_authentication который используется, это что выходит что штаб выпустил кривую прошивку. Ведь если допустим с 23 и 24 портов будут включены устройства и они настроены как source в Multicast Vlan-e, то на них всех польется мультикаст. Разве это правильное поведение?
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 83
