Текущее время: Чт окт 01, 2026 01:14
СообщениеДобавлено: Ср апр 17, 2013 12:37
Здравствуйте имеем несколько свитчей DGS-3120
На всех свитчах установлена прошивка:
Boot PROM Version : Build 2.00.003
Firmware Version : Build 2.50.B032
Hardware Version : A2
Все наши DGS-3120 стали массово слать Topology changed для протокола MSTP.
16896 2013-04-15 14:07:49 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
-D7-48-06-3B-80)
16895 2013-04-15 14:07:47 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
-D7-48-06-3B-80)
16894 2013-04-15 14:07:45 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
-D7-48-06-3B-80)
16893 2013-04-15 14:07:43 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
-D7-48-06-3B-80)
16892 2013-04-15 14:07:41 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
10.232.5.78 3120
15630 2013-04-15 14:09:11 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
-D7-48-06-3B-80)
15629 2013-04-15 14:09:10 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
-D7-48-06-3B-80)
15628 2013-04-15 14:09:07 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
-D7-48-06-3B-80)
15627 2013-04-15 14:09:05 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
-D7-48-06-3B-80)
15626 2013-04-15 14:09:03 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
-D7-48-06-3B-80)
15625 2013-04-15 14:09:01 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
-D7-48-06-3B-80)
15624 2013-04-15 14:08:59 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
10.232.5.91 3120
57799 2013-04-15 13:11:52 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
-D7-48-06-3B-80)
57798 2013-04-15 13:11:51 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
-D7-48-06-3B-80)
57797 2013-04-15 13:11:48 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
-D7-48-06-3B-80)
57796 2013-04-15 13:11:47 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
-D7-48-06-3B-80)
57795 2013-04-15 13:11:44 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
10.232.5.209 3120
22865 2013-04-15 14:13:54 NOTI(5) Topology changed (Instance:0, Port:1:47,MAC:D4
-D7-48-06-3B-80)
22864 2013-04-15 14:13:53 NOTI(5) Topology changed (Instance:0, Port:1:47,MAC:D4
-D7-48-06-3B-80)
22863 2013-04-15 14:13:50 NOTI(5) Topology changed (Instance:0, Port:1:47,MAC:D4
-D7-48-06-3B-80)
22862 2013-04-15 14:13:49 NOTI(5) Topology changed (Instance:0, Port:1:47,MAC:D4
-D7-48-06-3B-80)
22861 2013-04-15 14:13:46 NOTI(5) Topology changed (Instance:0, Port:1:47,MAC:D4
-D7-48-06-3B-80)
22860 2013-04-15 14:13:45 NOTI(5) Topology changed (Instance:0, Port:1:47,MAC:D4
-D7-48-06-3B-80)
10.232.5.211 3120
18234 2013-04-15 14:16:09 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
-D7-48-06-3B-80)
18233 2013-04-15 14:16:07 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
-D7-48-06-3B-80)
18232 2013-04-15 14:16:05 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
-D7-48-06-3B-80)
18231 2013-04-15 14:16:03 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
-D7-48-06-3B-80)
18230 2013-04-15 14:16:01 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
-D7-48-06-3B-80)
18229 2013-04-15 14:15:59 NOTI(5) Topology changed (Instance:0, Port:1:48,MAC:D4
DGS-3100 при таком же подключении работают нормально.
Все DLINK свичи подключены двумя линками к двум цискам и образуют кольцо.
Конфиг и Tech_support log с одного из этих свитчей можно посмотреть тут: https://dl.dropboxusercontent.com/u/455 ... S-3120.rar
Помогите пожалуйста разобраться в сути проблемы и устранить её.
СообщениеДобавлено: Чт апр 18, 2013 08:30
Что за устройство шлет tcn? Отключайте stp на портах, на которых он не нужен, смотрите, где у вас идет смена топологии.
Сейчас этот форум просматривают: Google [Bot] и гости: 68
