Текущее время: Чт окт 01, 2026 03:18
СообщениеДобавлено: Вс фев 03, 2013 01:39
Добрый день, имеем проблемы со свитчем DGS-3200-10, включен в такой конфигурации
DGS-3426G -> оптика SFP 1Gbps -> DGS-3200-10 -> абонентские коммутаторы 3526,3528 около 10 шт.
в свитче
                     DGS-3200-10 Gigabit Ethernet Switch
                            Command Line Interface
                          Firmware: Build 2.21.B005
           Copyright(C) 2012 D-Link Corporation. All rights reserved.
UserName:admin
PassWord:
DGS-3200-10:4#show ports
Command: show ports
 Port      Port            Settings             Connection          Address
           State     Speed/Duplex/FlowCtrl  Speed/Duplex/FlowCtrl   Learning
 1        Enabled   Auto/Disabled           Link Down               Enabled
 2        Enabled   Auto/Disabled           Link Down               Enabled
 3        Enabled   Auto/Disabled           1000M/Full/None         Enabled
 4        Enabled   Auto/Disabled           1000M/Full/None         Enabled
 5        Enabled   Auto/Disabled           1000M/Full/None         Enabled
 6        Enabled   Auto/Disabled           1000M/Full/None         Enabled
 7        Enabled   Auto/Disabled           1000M/Full/None         Enabled
 8        Enabled   Auto/Disabled           1000M/Full/None         Enabled
 9    (C) Enabled   Auto/Disabled           Link Down               Enabled
 9    (F) Enabled   Auto/Disabled           1000M/Full/None         Enabled
 10   (C) Enabled   Auto/Disabled           Link Down               Enabled
 10   (F) Enabled   Auto/Disabled           Link Down               Enabled
Notes:(F)indicates fiber medium and (C)indicates copper medium in a combo port
Как видим в 10м порту нет линка, тут же запускаем и видим куча мак адресов:
DGS-3200-10:4#show fdb port 10
Command: show fdb port 10
 VID  VLAN Name                        MAC Address       Port  Type    Status
 1    default                          34-08-04-47-82-F6 10    Dynamic Forward
 5    managment                        00-1B-21-B9-EA-E9 10    Dynamic Forward
 10   Users                            00-00-F0-79-E9-D7 10    Dynamic Forward
 10   Users                            00-01-2E-23-45-5D 10    Dynamic Forward
 10   Users                            00-01-6C-0F-9C-50 10    Dynamic Forward
 10   Users                            00-01-6C-B3-27-DB 10    Dynamic Forward
 10   Users                            00-04-61-4A-CC-F1 10    Dynamic Forward
 10   Users                            00-04-61-4E-48-3B 10    Dynamic Forward
 10   Users                            00-06-F4-31-BA-42 10    Dynamic Forward
 10   Users                            00-0C-29-40-61-23 10    Dynamic Forward
 10   Users                            00-0C-6E-63-AC-70 10    Dynamic Forward
 10   Users                            00-0C-6E-93-87-60 10    Dynamic Forward
 10   Users                            00-0C-6E-CE-73-FC 10    Dynamic Forward
 10   Users                            00-0C-76-B9-07-BC 10    Dynamic Forward
 10   Users                            00-0E-08-EA-D4-9A 10    Dynamic Forward
 10   Users                            00-0E-2E-5F-BC-E7 10    Dynamic Forward
 10   Users                            00-0E-A6-41-43-70 10    Dynamic Forward
 10   Users                            00-11-2F-30-9A-87 10    Dynamic Forward
 10   Users                            00-11-2F-3D-4A-5D 10    Dynamic Forward
 10   Users                            00-11-2F-6F-73-7C 10    Dynamic Forward
CTRL+C ESC q Quit SPACE n Next Page ENTER Next Entry a All
Так же видим и нагрузку на порту
DGS-3200-10:4#show utilization ports
Command: show utilization ports
 Port     TX/sec     RX/sec   Util
 1      0          0          0
 2      0          0          0
 3      1741       995        1
 4      376        550        1
 5      1082       2333       1
 6      361        391        1
 7      528        320        1
 8      249        142        1
 9      635        1029       1
 10     5754       4698       4
в логах старта 10 порта нет
15    2000-01-01 03:56:21 Successful login through Telnet (Username: Anonymous
                          IP: 10.5.0.83)
14    2000-01-01 00:00:34 Port 5 link up, 1000Mbps FULL duplex
13    2000-01-01 00:00:33 Port 6 link up, 1000Mbps FULL duplex
12    2000-01-01 00:00:33 Port 8 link up, 1000Mbps FULL duplex
11    2000-01-01 00:00:33 Port 7 link up, 1000Mbps FULL duplex
10    2000-01-01 00:00:33 Port 3 link up, 1000Mbps FULL duplex
9     2000-01-01 00:00:33 Port 4 link up, 1000Mbps FULL duplex
8     2000-01-01 00:00:33 Port 9 link up, 1000Mbps FULL duplex
7     2000-01-01 00:00:33 Port 9 link down
6     2000-01-01 00:00:33 Port 9 link up, 1000Mbps FULL duplex
5     2000-01-01 00:00:33 Port 8 link down
4     2000-01-01 00:00:33 Port 7 link down
3     2000-01-01 00:00:33 Port 6 link down
2     2000-01-01 00:00:33 Port 4 link down
1     2000-01-01 00:00:33 System started up
При этом на морде светодиод линка моргает.
В итоге имеем свитч отвалившийся от управления, не пингуется, не отвечает, мас свой не светит на порту 3426G, смог зайти сейчас на него через клиентский 3526 только. При этом данные на клиентов шлет, управление свитчами находящимися за ним тоже осталось. Не работает igmp_snooping, мультикаст не бегает. Свитч новый только из коробки, поставлен на замену точно такому же 3200-10 который, точно также до этого заглючил. Управление пропало после перезагрузки.
Даже и не знаю, что и делать...
СообщениеДобавлено: Вс фев 03, 2013 15:08
Заменили SFP , вроде все заработало, но вопрос все равно к свитчу остается, если оно не работает, то хотелось бы чтобы не работало совсем, а не так себя вело. В итоге лишних 200 баксов на свитч и 2 дня разбирательства коту под хвост.
СообщениеДобавлено: Пн фев 04, 2013 10:09
Почитали бы хотя бы темы на первой странице - viewtopic.php?f=2&t=158726
О проблеме уже сообщено разработчикам.
Закрыто.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 90
