Текущее время: Чт окт 01, 2026 07:22
 Заголовок сообщения: Safeguard Engine на DGS-3200-16
СообщениеДобавлено: Вт дек 25, 2012 09:46
Постоянно прыгает защита Safeguard Engine.
2012-12-25 10:17:15 Local0 Info 192.168.10.5 Dec 25 10:17:13 192.168.10.5 INFO: Safeguard Engine enters NORMAL mode
2012-12-25 10:17:11 Local0 Warning 192.168.10.5 Dec 25 10:17:09 192.168.10.5 WARN: Safeguard Engine enters EXHAUSTED mode
2012-12-25 10:12:44 Local0 Info 192.168.10.14 Dec 25 10:12:41 192.168.10.14 INFO: Safeguard Engine enters NORMAL mode
2012-12-25 10:12:43 Local0 Info 192.168.10.13 Dec 25 10:12:41 192.168.10.13 INFO: Safeguard Engine enters NORMAL mode
2012-12-25 10:12:38 Local0 Warning 192.168.10.13 Dec 25 10:12:37 192.168.10.13 WARN: Safeguard Engine enters EXHAUSTED mode
2012-12-25 10:12:35 Local0 Warning 192.168.10.14 Dec 25 10:12:31 192.168.10.14 WARN: Safeguard Engine enters EXHAUSTED mode
2012-12-25 10:12:35 Local0 Info 192.168.10.2 Dec 25 10:12:30 192.168.10.2 INFO: Safeguard Engine enters NORMAL mode
2012-12-25 10:12:31 Local0 Info 192.168.10.9 Dec 25 10:12:29 192.168.10.9 INFO: Safeguard Engine enters NORMAL mode
2012-12-25 10:12:30 Local0 Warning 192.168.10.2 Dec 25 10:12:26 192.168.10.2 WARN: Safeguard Engine enters EXHAUSTED mode
2012-12-25 10:12:26 Local0 Warning 192.168.10.9 Dec 25 10:12:24 192.168.10.9 WARN: Safeguard Engine enters EXHAUSTED mode
2012-12-25 10:12:26 Local0 Info 192.168.10.10 Dec 25 10:12:25 192.168.10.10 INFO: Safeguard Engine enters NORMAL mode
2012-12-25 10:12:23 Local0 Info 192.168.10.11 Dec 25 10:12:22 192.168.10.11 INFO: Safeguard Engine enters NORMAL mode
2012-12-25 10:12:22 Local0 Warning 192.168.10.10 Dec 25 10:12:21 192.168.10.10 WARN: Safeguard Engine enters EXHAUSTED mode
2012-12-25 10:12:21 Local0 Info 192.168.10.6 Dec 25 10:12:20 192.168.10.6 INFO: Safeguard Engine enters NORMAL mode
Настройки:
DGS-3200-16:4#show safeguard_engine
Command: show safeguard_engine
Safeguard Engine State : Enabled
Safeguard Engine Current Status : Normal Mode
CPU Utilization Information:
Rising Threshold : 85%
Falling Threshold : 45%
Trap/Log State : Enabled
Mode : Fuzzy
Где копать?
 Заголовок сообщения: Re: Safeguard Engine на DGS-3200-16
СообщениеДобавлено: Вт дек 25, 2012 09:53
Смотреть какой трафик куда валится. Возможно петли в сети.
СообщениеДобавлено: Вт дек 25, 2012 09:58
В сети работает RSTP, в логах про петли молчит.
P.S на магистральных портах RSTP, на пользовательских LBD.
СообщениеДобавлено: Чт янв 17, 2013 10:30
Разобрался, виной скачков Safeguard Engine - SNMP!
Видимо у данной серии слабый CPU, раз SNMP запрос даёт скачёк загрузки CPU до 100 %, при котором срабатывает защита Safeguard Engine и тут же отключается. После таких скачков весь журнал syslog завален данными сообщениями.
P.S коммутаторы на доступность мониторю ПО The Dude 4.0beta3, вот как раз она и генерировала SNMP запросы.
При запросах через snmpwalk скачков загрузки CPU не наблюдаю.
СообщениеДобавлено: Чт янв 17, 2013 11:27
У меня при работе 3200-28 С1 в логах подобное наблюдалось, плюс на нем были задействованы все 100 Мбитные порты, ещё сам коммутатор периодически отваливался, пока не перезагрузишь - толку нет. Отключил Safeguard Engine, да и поставил туда, где мало портов используется, а на его место старую ревизию A1. Мониторинг осуществляется заббиксом 2.0.0.
СообщениеДобавлено: Чт янв 17, 2013 13:17
Я просто отключил отключил Alarm-ы от safeguard:
Если кому надо oid:
1.3.6.1.4.1.171.12.19.2.4 i
1 : other(1)
2 : disabled(2)
3 : enabled(3)
Сейчас этот форум просматривают: Google [Bot] и гости: 83
