Текущее время: Чт окт 01, 2026 07:22
 Заголовок сообщения: Странности с DES-3200-28/C1
СообщениеДобавлено: Вт окт 30, 2012 08:13
Недавно начали запускать новый район города на C1 ревизии сабжевых свичей. Столкнулись с проблемой:
147   2000-01-01 06:03:41 INFO(6) Port 14 link down
146   2000-01-01 06:03:41 INFO(6) Port 14 link up, 100Mbps FULL duplex
145   2000-01-01 06:03:40 INFO(6) Port 14 link down
144   2000-01-01 06:03:39 INFO(6) Port 14 link up, 100Mbps FULL duplex
143   2000-01-01 06:03:38 INFO(6) Port 14 link down
142   2000-01-01 06:03:38 INFO(6) Port 14 link up, 100Mbps FULL duplex
141   2000-01-01 06:03:36 INFO(6) Port 14 link down
140   2000-01-01 06:03:36 INFO(6) Port 14 link up, 100Mbps FULL duplex
139   2000-01-01 06:03:34 INFO(6) Port 14 link down
138   2000-01-01 06:03:34 INFO(6) Port 14 link up, 100Mbps FULL duplex
137   2000-01-01 06:03:32 INFO(6) Port 14 link down
136   2000-01-01 06:03:32 INFO(6) Port 14 link up, 100Mbps FULL duplex
135   2000-01-01 06:03:30 INFO(6) Port 14 link down
134   2000-01-01 06:03:30 INFO(6) Port 14 link up, 100Mbps FULL duplex
133   2000-01-01 06:03:28 INFO(6) Port 14 link down
132   2000-01-01 06:03:28 INFO(6) Port 14 link up, 100Mbps FULL duplex
131   2000-01-01 06:03:26 INFO(6) Port 14 link down
130   2000-01-01 06:03:26 INFO(6) Port 14 link up, 100Mbps FULL duplex
129   2000-01-01 06:03:25 INFO(6) Port 14 link down
128   2000-01-01 06:03:24 INFO(6) Port 14 link up, 100Mbps FULL duplex
127   2000-01-01 06:03:23 INFO(6) Port 14 link down
126   2000-01-01 06:03:23 INFO(6) Port 14 link up, 100Mbps FULL duplex
125   2000-01-01 06:03:21 INFO(6) Port 14 link down
124   2000-01-01 06:03:21 INFO(6) Port 14 link up, 100Mbps FULL duplex
123   2000-01-01 06:03:19 INFO(6) Port 14 link down
122   2000-01-01 06:03:19 INFO(6) Port 14 link up, 100Mbps FULL duplex
121   2000-01-01 06:03:17 INFO(6) Port 14 link down
120   2000-01-01 06:03:17 INFO(6) Port 14 link up, 100Mbps FULL duplex
119   2000-01-01 06:03:15 INFO(6) Port 14 link down
118   2000-01-01 06:03:15 INFO(6) Port 14 link up, 100Mbps FULL duplex
117   2000-01-01 06:03:14 INFO(6) Port 14 link down
116   2000-01-01 06:03:13 INFO(6) Port 14 link up, 100Mbps FULL duplex
115   2000-01-01 06:03:12 INFO(6) Port 14 link down
114   2000-01-01 06:03:12 INFO(6) Port 14 link up, 100Mbps FULL duplex
113   2000-01-01 06:03:10 INFO(6) Port 14 link down
112   2000-01-01 06:03:10 INFO(6) Port 14 link up, 100Mbps FULL duplex
111   2000-01-01 06:03:08 INFO(6) Port 14 link down
110   2000-01-01 06:03:08 INFO(6) Port 14 link up, 100Mbps FULL duplex
109   2000-01-01 06:03:06 INFO(6) Port 14 link down
108   2000-01-01 06:03:06 INFO(6) Port 14 link up, 100Mbps FULL duplex
107   2000-01-01 06:03:04 INFO(6) Port 14 link down
106   2000-01-01 06:03:04 INFO(6) Port 14 link up, 100Mbps FULL duplex
105   2000-01-01 06:03:02 INFO(6) Port 14 link down
104   2000-01-01 06:03:02 INFO(6) Port 14 link up, 100Mbps FULL duplex
103   2000-01-01 06:03:00 INFO(6) Port 14 link down
102   2000-01-01 06:03:00 INFO(6) Port 14 link up, 100Mbps FULL duplex
101   2000-01-01 06:02:58 INFO(6) Port 14 link down
100   2000-01-01 06:02:58 INFO(6) Port 14 link up, 100Mbps FULL duplex
99    2000-01-01 06:02:56 INFO(6) Port 14 link down
98    2000-01-01 06:02:56 INFO(6) Port 14 link up, 100Mbps FULL duplex
97    2000-01-01 06:02:54 INFO(6) Port 14 link down
перепробовали 4 порта двумя ноутами - результат одинаков.
буки рапортуют что кабель не подключен, cable_diag говорит порт в шатдауне, периодически показывая его длину.
loopdetect на порт не жалуется. пробовал переключить на 10 мбит, дергаться перестал, линк поднялся, но ноуты своего мнения не изменили - кабель не подключен...
есть у кого предположения что за фигня творится с коммутатором?
пока-что это первый такой случай, хотя это не первый абон на C1 ревизии
Последний раз редактировалось ru.jester Вт окт 30, 2012 08:21, всего редактировалось 1 раз.
 Заголовок сообщения: Re: Странности с DES-3200-28/C1
СообщениеДобавлено: Вт окт 30, 2012 08:16
Предположение, что очень длинный/битый кабель.
СообщениеДобавлено: Вт окт 30, 2012 09:46
Подскажите как на DES-3200-28/C1 удалить в "ACL - Access Profile List" два профиля при нажатие на delete выдает "Cannot delete the system profile"
delete access_profile all - не удаляет
reset - не удаляет
СообщениеДобавлено: Вт окт 30, 2012 10:07
профили 1,2 - системные, типы у них ETH и IP соответственно. они не удаляются, а чего делают - это тайна, которую разработчики не говорят.
Сейчас этот форум просматривают: Google [Bot] и гости: 83
