Текущее время: Чт окт 01, 2026 19:21
 Заголовок сообщения: DES-3200-52 rev. C1 igmp_snooping
СообщениеДобавлено: Чт июн 14, 2012 10:46
Пытаюсь настроить новый DES-3200, прошивка 4.20.B004
Кусок конфига:
# IGMP_MULTICAST_VLAN
enable igmp_snooping multicast_vlan
config igmp_snooping multicast_vlan forward_unmatched disable
create igmp_snooping multicast_vlan ISM 7
config igmp_snooping multicast_vlan ISM state enable replace_source_ip 0.0.0.0
config igmp_snooping multicast_vlan ISM add member_port 1-48
config igmp_snooping multicast_vlan ISM add tag_member_port 50
config igmp_snooping multicast_vlan ISM add source_port 49
# MULTICAST_FILTER
create mcast_filter_profile profile_id 1 profile_name IPTV
config mcast_filter_profile profile_id 1 add 224.0.0.2-224.0.0.2
config mcast_filter_profile profile_id 1 add 239.72.0.1-239.72.255.254
config limited_multicast_addr ports 1-48 add profile_id 1
config max_mcast_group ports 1-52 max_group 5
# MCFILTER
config multicast vlan_filtering_mode vlanid 7 filter_unregistered_groups
# IGMP_SNOOPING
config igmp_snooping data_driven_learning max_learned_entry 96
config igmp_snooping vlan_name default fast_leave disable report_suppression enable state disable
config igmp_snooping querier vlan_name default query_interval 125  max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping data_driven_learning vlan_name default expiry_time 260 state enable aged_out disable
config igmp_snooping vlan_name ISM fast_leave disable report_suppression enable
config igmp_snooping querier vlan_name ISM query_interval 125  max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping data_driven_learning vlan_name ISM expiry_time 260 state enable aged_out disable
config igmp_snooping vlan_name client fast_leave disable report_suppression enable state disable
config igmp_snooping querier vlan_name client query_interval 125  max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping data_driven_learning vlan_name client expiry_time 260 state enable aged_out disable
config cpu_filter l3_control_pkt 1-52 all state disable
На абонентских портах мультикаста не наблюдаю, igmp_snooping в ISM влане отображается как выключенный
DES-3200-52:admin#show igmp_snooping vlan ISM
Command: show igmp_snooping vlan ISM
 IGMP Snooping Global State              : Enabled
 Data Driven Learning Max Entries        : 96
 VLAN Name                     : ISM
 Query Interval                : 125
 Max Response Time             : 10
 Robustness Value              : 2
 Last Member Query Interval    : 1
 Querier State                 : Disabled
 Querier Role                  : Non-Querier
 Querier IP                    : 192.168.1.6
 Querier Expiry Time           : 212 secs
 State                         : Disabled
 Fast Leave                    : Disabled
 Rate Limit                    : No Limitation
 Report Suppression            : Enabled
 Version                       : 3
 Data Driven Learning State    : Enabled
 Data Driven Learning Aged Out : Disabled
 Data Driven Group Expiry Time : 260
Total Entries: 1
Это я что-то делаю не так или глюк коммутатора?
 Заголовок сообщения: Re: DES-3200-52 rev. C1 igmp_snooping
СообщениеДобавлено: Чт июн 14, 2012 11:11
Нужно для Limited Multicast Address указывать параметр access:
config limited_multicast_addr ports 1-48 add profile_id 1 access permit
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 89
