Текущее время: Пт окт 02, 2026 21:06
 Заголовок сообщения: DGS-3120-24SC Gigabit Ethernet Switch Temperatrue Sensor:1
СообщениеДобавлено: Вт янв 24, 2012 16:15
Посыпало в логи:
Jan 21 14:07:44 192.168.2.2 WARN: Unit 1 Temperatrue Sensor:1 enter alarm state.(current temperatrue:11)
Jan 21 14:07:50 192.168.2.2 INFO: Unit 1 Temperatrue Sensor:1 recovers to normal state.(current temperatrue:12)
Jan 21 14:11:39 192.168.2.2 WARN: Unit 1 Temperatrue Sensor:1 enter alarm state.(current temperatrue:11)
Jan 21 14:11:45 192.168.2.2 INFO: Unit 1 Temperatrue Sensor:1 recovers to normal state.(current temperatrue:12)
Jan 21 14:11:52 192.168.2.2 WARN: Unit 1 Temperatrue Sensor:1 enter alarm state.(current temperatrue:11)
Jan 21 14:11:58 192.168.2.2 INFO: Unit 1 Temperatrue Sensor:1 recovers to normal state.(current temperatrue:12)
Jan 21 14:12:04 192.168.2.2 WARN: Unit 1 Temperatrue Sensor:1 enter alarm state.(current temperatrue:11)
Jan 21 14:12:10 192.168.2.2 INFO: Unit 1 Temperatrue Sensor:1 recovers to normal state.(current temperatrue:12)
Jan 21 14:12:34 192.168.2.2 WARN: Unit 1 Temperatrue Sensor:1 enter alarm state.(current temperatrue:11)
Jan 21 14:12:40 192.168.2.2 INFO: Unit 1 Temperatrue Sensor:1 recovers to normal state.(current temperatrue:12)
Jan 21 14:13:04 192.168.2.2 WARN: Unit 1 Temperatrue Sensor:1 enter alarm state.(current temperatrue:11)
Jan 21 14:13:16 192.168.2.2 INFO: Unit 1 Temperatrue Sensor:1 recovers to normal state.(current temperatrue:12)
Jan 21 14:14:29 192.168.2.2 WARN: Unit 1 Temperatrue Sensor:1 enter alarm state.(current temperatrue:11)
Jan 21 14:15:05 192.168.2.2 INFO: Unit 1 Temperatrue Sensor:1 recovers to normal state.(current temperatrue:12)
Jan 21 14:15:29 192.168.2.2 WARN: Unit 1 Temperatrue Sensor:1 enter alarm state.(current temperatrue:11)
Jan 21 14:15:41 192.168.2.2 INFO: Unit 1 Temperatrue Sensor:1 recovers to normal state.(current temperatrue:12)
Jan 21 14:15:47 192.168.2.2 WARN: Unit 1 Temperatrue Sensor:1 enter alarm state.(current temperatrue:11)
Jan 21 14:15:59 192.168.2.2 INFO: Unit 1 Temperatrue Sensor:1 recovers to normal state.(current temperatrue:12)
Jan 21 14:16:23 192.168.2.2 WARN: Unit 1 Temperatrue Sensor:1 enter alarm state.(current temperatrue:11)
Jan 21 14:16:30 192.168.2.2 INFO: Unit 1 Temperatrue Sensor:1 recovers to normal state.(current temperatrue:12)
Jan 21 14:17:00 192.168.2.2 WARN: Unit 1 Temperatrue Sensor:1 enter alarm state.(current temperatrue:11)
Jan 21 14:17:06 192.168.2.2 INFO: Unit 1 Temperatrue Sensor:1 recovers to normal state.(current temperatrue:12)
Jan 21 14:17:12 192.168.2.2 WARN: Unit 1 Temperatrue Sensor:1 enter alarm state.(current temperatrue:11)
Но становится, не много не понятно, а чего вдруг так???
Какие у него критические параметры температуры? а вдруг я его на крышу?
 Заголовок сообщения: Re: DGS-3120-24SC Gigabit Ethernet Switch Temperatrue Sensor
СообщениеДобавлено: Ср янв 25, 2012 08:20
Логи, трапы и граничные параметры температуры можно настроить.
Почитайте CLI мануал стр.473 глава 49
СообщениеДобавлено: Ср янв 25, 2012 08:44
Это понятно, но вопрос, до скольки можно опускать температуру чтобы оборудование нормально работало? а то сегодня наверное уже весь ноль в помещении.
СообщениеДобавлено: Ср янв 25, 2012 09:00
Смотрим описание коммутатора серии DGS-3120:
http://dlink.ru/ru/products/1/1366_b.html
Рабочая температура
От 0˚ до 50˚ C
Рабочая влажность
От 5% до 90% без конденсата
