Текущее время: Сб окт 03, 2026 01:13
Начать новую тему Эта тема закрыта, Вы не можете редактировать и оставлять сообщения в ней.  [ Сообщений: 2 ]
 Заголовок сообщения: высокая загрузка CPU DGS-3610-26G A2A
СообщениеДобавлено: Пн ноя 21, 2011 11:11
ситуация следующая:
#show cpu | e 0.00
     CPU Using Rate Information
CPU utilization in five seconds: 50.18%
CPU utilization in one minute  : 55.35%
CPU utilization in five minutes: 53.48%
  NO   5Sec   1Min   5Min   Process
  0   8.02%   9.27%   9.05%    LISR INT
  1   1.25%   1.53%   1.28%    HISR INT
  2   0.26%   0.27%   0.27%    ktimer
  3   0.08%   0.09%   0.10%    atimer
 18   0.01%   0.03%   0.03%    ll_mt
 19   0.42%   0.42%   0.42%    ll main process
 36   0.47%   0.49%   0.49%    lacp_event
 42   0.06%   0.09%   0.10%    erps_task
 46   0.61%   0.60%   0.60%    tpp_task
 49   0.03%   0.03%   0.03%    ip6timer
 56   7.00%   8.02%   7.97%    tnet
 58  16.43%  16.81%  15.99%    Tarptime
 60   0.01%   0.01%   0.01%    Ttcptimer
 63   0.14%   0.13%   0.14%    ef_res
 64   1.39%   1.52%   1.47%    ef_rcv_msg
 83   0.09%   0.04%   0.03%    nsmd
 84   0.01%   0.11%   0.11%    ripd
 86   0.46%   0.22%   0.22%    ospfd
 98   0.03%   0.03%   0.02%    Tlogtrap
114   0.28%   0.27%   0.27%    bfd_server
115   0.02%   0.02%   0.02%    bfd_proxy
144   0.05%   0.05%   0.05%    lldp_task
148   2.11%   2.09%   2.10%    bcm_l2x_1
149   0.97%   0.96%   0.95%    bcm_cntr_0
150   1.03%   1.04%   1.04%    bcm_link_0
151   0.05%   0.05%   0.05%    dma_pkt_thread
166   8.17%   9.36%   9.41%    ssp_flow_rx_task
171   0.06%   0.05%   0.04%    idle_vlan_proc_thread
174   0.65%   0.54%   0.54%    stat_get_and_send
176   0.02%   0.16%   0.12%    rl_vty_2
177  49.82%  44.65%  46.52%    idle
#sh cpu m | e 0         0         0
 Type                 Pps       Total     Drop
 arp                  20        295255    0
 lldp                 0         1688      0
 ospf-v2              1         13804     0
 rip-ipv4             0         912       0
 err-ttl1             0         126727    22
 ip-packet-other      79        1278015   0
#sh arp counter
Count of static entries:  0
Count of dynamic entries: 3636 (complete: 3332  incomplete: 304)
Total:                    3636
#sh mac-address-table count
Dynamic Address Count  : 3993
Static  Address Count  : 0
Filtering Address Count: 0
Total Mac Addresses    : 3993
Total Mac Address Space Available: 28775
#sh interfaces status
Interface                Status    Vlan  Duplex   Speed     Type
GigabitEthernet 0/1      up        1     Full     1000M     fiber
GigabitEthernet 0/2      up        1     Full     1000M     fiber
GigabitEthernet 0/3      up        1     Full     1000M     fiber
GigabitEthernet 0/4      up        1     Full     1000M     fiber
GigabitEthernet 0/5      down      1     Unknown  Unknown   fiber
GigabitEthernet 0/6      down      1     Unknown  Unknown   fiber
GigabitEthernet 0/7      down      1     Unknown  Unknown   fiber
GigabitEthernet 0/8      down      1     Unknown  Unknown   fiber
GigabitEthernet 0/9      down      1     Unknown  Unknown   fiber
GigabitEthernet 0/10     down      1     Unknown  Unknown   fiber
GigabitEthernet 0/11     down      1     Unknown  Unknown   fiber
GigabitEthernet 0/12     down      1     Unknown  Unknown   fiber
GigabitEthernet 0/13     up        1     Full     1000M     copper
GigabitEthernet 0/14     up        1     Full     1000M     copper
GigabitEthernet 0/15     up        1     Full     1000M     copper
GigabitEthernet 0/16     up        1     Full     1000M     copper
GigabitEthernet 0/17     down      1     Unknown  Unknown   copper
GigabitEthernet 0/18     down      1     Unknown  Unknown   copper
GigabitEthernet 0/19     up        1     Full     1000M     copper
GigabitEthernet 0/20     up        1     Full     1000M     copper
GigabitEthernet 0/21     up        1     Full     1000M     copper
GigabitEthernet 0/22     up        1     Full     1000M     copper
GigabitEthernet 0/23     up        1     Full     1000M     copper
GigabitEthernet 0/24     up        1     Full     1000M     copper
AggregatePort 1          up        1     Full     1000M     fiber
AggregatePort 2          up        1     Full     1000M     copper
AggregatePort 3          up        1     Full     1000M     copper
AggregatePort 4          up        1     Full     1000M     copper
по топологии 1-4 порты LACP из ядра, 13-16 порты LACP в стэк DGS-3120, 21-22 и 23-24 сервера для фильтрации трафика, 19 и 20 порты сервер для диагностики трафика (monitor session + tcpdump)
Вечером все становится на столько плохо, что невозможно подключиться по telnet (после обмена SYN тихо).
по фильтру зекралированного трафика линка в сторону абонентов
tcpdump -ni em1 -e vlan and ! arp and ! tcp and ! udp and proto ! gre and ! ipv6 and ! icmp and ! esp
видно только LACP.
если делать фильтр, где перечислить все ip, приписанные на коммутаторе, то видны лишь icmp reply/request на скорости примерно 10 запросов до коммутатора в секунду.
на коммутаторе запущены rip для анонсирования в ядро и OSPF для связи с VPN абонентами:
#sh ip ro sum
  Memory: 220632 bytes
  Entries: 951
    Connected:152,Static:7,RIP:0,OSPF:791,ISIS:0,BGP:0
#sh interfaces counters rate
Interface    Sampling Time         Input Rate           Input Rate           Output Rate          Output Rate
                                   (bits/sec)           (packets/sec)        (bits/sec)           (packets/sec)
Gi0/1        5 seconds             291836594            43205                259225683            53243
Gi0/2        5 seconds             447794171            52959                233911793            43631
Gi0/3        5 seconds             462633199            59565                278359294            43939
Gi0/4        5 seconds             402405001            50173                257774861            41433
Gi0/5        5 seconds             0                    0                    0                    0
Gi0/6        5 seconds             0                    0                    0                    0
Gi0/7        5 seconds             0                    0                    0                    0
Gi0/8        5 seconds             0                    0                    0                    0
Gi0/9        5 seconds             0                    0                    0                    0
Gi0/10       5 seconds             0                    0                    0                    0
Gi0/11       5 seconds             0                    0                    0                    0
Gi0/12       5 seconds             0                    0                    0                    0
Gi0/13       5 seconds             283008981            48334                698104450            90868
Gi0/14       5 seconds             256725591            40347                230042665            43776
Gi0/15       5 seconds             279685760            46254                411483094            58645
Gi0/16       5 seconds             278724724            59103                346791373            55110
Gi0/17       5 seconds             0                    0                    0                    0
Gi0/18       5 seconds             0                    0                    0                    0
Gi0/19       5 seconds             472                  0                    1738                 1
Gi0/20       5 seconds             1048                 0                    968167543            153991
Gi0/21       5 seconds             221245268            52406                232721295            41821
Gi0/22       5 seconds             209297559            49521                183599388            29162
Gi0/23       5 seconds             49580683             18512                54936712             19905
Gi0/24       5 seconds             49471544             18422                45692955             17918
Ag1          5 seconds             1636412300           209817               1045134679           185290
Ag2          5 seconds             1115277726           197319               1719478088           252838
Ag3          5 seconds             102183318            37829                103806667            38743
Ag4          5 seconds             435801141            103153               421440917            71884
Ag5          5 seconds             3364                 2                    2490                 4
вообщем, повторяется ситуация с DGS-3612. если проблема не будет решена, то нового возвращения аггрегации на D-Link не предвидится. сейчас остальные районы крутятся на Cisco 3550/3750 - подобных проблем никогда не возникало.
вечерняя нагрузка поднимается до
d1-zav40#sh arp counter
Count of dynamic entries: 4117 (complete: 3878  incomplete: 239)
Total:                    4117
d1-zav40#sh mac-address-table count
Dynamic Address Count  : 4873
Total Mac Addresses    : 4873
Total Mac Address Space Available: 27895
Total Entries: 4194
и 3-3.5Гбит на a1 и a2
 Заголовок сообщения: Re: высокая загрузка CPU DGS-3610-26G A2A
СообщениеДобавлено: Пн ноя 21, 2011 11:24
viewtopic.php?f=2&t=146613
версию ПО сообщите, пожалуйста и покажите файл конфигурации
