Текущее время: Сб окт 03, 2026 07:42
 Заголовок сообщения: вопрос dhcp relay
СообщениеДобавлено: Пт сен 02, 2011 14:40
Есть множество комутаторов dlink у всех один vlan управления.
В этом же vlan находится DHCP сервер.
Везде настроен dhcp relay.
При попытки клиента получить адрес наблюдаем картину.
2011-09-02 15:40:51 [32280:3037158256] Got DHCPDISCOVER (1) message from client 00:21:27:D0:AE:D3 on eth0/ipserver (relay 10.128.18.11)
2011-09-02 15:40:51 [32280:3037158256] Got DHCPDISCOVER (1) message from client 00:21:27:D0:AE:D3 on eth0/ipserver (relay 10.128.18.15)
2011-09-02 15:40:51 [32280:3037158256] Got DHCPDISCOVER (1) message from client 00:21:27:D0:AE:D3 on eth0/ipserver (relay 10.128.18.52)
2011-09-02 15:40:51 [32280:3037158256] Got DHCPDISCOVER (1) message from client 00:21:27:D0:AE:D3 on eth0/ipserver (relay 10.128.18.10)
2011-09-02 15:40:51 [32280:3037158256] Got DHCPDISCOVER (1) message from client 00:21:27:D0:AE:D3 on eth0/ipserver (relay 10.128.18.24)
2011-09-02 15:40:51 [32280:3037158256] Got DHCPDISCOVER (1) message from client 00:21:27:D0:AE:D3 on eth0/ipserver (relay 10.128.18.26)
2011-09-02 15:40:51 [32280:3037158256] Got DHCPDISCOVER (1) message from client 00:21:27:D0:AE:D3 on eth0/ipserver (relay 10.128.18.93)
2011-09-02 15:40:51 [32280:3037158256] Got DHCPDISCOVER (1) message from client 00:21:27:D0:AE:D3 on eth0/ipserver (relay 10.128.18.80)
2011-09-02 15:40:51 [32280:3037158256] Got DHCPDISCOVER (1) message from client 00:21:27:D0:AE:D3 on eth0/ipserver (relay 10.128.18.58)
2011-09-02 15:40:51 [32280:3037158256] Got DHCPDISCOVER (1) message from client 00:21:27:D0:AE:D3 on eth0/ipserver (relay 10.128.18.12)
2011-09-02 15:40:51 [32280:3037158256] Got DHCPDISCOVER (1) message from client 00:21:27:D0:AE:D3 on eth0/ipserver (relay 10.128.18.81)
2011-09-02 15:40:52 [32280:3037158256] Sending DHCPOFFER (2) to 00:21:27:D0:AE:D3/10.128.20.18 via ipserver (relay 10.128.18.11)
2011-09-02 15:40:52 [32280:3037158256] Sending DHCPOFFER (2) to 00:21:27:D0:AE:D3/10.128.20.18 via ipserver (relay 10.128.18.15)
2011-09-02 15:40:52 [32280:3037158256] Sending DHCPOFFER (2) to 00:21:27:D0:AE:D3/10.128.20.18 via ipserver (relay 10.128.18.52)
2011-09-02 15:40:52 [32280:3037158256] Sending DHCPOFFER (2) to 00:21:27:D0:AE:D3/10.128.20.18 via ipserver (relay 10.128.18.10)
2011-09-02 15:40:52 [32280:3037158256] Sending DHCPOFFER (2) to 00:21:27:D0:AE:D3/10.128.20.18 via ipserver (relay 10.128.18.24)
2011-09-02 15:40:52 [32280:3037158256] Sending DHCPOFFER (2) to 00:21:27:D0:AE:D3/10.128.20.18 via ipserver (relay 10.128.18.26)
2011-09-02 15:40:52 [32280:3037158256] Sending DHCPOFFER (2) to 00:21:27:D0:AE:D3/10.128.20.18 via ipserver (relay 10.128.18.93)
2011-09-02 15:40:52 [32280:3037158256] Sending DHCPOFFER (2) to 00:21:27:D0:AE:D3/10.128.20.18 via ipserver (relay 10.128.18.80)
2011-09-02 15:40:52 [32280:3037158256] Sending DHCPOFFER (2) to 00:21:27:D0:AE:D3/10.128.20.18 via ipserver (relay 10.128.18.58)
2011-09-02 15:40:52 [32280:3037158256] Sending DHCPOFFER (2) to 00:21:27:D0:AE:D3/10.128.20.18 via ipserver (relay 10.128.18.12)
2011-09-02 15:40:52 [32280:3037158256] Sending DHCPOFFER (2) to 00:21:27:D0:AE:D3/10.128.20.18 via ipserver (relay 10.128.18.81)
как все коммутаторы запрашивают адрес для этого клиента у сервера. Как возможно ограничить прохождения DHCP запросов на другие устройства. Что бы общение с dhcp relay было локальный а не ходило по всей сети.
 Заголовок сообщения: Re: вопрос dhcp relay
СообщениеДобавлено: Пт сен 02, 2011 14:47
Укажите модели коммутаторов, прошивки и опишите топологию сети.
Какие настройки на коммутаторах в плане dhcp_relay?
СообщениеДобавлено: Пт сен 02, 2011 14:54
Прошивки разные. Коммутаторы 3526 3028 3550.
              DES-3550 Fast Ethernet Switch Command Line Interface
                            Firmware: Build 5.01.B53
            Copyright(C) 2008 D-Link Corporation. All rights reserved.
username:
password:
DES-3550:admin#show dhcp_relay
Command: show dhcp_relay
DHCP/BOOTP Relay Status         : Enabled
DHCP/BOOTP Hops Count Limit     : 4
DHCP/BOOTP Relay Time Threshold : 0
DHCP Relay Agent Information Option 82 State  : Disabled
DHCP Relay Agent Information Option 82 Check  : Disabled
DHCP Relay Agent Information Option 82 Policy : Replace
DHCP Relay Agent Information Option 82 Remote ID : mac
Interface     Server 1         Server 2         Server 3         Server 4
System        ip.ip.ip.ip      ip.ip.ip.ip
DES-3550:admin#
СообщениеДобавлено: Пт сен 02, 2011 14:56
видимо меня интересует acl блокирующий dhcp запросы в любые другие места кроме relay.
СообщениеДобавлено: Пт сен 02, 2011 15:30
Есть что то похожее? или возможно заблокировать входящие запросы на магистральных портах. ?
СообщениеДобавлено: Пт сен 02, 2011 16:38
Опишите, пожалуйста, топологию более точно. Как я понимаю коммутаторы подключены цепочкой. Если да, то как она выглядит?
СообщениеДобавлено: Сб сен 10, 2011 18:16
Дело было в прошивке. Прошу вышлете актуальные. Отписал в теме с запросом.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 101
