Текущее время: Сб окт 03, 2026 12:29
 Заголовок сообщения: 3200-28 LLDP Firmware Version : Build 1.52.B004
СообщениеДобавлено: Пн авг 08, 2011 08:40
Не функционирует LLDP после смены ПО
Boot PROM Version : Build 1.00.B004
ДОСТУП
enable lldp
config lldp message_tx_interval 30
config lldp tx_delay 2
config lldp message_tx_hold_multiplier 4
config lldp reinit_delay 2
config lldp notification_interval 5
config lldp forward_message enable
config lldp ports 25 dot1_tlv_protocol_vid vlanid 1-4059 enable
config lldp ports 25 dot1_tlv_vlan_name vlanid 1-4059 enable
config lldp ports 26 dot1_tlv_protocol_vid vlanid 1-4059 enable
config lldp ports 26 dot1_tlv_vlan_name vlanid 1-4059 enable
config lldp ports 27 dot1_tlv_protocol_vid vlanid 1-4059 enable
config lldp ports 27 dot1_tlv_vlan_name vlanid 1-4059 enable
config lldp ports 28 dot1_tlv_protocol_vid vlanid 1-4059 enable
config lldp ports 28 dot1_tlv_vlan_name vlanid 1-4059 enable
config lldp ports 1-24 notification disable
config lldp ports 1-28 admin_status tx_and_rx
config lldp ports 25-28 notification enable
config lldp ports 25-28 basic_tlvs port_description system_name system_description system_capabilities enable
config lldp ports 25-28 dot1_tlv_pvid enable
config lldp ports 25-28 dot1_tlv_protocol_identity eapol enable
config lldp ports 25-28 dot1_tlv_protocol_identity lacp enable
config lldp ports 25-28 dot1_tlv_protocol_identity gvrp enable
config lldp ports 25-28 dot1_tlv_protocol_identity stp enable
config lldp ports 25-28 mgt_addr ipv4 10.24.0.181 enable
sw01.mu02.z32:5#show lldp statistics ports 25
Command: show lldp statistics ports 25
Port ID : 25
lldpStatsTxPortFramesTotal : 240
lldpStatsRxPortFramesDiscardedTotal : 0
lldpStatsRxPortFramesErrors : 0
lldpStatsRxPortFramesTotal : 0
lldpStatsRxPortTLVsDiscardedTotal : 0
lldpStatsRxPortTLVsUnrecognizedTotal : 0
lldpStatsRxPortAgeoutsTotal : 0
АГРЕГАТ
enable lldp
config lldp ports 1-24 notification enable
config lldp ports 1-27 admin_status tx_and_rx
config lldp ports 1-24 basic_tlvs port_description system_name system_description system_capabilities enable
config lldp ports 1-24 dot1_tlv_pvid enable
config lldp ports 1-24 dot1_tlv_vlan_name vlanid 1-4094 enable
config lldp ports 1-24 dot1_tlv_protocol_identity eapol enable
config lldp ports 1-24 dot1_tlv_protocol_identity lacp enable
config lldp ports 1-24 dot1_tlv_protocol_identity gvrp enable
config lldp ports 1-24 dot1_tlv_protocol_identity stp enable
config lldp ports 25-27 notification disable
config lldp ports 1-24 mgt_addr ipv4 10.10.56.30 enable
mu01.z20a.ugrat:admin#show lldp statistics ports 1
Command: show lldp statistics ports 1
Port ID : 1
LLDPStatsTXPortFramesTotal : 296
LLDPStatsRXPortFramesDiscardedTotal : 0
LLDPStatsRXPortFramesErrors : 0
LLDPStatsRXPortFramesTotal : 246
LLDPStatsRXPortTLVsDiscardedTotal : 0
LLDPStatsRXPortTLVsUnrecognizedTotal : 0
LLDPStatsRXPortAgeoutsTotal : 0
mu01.z20a.ugrat:admin#show lldp remote_ports 1
Command: show lldp remote_ports 1
Port ID : 1
Remote Entities Count : 1
Entity 1
Chassis ID Subtype : MAC Address
Chassis ID : 1C-BD-B9-56-BA-00
Port ID Subtype : Local
Port ID : 1/25
Port Description : D-Link DES-3200-28 R1.52 Port 2
5
System Name : sw01.mu02.z32.ugratel.ru
System Description : Fast Ethernet Switch
System Capabilities : Repeater, Bridge
Management Address Count : 1
Port PVID : 1
PPVID Entries Count : 0
VLAN Name Entries Count : 10
Protocol ID Entries Count : 0
MAC/PHY Configuration/Status : (None)
Power Via MDI : (None)
Link Aggregation : (None)
Maximum Frame Size : 0
Unknown TLVs Count : 0
 Заголовок сообщения: Re: 3200-28 LLDP Firmware Version : Build 1.52.B004
СообщениеДобавлено: Пн авг 08, 2011 09:40
У Вас на коммутатор просто не поступают пакеты LLDP. Какой коммутатор включен в 25-й порт? Если DGS-3627, то какая на нём прошивка?
СообщениеДобавлено: Пн авг 08, 2011 11:04
25 порт 3627
Boot PROM Version : Build 1.10-B09
Firmware Version : Build 2.84.B14
26 порт 3200-28.
Проблема точно не в 3627. Откатились на Build 1.51.B005
СообщениеДобавлено: Пн авг 08, 2011 12:02
Обновите прошивку на DGS-3627 на 2.84-B16 и выше.
На всех устройствах фиксили поведение LLDP в последних прошивках. На DES-3200 - начиная с R1.52.B003, на DGS-3627 - как я уже написал, начиная с 2.84-B16
СообщениеДобавлено: Пн авг 08, 2011 12:13
Смущает факт того что ставили три 3200-28 с Build 1.52.B004 и они не видят друг друга по LLDP.
Можно ли получить 2.84-B16 для 3627?
СообщениеДобавлено: Пн авг 08, 2011 12:22
Прошивки запросите в соответствующей теме.
viewtopic.php?f=2&t=92700
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 97
