Текущее время: Сб окт 03, 2026 17:50
СообщениеДобавлено: Пн апр 18, 2011 16:55
Собственно телевидение получаем от партнеров, настроен ISM влан и фильтрация
Свичи DES3526
прошивка 6.00 B43
Вот пример настроек мультикаста:
create igmp_snooping multicast_vlan vlan_400 400
config igmp_snooping multicast_vlan vlan_400 state enable replace_source_ip 10.40.54.79 source_port 25
config igmp_snooping multicast_vlan vlan_400 state enable member_port 7
config igmp_snooping vlan_400 host_timeout 260 router_timeout 260 leave_timer 2 state enable
config igmp_snooping querier vlan_400 query_interval 125 max_response_time 10 robustness_variable 2
config igmp_snooping querier vlan_400 last_member_query_interval 1 state disable
config igmp_snooping default host_timeout 260 router_timeout 260 leave_timer 2 state disable
config igmp_snooping querier default query_interval 125 max_response_time 10 robustness_variable 2
config igmp_snooping querier default last_member_query_interval 1 state disable
config igmp_snooping vlan_21 host_timeout 260 router_timeout 260 leave_timer 2 state disable
config igmp_snooping querier vlan_21 query_interval 125 max_response_time 10 robustness_variable 2
config igmp_snooping querier vlan_21 last_member_query_interval 1 state disable
config igmp_snooping manag host_timeout 260 router_timeout 260 leave_timer 2 state disable
config igmp_snooping querier manag query_interval 125 max_response_time 10 robustness_variable 2
config igmp_snooping querier manag last_member_query_interval 1 state disable
create multicast_range tv_media_al from 224.0.42.0 to 224.0.45.255
create multicast_range m_roters from 224.0.0.2 to 224.0.0.2
config limited_multicast_addr ports 1-26 add multicast_range tv_media_al
config limited_multicast_addr ports 1-26 add multicast_range m_roters
config limited_multicast_addr ports 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,26 access permit state enable
config limited_multicast_addr ports 25 access deny state disable
Соответсвенно 25 порт аплинк, юзер в 7 порту с приставкой DIB120
Регулярно наблюдаю что юзер подписан на 100 и более групп -и такое по всей цепочке свичей.
Ну и порой наблюдаю >3000 мультикаст пакетов которые сваливаются на приставку.
Что посоветуйте?
http://lanstart.ru -Сети, сервисы, оборудование.
СообщениеДобавлено: Ср апр 20, 2011 11:50
Попробуйте, пожалуйста, ситуацию с прошивкой, которую я Вам выслал. С ней на тестовом стенде такого не наблюдается.
СообщениеДобавлено: Ср апр 20, 2011 12:07
Спасибо помогло
Более того, есть цепочка из 2 свичей
На свиче в котором подключен абонент -новая прошивка
Выше -более старая прошивка
Итого - на абонентском свиче -все в порядке, на предыдущем - висят те же 100 групп.
Ушел перешивать свичи, спасибо.
СообщениеДобавлено: Ср апр 20, 2011 12:09
Рад слышать, что помогло.
СообщениеДобавлено: Чт апр 21, 2011 01:34
Было бы хорошо, если бы указали начиная с какой прошивки проблема исправилась. И еще затрагивает только 3526 или и 3550. Не нескольких 3550 коммутаторах стоит В44, на всякий случай прошился последней, из того что имею.
СообщениеДобавлено: Чт апр 21, 2011 08:53
Точных данных, когда это исправили нет. Так как прошивка для DES-3526 и DES-3550 основана на одном коде, то лучше и DES-3550 обновить.
СообщениеДобавлено: Чт апр 28, 2011 18:42
6.00 B43 -проблема есть
6.00 B53 -уже нету
где то между ними и исправили
СообщениеДобавлено: Пт апр 29, 2011 09:15
Вас понял. Рад слышать, что проблема решена!
СообщениеДобавлено: Пт апр 29, 2011 10:40
6.00 B53 -уже нету
6.00-B45
1. Fixed issue with ISM VLAN (device does not leave multicast groups).
2008-2015г. компания Экстрим Интернет. Технический директор/Главный системный администратор.
2015-по н.в. компания "Подряд". Инженер сети ШПД
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 133
