Текущее время: Вс окт 04, 2026 12:54
 Заголовок сообщения: 3200-28 помогите с мультикастом
СообщениеДобавлено: Ср июн 16, 2010 12:29
помогите запустить.
на 25 порт в 200 влане подается в таге мультикаст.
# VLAN
disable asymmetric_vlan
enable pvid auto_assign
config vlan default delete 1-28
config vlan default advertisement disable
create vlan native tag 2
config vlan native add forbidden 1-28
create vlan 20 tag 20
config vlan 20 add tagged 25
create vlan 2003 tag 2003
config vlan 2003 add tagged 25
config vlan 2003 add untagged 1-24,26-28
disable qinq
disable gvrp
config qinq ports 1-28 role nni outer_tpid 0x88A8 trust_cvid disable vlan_translation disable
config gvrp 1-24,26-28 state disable ingress_checking enable acceptable_frame admit_all pvid 2003
config gvrp 25 state disable ingress_checking enable acceptable_frame tagged_only pvid 2
# PROTOCOL_VLAN
# SNOOP
enable igmp_snooping
config igmp_snooping data_driven_learning max_learned_entry 56
enable igmp_snooping multicast_vlan
create igmp_snooping multicast_vlan video 200
config igmp_snooping multicast_vlan video state enable
config igmp_snooping multicast_vlan video add member_port 1-24
config igmp_snooping multicast_vlan video add source_port 25
config igmp_snooping vlan_name default state disable fast_leave disable
config igmp_snooping data_driven_learning vlan_name default aged_out disable
config igmp_snooping querier all query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping vlan_name native state disable fast_leave disable
config igmp_snooping data_driven_learning vlan_name native aged_out disable
config igmp_snooping vlan_name 20 state disable fast_leave disable
config igmp_snooping data_driven_learning vlan_name 20 aged_out disable
config igmp_snooping vlan_name video fast_leave disable
config igmp_snooping data_driven_learning vlan_name video aged_out disable
config igmp_snooping vlan_name 2003 state disable fast_leave disable
config igmp_snooping data_driven_learning vlan_name 2003 aged_out disable
config igmp access_authentication ports 1-28 state disable
# FDB
чего нехватает?
СообщениеДобавлено: Пт июн 18, 2010 15:02
config igmp_s vlan 2003 sta ena
Сейчас этот форум просматривают: Baidu [Spider] и гости: 85
