Текущее время: Вт окт 06, 2026 03:26
 Заголовок сообщения: DGS3612G + Mikrotik RB450G - настройка OSPF
СообщениеДобавлено: Чт ноя 26, 2009 22:13
Доброго времени суток.
Нужна помощь в настройке OSPF в связке DGS3612G + Mikrotik RB450G.
mikrotik
[admin@MikroTik] /ip route> print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
B - blackhole, U - unreachable, P - prohibit
 #      DST-ADDRESS        PREF-SRC        GATEWAY-STATE GATEWAY                       DISTANCE INTERFACE
 0 A S  0.0.0.0/0                          reachable     195.58.208.1                  1        ether5
 1 ADC  10.0.0.0/24        10.0.0.2                                                    0        ether1
 2 ADC  192.168.7.0/24     192.168.7.1                                                 0        ether2
 3 ADC  192.168.8.0/24     192.168.8.1                                                 0        ether3
[admin@MikroTik] /routing ospf> print
               router-id: 10.0.0.2
      distribute-default: never
  redistribute-connected: as-type-1
     redistribute-static: as-type-1
        redistribute-rip: no
        redistribute-bgp: no
          metric-default: 1
        metric-connected: 20
           metric-static: 20
              metric-rip: 20
              metric-bgp: 20
            mpls-te-area: unspecified
       mpls-te-router-id: unspecified
[admin@MikroTik] /routing ospf neighbor> print
 0 router-id=10.0.0.1 address=10.0.0.1 interface=ether1 priority=1 dr-address=10.0.0.1 backup-dr-address=0.0.0.0
   state="Init" state-changes=3 ls-retransmits=0 ls-requests=0 db-summaries=0
[admin@MikroTik] /routing ospf lsa> print
AREA                                              TYPE         ID             ORIGINATOR     SEQUENCE-NUMBER AGE
backbone                                          router       10.0.0.2       10.0.0.2       0x80000002      1504
external                                          as-external  192.168.7.0    10.0.0.2       0x80000002      1504
external                                          as-external  192.168.8.0    10.0.0.2       0x80000002      1504
external                                          as-external  195.58.208.0   10.0.0.2       0x80000002      1504
[admin@MikroTik] /routing ospf area> print
Flags: X - disabled
 #   NAME        AREA-ID         TYPE    DEFAULT-COST
 0   backbone        0.0.0.0         default
D-link
DGS-3612G:5#sh iproute
Command: show iproute
Routing Table
IP Address/Netmask  Gateway          Interface     Cost      Protocol
0.0.0.0/0           195.58.208.15   inet_in      1         Default
10.0.0.0/24         0.0.0.0          iface10       1         Local
192.168.0.0/24      0.0.0.0          iface0        1         Local
192.168.1.0/24      0.0.0.0          iface1        1         Local
Total Entries : 7
DGS-3612G:5#show route redistribute
Command: show route redistribute
Route Redistribution Settings
Source    Destination   Type      Metric
Protocol  Protocol
LOCAL     OSPF          Type-1    20
Total Entries : 1
DGS-3612G:5#show ospf neighbor
Command: show ospf neighbor
IP Address of   Router ID of    Neighbor Neighbor
Neighbor        Neighbor        Priority State
Total Entries : 0
DGS-3612G:5#show ospf lsdb
Command: show ospf lsdb
Area            LSDB      Advertising     Link State         Cost     Sequence
ID              Type      Router ID       ID                          Number
0.0.0.0         RTRLink   10.0.0.1        10.0.0.1/0         *        0x80000009
0.0.0.0         ASExtLink 10.0.0.1        172.16.0.0/16      20       0x80000003
0.0.0.0         ASExtLink 10.0.0.1        192.168.0.0/24     20       0x80000003
0.0.0.0         ASExtLink 10.0.0.1        192.168.1.0/24     20       0x80000003
0.0.0.0         ASExtLink 10.0.0.1        195.58.208.0/27    20       0x80000003
Total Entries: 6
DGS-3612G:5#show ospf area
Command: show ospf area
OSPF Area Settings
Area ID         Type   Stub Import Summary LSA Stub Default Cost Translate
0.0.0.0         Normal None                    None              None
Total Entries : 1
У кого получилось подружить DGS3612G с микротиком RB450g в
связке по OSPF?
Прошивки:
MikroTik RouterOS 3.30 (c) 1999-2009
Boot PROM Version Build 1.10-B06
Firmware Version Build 2.40.B77
Hardware Version 1A1G
СообщениеДобавлено: Пт ноя 27, 2009 12:41
Вот схема проведения тестирвания:
192.168.0.0/24                                  192.168.7.0/24
D-Link DGS3612G-10.0.0.1/24---------10.0.0.2/24-Mikrotik RB450G
192.168.1.0/24                                  192.168.8.0/24
Кто может поделиться опытом?
СообщениеДобавлено: Пт ноя 27, 2009 14:56
Сначала обновите пожалуйста BootPROM и прошивку на те что я Вам выслал.
СообщениеДобавлено: Пт ноя 27, 2009 17:38
Получил только xStackIIProm_1.10-B09.had
Повторите, пожалуйста!
СообщениеДобавлено: Пт ноя 27, 2009 17:39
Выслал.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 61
