Текущее время: Вт окт 06, 2026 19:48
 Заголовок сообщения: DGS-3610-26G и GVRP
СообщениеДобавлено: Ср мар 11, 2009 09:37
Добрый день!
Схема такая:
DES-3526 (port 26) - (port 1) DGS-3610-26G (port 2) - (port 26) DES-3526
25 и 26 порты на DES-3526 как untagged в default vlan
1-24 на DES-3526 как untagged в vlan с vlanid 10
Конфиг 3526:
create vlan old tag 10
config vlan old advertisement enable
config vlan default delete 1
config vlan vlanid 10 add untagged 1
config vlan default delete 2
config vlan vlanid 92 add untagged 2
config vlan default delete 3
config vlan vlanid 10 add untagged 3
config vlan default delete 4
config vlan vlanid 10 add untagged 4
config vlan default delete 5
config vlan vlanid 10 add untagged 5
config vlan default delete 6
config vlan vlanid 10 add untagged 6
config vlan default delete 7
config vlan vlanid 10 add untagged 7
config vlan default delete 8
config vlan vlanid 10 add untagged 8
config vlan default delete 9
config vlan vlanid 10 add untagged 9
config vlan default delete 10
config vlan vlanid 10 add untagged 10
config vlan default delete 11
config vlan vlanid 10 add untagged 11
config vlan default delete 12
config vlan vlanid 10 add untagged 12
config vlan default delete 13
config vlan vlanid 10 add untagged 13
config vlan default delete 14
config vlan vlanid 10 add untagged 14
config vlan default delete 15
config vlan vlanid 10 add untagged 15
config vlan default delete 16
config vlan vlanid 10 add untagged 16
config vlan default delete 17
config vlan vlanid 10 add untagged 17
config vlan default delete 18
config vlan vlanid 10 add untagged 18
config vlan default delete 19
config vlan vlanid 10 add untagged 19
config vlan default delete 20
config vlan vlanid 10 add untagged 20
config vlan default delete 21
config vlan vlanid 10 add untagged 21
config vlan default delete 22
config vlan vlanid 10 add untagged 22
config vlan default delete 23
config vlan vlanid 10 add untagged 23
config vlan default delete 24
config vlan vlanid 10 add untagged 24
config vlan default add untagged 25
config vlan default add untagged 26
enable gvrp
config gvrp 1 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 2 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 3 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 4 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 5 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 6 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 7 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 8 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 9 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 10 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 11 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 12 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 13 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 14 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 15 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 16 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 17 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 18 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 19 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 20 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 21 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 22 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 23 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 24 state disabled ingress_checking enable acceptable_frame admit_all pvid 10
config gvrp 25 state enable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 26 state enable ingress_checking disable acceptable_frame admit_all pvid 1
Конфиг 3610-26G
gvrp enable
gvrp dynamic-vlan-creation enable
interface GigabitEthernet 0/1
 switchport mode trunk
interface GigabitEthernet 0/2
Таким образом на 3526 26-е порты становятся tagged в vlanid 10, а на 3610-26G появляется vlan DVLAN0010 и все как бы работает.
Теперь делаем
vlan 10
name test
и
int vlan 10
ip address 10.0.0.1 255.0.0.0
Теперь на 3526 порты 26 не включатся в vlan с id 10, а на 3627G при аналогичной схеме включаются.
Что я делаю не так?
СообщениеДобавлено: Ср мар 11, 2009 22:08
Никто не знает?
СообщениеДобавлено: Ср мар 11, 2009 22:12
Т.е. Вы имеете ввиду что в последнем случае если вместо DGS-3610-26G поставить DGS-3627G то у Вас всё равно работает?
СообщениеДобавлено: Ср мар 11, 2009 22:22
Что значит все равно?
В одном месте в такой схеме стоит 3627 - там работает, а в другом 3610-26G - там не работает. так вот не могу понять что не так настроено...
СообщениеДобавлено: Ср мар 11, 2009 22:23
Да, Вы правы динамические VLAN не отображаются, но они работают.
Попробуйте с svi 10 пропинговать компютеры на DES-3526, должен идти ответ.
СообщениеДобавлено: Ср мар 11, 2009 22:36
Не отображаются где? На 3526?
Ответ не идет...
СообщениеДобавлено: Ср мар 11, 2009 22:41
Так Вы же его на DGS-3610-XX в явном виде создали! Как же Вы хотите чтобы он пробрасывался?
СообщениеДобавлено: Ср мар 11, 2009 22:42
на 3610 не отображаются.
соберите схему, запустите команду debug gvrp, отключите-включите порт 26, попробуйте запусть пинг с dgs3610 на компьютеры в диапазоте 10.0.0.0/8, подключенные к des-3526.
Если пинга не будет, то конфиги коммутаторов и выводе debug пришлите пожалуйста мне на почту.
СообщениеДобавлено: Ср мар 11, 2009 22:45
хорошее дополнение, покажите пожалуйста:
sh int gigabitEthernet 0/1 trunk
СообщениеДобавлено: Ср мар 11, 2009 23:28
Да мне не нужно чтобы он пробрасывался, мне нужно чтоб на 3526 26 порт становился tagged в vlan 10.
СообщениеДобавлено: Ср мар 11, 2009 23:30
Так не получится. Укажите в личку Ваш телефон пожалуйста.
СообщениеДобавлено: Ср мар 11, 2009 23:31
А на 3627 получается...
Телефон сбросил.
СообщениеДобавлено: Пт мар 13, 2009 12:00
мне так никто и не перезвонил...
Поставлю вопрос подругому.
Вот есть у меня ксажем 3627. на нем на всех портах есть untagged default и tagged 10,20,30 и включен gvrp. К нему подключен 26 портом 3526 в 1 порт, к которыму допустим подключен еще один 3526 26 портом к 25 порту первого 3526, т.е.
3526(26 порт) - (25 порт)3526(26 порт) - (1 порт)3627
На крайнем свиче порты 1-24 я делаю Untagged vlan 20, на среднем untagged vlan 10, настраиваю GVRP на всех свичах, прописываю в vlan 10 и vlan 20 на 3627 ip-интерфейсы. Т.е. все пробрасывается и клиенты соответственно пингуют свои интерфейсы.
Как реализовать такое на 3610-26G?
СообщениеДобавлено: Сб мар 14, 2009 22:52
Я думаю после телефонного звонка направление стало понятнее. Пришлите пожалуйста то что я Вас просил.
Сейчас этот форум просматривают: Google [Bot] и гости: 53
