Текущее время: Ср окт 07, 2026 00:30
 Заголовок сообщения: Проблема с Asymmetric VLAN на DES-3028
СообщениеДобавлено: Пт ноя 28, 2008 17:11
Прошивка v.2.00 B24, получил вчера.
Не заработало вот в такой конфигурации:
enable asymmetric_vlan
config vlan default delete 1-28
config vlan default add untagged 1-15,18-21,25-28
config vlan default advertisement disable
create vlan Servers tag 9
config vlan Servers add untagged 1,20-22,26
create vlan Inet tag 10
config vlan Inet add untagged 17,24
create vlan Ournet tag 11
config vlan Ournet add untagged 16,23
enable gvrp
config gvrp 1 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 2 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 3 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 4 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 5 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 6 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 7 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 8 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 9 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 10 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 11 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 12 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 13 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 14 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 15 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 16 state disable ingress_checking disable acceptable_frame admit_all pvid 11
config gvrp 17 state disable ingress_checking disable acceptable_frame admit_all pvid 10
config gvrp 18 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 19 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 20 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 21 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 22 state disable ingress_checking disable acceptable_frame admit_all pvid 9
config gvrp 23 state disable ingress_checking disable acceptable_frame admit_all pvid 11
config gvrp 24 state disable ingress_checking disable acceptable_frame admit_all pvid 10
config gvrp 25 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 26 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 27 state disable ingress_checking disable acceptable_frame admit_all pvid 1
config gvrp 28 state disable ingress_checking disable acceptable_frame admit_all pvid 1
По идее порт 22 в одном VLAN с 1,20,21 и 26. Так же порты 1,20,21 и 26 присутствуют и в Default VLAN, порт 22 они не видят, хотя по смыслу должны. Ткните носом, что не так?
P.S.: При смене PVID например на 1-м порту на 9, он начинает видеть порт 22, но пересает быть видимым в Default VLAN.
 Заголовок сообщения: Re: Проблема с Asymmetric VLAN на DES-3028
СообщениеДобавлено: Пт ноя 28, 2008 18:21
Пожалуйста, опишите задачу, которую Вы хотите решить.
Бигаров Руслан.
СообщениеДобавлено: Пт ноя 28, 2008 18:56
Есть 4 сервера, которые должны быть доступны в Default VLAN, но так же должны иметь доступ к 22 порту, откуда они могуть взять Интернет, т.е. в 22 порт подключен шлюз.
P.S.: Сегментацию трафика не предлагайте, сейчас именно так все и работает. Нужно перейти на Asymmetric VLAN.
СообщениеДобавлено: Сб ноя 29, 2008 17:02
Те порты которые Вы хотите сделать общими (нетегированные в нескольких VLAN-ах) должны быть наряду с портами из которых нужен доступ к ним добавлены в один VLAN. Но PVID равный VID этого VLAN-а должен быть прописан только на общих портах. На клиентских портах PVID должен быть равен VID клиентских VLAN-ов.
СообщениеДобавлено: Сб ноя 29, 2008 18:15
Так у меня по сути так и есть, у 22 порта VID = 9, у всех остальных которые должны иметь доступ к нему VID = 1, но они так же входят и в VLAN9.
СообщениеДобавлено: Сб ноя 29, 2008 21:13
Перезвоните пожалуйста в понедельник в офис по телефону 744-00-99 доб.390.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 58
