Текущее время: Вс июн 28, 2026 23:09
СообщениеДобавлено: Вт янв 15, 2008 06:22
раньше было:
ommand: show ports
Port Port       Settings               Connection             Address  Trap
     State/MDI  Speed/Duplex/FlowCtrl  Speed/Duplex/FlowCtrl  Learning State
1     En/Auto    Auto/Disabled          100M/Full/None         Enabled  Enabled
2     Dis/Auto   Auto/Disabled          Link Down              Enabled  Enabled
3     En/Auto    Auto/Enabled           100M/Full/None         Enabled  Enabled
4     En/Auto    Auto/Enabled           Link Down              Enabled  Enabled
5     En/Auto    Auto/Enabled           100M/Full/None         Enabled  Enabled
6     En/Auto    Auto/Enabled           100M/Full/None         Enabled  Enabled
7     Dis/Auto   10M/Full/Enabled       Link Down              Enabled  Enabled
8     En/Auto    Auto/Enabled           Link Down              Enabled  Enabled
9     En/Auto    Auto/Enabled           100M/Full/None         Enabled  Enabled
10    En/Auto    Auto/Enabled           Link Down              Enabled  Enabled
11    En/Auto    Auto/Enabled           Link Down              Enabled  Enabled
12    En/Auto    Auto/Enabled           100M/Full/None         Enabled  Enabled
13    En/Auto    Auto/Enabled           Link Down              Enabled  Enabled
14    Dis/Auto   Auto/Enabled           Link Down              Enabled  Enabled
15    En/Auto    Auto/Enabled           100M/Full/None         Enabled  Enabled
16    En/Auto    Auto/Enabled           100M/Full/None         Enabled  Enabled
17    En/Auto    Auto/Enabled           Link Down              Enabled  Enabled
18    En/Auto    Auto/Enabled           100M/Full/None         Enabled  Enabled
19    En/Auto    Auto/Enabled           100M/Full/None         Enabled  Enabled
20    En/Auto    Auto/Enabled           Link Down              Enabled  Enabled
21    En/Auto    Auto/Disabled          100M/Full/None         Enabled  Enabled
22    En/Auto    Auto/Disabled          Link Down              Enabled  Enabled
23    En/Auto    Auto/Disabled          Link Down              Enabled  Enabled
24    En/Auto    Auto/Disabled          100M/Full/None         Enabled  Enabled
25    En/Auto    Auto/Disabled          Link Down              Enabled  Enabled
26    En/Auto    Auto/Disabled          Link Down              Enabled  Enabled
и особенно было удобно использовать команду config terminal_line 30
все 26 портов умещались на один экран
теперь стало крайне неудобно:
Command: show ports
Port  State/     Settings              Connection             Address  Trap
      MDIX       Speed/Duplex/FlowCtrl Speed/Duplex/FlowCtrl  Learning State
1     Enabled    Auto/Enabled          Link Down              Enabled  Enabled
      Auto
2     Enabled    Auto/Enabled          Link Down              Enabled  Enabled
      Auto
3     Enabled    Auto/Enabled          Link Down              Enabled  Enabled
      Auto
4     Enabled    Auto/Enabled          Link Down              Enabled  Enabled
      Auto
5     Enabled    Auto/Enabled          Link Down              Enabled  Enabled
      Auto
6     Enabled    Auto/Enabled          Link Down              Enabled  Enabled
      Auto
7     Enabled    Auto/Enabled          Link Down              Enabled  Enabled
      Auto
8     Enabled    Auto/Enabled          Link Down              Enabled  Enabled
      Auto
9     Enabled    Auto/Enabled          Link Down              Enabled  Enabled
      Auto
10    Enabled    Auto/Enabled          Link Down              Enabled  Enabled
      Auto
11    Enabled    Auto/Enabled          Link Down              Enabled  Enabled
      Auto
12    Enabled    10M/Half/Enabled      Link Down              Enabled  Enabled
      Auto
13    Enabled    Auto/Enabled          Link Down              Enabled  Enabled
      Auto
плотность отображение информации низкая, чтобы посмотреть все порты надо пролистать вдвое больше
визуальное восприятие намного хуже
вернете ли назад? как было во всех предыдущих прошивках, один порт одна строка
описания портов вообще стали выглядеть неудобочитаемо, по три строчки на порт
Command: show ports description
      Auto
 Description:
      Auto
 Description:
      Auto
 Description:
      Auto
 Description:
      Auto
 Description:
      Auto
 Description:
      Auto
 Description:
      Auto
 Description:
сделали бы как sis на cisco
верните show ports как было
СообщениеДобавлено: Вт янв 15, 2008 20:00
Нет к сожалению это не выйдет. Там подготовили поля для ещё одной настройки MDI/MDI-X.
СообщениеДобавлено: Ср янв 16, 2008 08:50
очень жаль, думаю я такой не один
в строке еще много свободного места, можно что либо другое подсократить...
следует ожидать следующей прошивки с какой то новой опцией?
СообщениеДобавлено: Ср янв 16, 2008 14:37
Конечно будет новый релиз со многими функциями и улучшениями, но эта функция как я и указал конфигурирование MDI/MDI-X.
СообщениеДобавлено: Чт янв 17, 2008 05:57
жаль, программисты никогда не отличались стремлением к эргономике
