Текущее время: Чт окт 29, 2026 04:37
 Заголовок сообщения: Кол-во мас на DAS4192
СообщениеДобавлено: Чт апр 23, 2009 11:28
Здравствуйте!
на DAS4192 с помощью Fast Provision создал vc-vlan, далее при попытке изменить в окне VC-to-VLAN setting mac-limit до большего значения например 6 и соответственно DHCP IP Limit - 6
выдает ошибку:
Error 1: All enabled PVCs' IP limit amount on this LC can't be greater than 108
Глобально мас-лимит на вилане стоит в disable
CLI(config ucast)# show vc-vlan
port ID  VPI/VCI     IP-traffic    VLAN 1p MAC RFC2684  next-hop   admin   oper
   1. 1   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1. 2   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1. 3   8/   35         adsl_all  119  0   3 bridged             enabled   up
   1. 4   8/   35         adsl_all 2028  0   2 bridged             enabled   up
   1. 5   8/   35         adsl_all  119  0   3 bridged             enabled   up
   1. 6   8/   35         adsl_all  119  0   3 bridged             enabled   up
   1. 7   8/   35         adsl_all  119  0   3 bridged             enabled   up
   1. 8   8/   35         adsl_all  119  0   3 bridged             enabled   up
   1. 9   8/   35         adsl_all  119  0   3 bridged             enabled   up
   1.10   8/   35         adsl_all  119  0   3 bridged             enabled   up
   1.11   8/   35         adsl_all  119  0   3 bridged             enabled   up
   1.12   8/   35         adsl_all  119  0   3 bridged             enabled   up
   1.13   8/   35         adsl_all  119  0   3 bridged             enabled   up
   1.14   8/   35         adsl_all  119  0   3 bridged             enabled   up
   1.15   8/   35         adsl_all  119  0   3 bridged             enabled   up
   1.16   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.17   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.18   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.19   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.20   8/   35         adsl_all 2028  0   2 bridged             enabled   up
   1.21   8/   35         adsl_all 2028  0   2 bridged             enabled   up
   1.22   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.23   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.24   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.25   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.26   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.27   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.28   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.29   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.30   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.31   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.32   8/   35         adsl_all 2028  0   2 bridged             enabled   up
   1.33   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.34   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.35   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.36   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.37   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.38   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.39   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.40   8/   35         adsl_all 2028  0   4 bridged             enabled   up
   1.41   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.42   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.43   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.44   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.45   8/   35         adsl_all  119  0   2 bridged             enabled   up
   1.46   8/   35         adsl_all  119  0   1 bridged             enabled   up
   1.48   8/   35         adsl_all  119  0   3 bridged             enabled   up
СообщениеДобавлено: Чт апр 23, 2009 12:12
Здравствуйте,
Да, есть подобное ограничение на количество MAC адресов на LC модуль (105), но только в том случае если включен STC функционал (глобально в настройках LC).
Таким образом нужно укладываться в этот лимит при создании VC-to-VLAN соединений (если "домашний" пользователь - 1 MAC, корпоративу - n MAC'ов).
Если нужно больше - выключайте STC глобально в настройках модуля.
Иного решения нет.
С уважением, Давыдов Денис.
СообщениеДобавлено: Пт апр 24, 2009 11:01
из мануала Service Type Control служит для определения типа доступа (типа присвоения IP адреса клиенту) на линейном модуле
если я его выключу будет ли клиент получать IP от внешнего DHCP сервера? и каков тогда будет лимит мас адресов
дслам используется как бридж тип соединения PPTP
СообщениеДобавлено: Пт апр 24, 2009 11:32
Да, клиент будет получать IP без проблем.
В данном случае поддерживается 384 MAC адреса на линейную плату.
СообщениеДобавлено: Пн апр 27, 2009 13:16
переставил Service type control в disable
и VTP в disable,
попробовал изменить DHCP limit и MAClimit до 5 адресов на порт
опять выдал ошибку Error 1: All enabled PVCs' IP limit amount on this LC can't be greater than 108
CLI(config lc)# show
        planned  current  rfc2684
    LC   type     type     encap     VTP       STC      tagged-mode
     1     ADSL     ADSL      LLC  disabled  disabled  untagged-only
     2     ADSL     ADSL      LLC  disabled  disabled  untagged-only
     3     ADSL     ADSL      LLC  disabled  disabled  untagged-only
     4     ADSL     ADSL      LLC  disabled  disabled  untagged-only
CLI(config ucast)# show vc-vlan 1.36
   1.36   8/   35         adsl_all 2028  0   3 bridged             enabled   up
CLI(config ucast)# show service-type 1.36
        DHCP/
 port           RFC2684   STC      runtime         configured    static-IP
  ID   VPI/VCI    mode   status   service-type    service-type   IP limit
 1.36   8/   35 bridged disabled     pure-bridge            DHCP      3/ 0
CLI(config ucast)# show mac-limit 1.36
port ID   VPI/VCI   mac-limit
   1.36    8/   35          3
СообщениеДобавлено: Пн апр 27, 2009 13:42
проблема в общем в том, что у абонента находится 2 девайса: ТВприставка и ПК (2мас адреса на порту), при подключении они соответственно получают IP, и работают, но через минут 10 - 15, мас одного из них на порту дслама теряется и один девайс (ПК или приставка) перестает работать.
Приходится перезапускать интерфейс девайса
СообщениеДобавлено: Вт апр 28, 2009 09:24
Здравствуйте,
Назовите пожалуйста версию прошивки устройства (status nc show).
СообщениеДобавлено: Вт апр 28, 2009 11:52
Вот
CLI# status nc show
NC
current card type : CPU Module
planned card type : CPU Module
role : active
hardware version : DAS-4192-10-00
software version : v2.5.0 build 67
serial number : DAS-4192-10-617CA054759
oper status : up
system up time : 1day / 1hr / 24min / 22sec
tagged mode : tagged-only
CLI#[/code]
с новой прошивкой у меня так и не получилось зацепиться по SNMP
СообщениеДобавлено: Вт апр 28, 2009 12:30
To art46013
С новой прошивкой - это с какой?
Не удалось зацепиться по SNMP - Вы имеете ввиду не работает LCT?
