Текущее время: Чт окт 29, 2026 19:14
 Заголовок сообщения: Проблема с DAS-3224
СообщениеДобавлено: Пн июн 23, 2008 16:12
Здравствуйте.
Имеем при загрузке следующее:
Welcome to IP DSLAM
Software Release: D.2.12.i1000.ADSL2+.A (COL2.10.2.0.051206) Date: Aug 24 2006
Initializing Memories............. Success
Press F1 to enter Interactive Mode, 'Enter' to skip ... 5 seconds left
Transfering Control to BootTftp binary
Flash Present In System
Flash size read in progress
Flash Address 0x00: 89
Flash Address 0x02: 16
Flash size: 4M
.......Flash size read successful...
g_u32FlashSize : 4194304
g_u32FlashBlockSize: 131072
All the files are in Flash, No TFTP required
System shall come up in normal mode
All the files have been successfully received.....
Active copy of Ctrl Plane Bin was found in flash
Unzipping the Control Plane................................................................................................................................................................................................................
Transferring Control to Ctrl Plane Binary...
Flash size: 4M
psCPInfo->u32FlashSize : 4194304
psCPInfo->u32FlashBlockSize: 131072
Free Memory available in SDRAM-A is 0x2b8200
System coming up in normal mode...
Locking Control Plane Text Start: 0x4923000 End: 0x4f301b0
Allocatiing System Memory fom SDRAM-E
total memory Free in SDRAM E = 196608
total memory Free in SDRAM D = 0
total memory Free in SDRAM B = 409222
Flash size: 4M
g_u32FlashNumBlocks: 32
Flash scanning in progress.............................
No space available in flash for requested device size
The device won't be used
CdbNvm:- Configuration Size is 1961756
CdbNvm:- NVM CFG1 size 262032
CdbNvm:- NVM CFG2 size 262032
NVM_DEV_LOGS open fails
The uncompress location for data plane is 0x400b000
Cin:- DataPlane present in NVRAM
Cin- Uncompressing Dataplane
Uncompressing "DP.bin.gz" (382933->848776) ...... Done
Locking Text Area DP Text Start: 0x4818000 CP Text End : 0x4f301b0
CfgInit: System Coming up from Minimum Configuration
Initializing DataPlane
DataPlane Initialized successfully
Welcome to IP DSLAM
<CO-0011951101C9>
login:
Все интерфейсы лежат, связь с устройством возможна только через консоль. Можно что-нибудь сделать?
СообщениеДобавлено: Вт июн 24, 2008 09:24
Попробуйте перезагрузить устройство в Safe конфигурации и перепрошить стандартным методом. Если это не приведет к положительным результатам, выход только один - обращение в сервисный центр D-Link.
С уважением, Давыдов Денис.
