Текущее время: Сб окт 31, 2026 15:44
 Заголовок сообщения: DAS-3224 При загрузке GagSetActD1xPort: Error
СообщениеДобавлено: Вт фев 26, 2008 09:57
Добрый день, такая же тема была закрыта, поэтому пришлось открыть новую. Перепрошил платформу DAS-3224 rev.A прошивкой IP4824_FLASH_V307_IP1000_AnnexA_D-Link.bin.gz. После установки ограничения скорости на портах и модуляции на gDMT при загрузке начинают появляться надписи(24 шт.):
GagSetActD1xPort: Error: Please Enable D1x system first!!!
$ reboot
 Rebooь
                         Welcome to IP DSLAM
 Software Release: D.3.07.i1000.ADSL2+.A (COL2.10.3.2.070221) Date: Sep  5 2007
 Initializing Memories............. Success
 Press F1 to enter Interactive Mode, 'Enter' to skip ... 5 seconds left
 Transfering Control to BootTftp binary
 Flash Present In System
 Flash size read in progress
 Flash Address 0x00: 89
 Flash Address 0x02: 16
 Flash size: 4M
 .......Flash size read successful...
 g_u32FlashSize     : 4194304
 g_u32FlashBlockSize: 131072
 All the files are in Flash, No TFTP required
 System shall come up in normal mode
 All the files have been successfully received.....
 Active copy of Ctrl Plane Bin was found in flash
 Unzipping the Control Plane..................................................................................................................................................................................................................................
 Transferring Control to Ctrl Plane Binary...
 Flash size: 4M
 psCPInfo->u32FlashSize     : 4194304
 psCPInfo->u32FlashBlockSize: 131072
 Free Memory available in SDRAM-A is 0x24a5f8
 System coming up in normal mode...
 Locking Control Plane Text Start: 0x4923000 End: 0x4efa150
 total memory Free in SDRAM A = 2401784
 Allocatiing System Memory fom SDRAM-E
 total memory Free in SDRAM E = 196608
 total memory Free in SDRAM D = 0
 total memory Free in SDRAM B = 350812
 Flash size: 4M
 g_u32FlashNumBlocks: 32
 Flash scanning in progress.............................
No space available in flash for requested device size
The device won't be used
RootMain: 1388:: configureHostBusIntfCtrlReg()
RootMain: 1393:: check_hw_ver()
check_hw_ver: 256B EE 1st Byte = 0
  IP4800_sBootConfig.sDslInfo.u32ChipType = 0
  IP4800_sBootConfig.sDslInfo.s32NumChips = 1
ParseManufSection: Enter
ProcessManufInfo: Enter
ProcessManufInfo: PH1, Use PH1 Port Map
ProcessManufInfo: Exit
 CdbNvm:- Configuration Size is 2086812
 CdbNvm:- NVM CFG1 size 262032
NVM_DEV_LOGS open fails
CdbNvm:- Device not Opened before Ioctl
 NVM_DEV_CONFIG2 IoCtl failed
create d1x_tkb & PIPE Start >>>
Total Bridge Number : 0
IP4800_Dsl_Maint_Init: Enter
dslme_main.c(1037):IP4800_Dsl_Maint_Init::NU_Create_Timer(IP4800_DSL_MAINT_TMR) OK
 The uncompress location for data plane is 0x400b000
 Cin:- DataPlane present in NVRAM
 Cin- Uncompressing Dataplane
 Uncompressing "DP.bin.gz" (385214->840232) ...... Done
 Locking Text Area DP Text Start: 0x4818000 CP Text End : 0x4efa150 B1X_tsk-- set RADR_OPEN_SOCKET_EVT  OK
  RADR_tsk rx RADR_OPEN_SOCKET_EVT==> GSIPOpen OK
 DOes this means SRVR exist ?? or Ping srvr's IP to discover SRVR exist ??
 DO we need to CHK SRVR's secret OK or NOT ??? to authenticate 4800 myself????
 CfgInit: System Coming up from Last Configuration
Uncompress:- UnZipLen: 55473, ZipLen: 4860
 Initializing DataPlane
 DataPlane Initialized successfully
The DSL binary file to be opened is dsl_10_330000003C00000D.bin.gz
The DSL bin size is 263471
Loading The system.....
Loading system over.....
Initializing system.....
Initializing system over.....
                         Welcome to IP DSLAM
 <CO-001346C9299D>
login:        Admin
password:
Login Successful
собственно платформа работает и модемы на нее линкуются... но как-то не спокойно себя чуствуется... т.к. не нашел нигде описания об этом.
СообщениеДобавлено: Вт фев 26, 2008 10:46
Это диагностическое сообщение системы о невозможности активации функции 802.1x.
На работоспособность устройства это никак не повлияет.
С уважением, Давыдов Денис.
СообщениеДобавлено: Вт фев 26, 2008 11:07
Благодарю за столь быстрый ответ.
