Текущее время: Чт окт 22, 2026 21:44
 Заголовок сообщения: Backuping
СообщениеДобавлено: Пн окт 05, 2009 11:24
############## DAS-3224################
$ get system info
Description : 000000000000000000000000000000000000000010000000
Name :
Contact :
Vendor :
LogThreshold : 0
Object-id : 1.3.6.1.4.1.171.10.65.1
Up Time(HH:MM:SS) : 0:29:53
HwVersion : ADSL-1.0
CPLDVersion : 1.9
CPSwVersion : COL2.10.3.2.070221
CPSwVersion(Build): D.3.07.i1000.ADSL2+.A PRIMARY (GS_API_654/E.67.1.69)
DPSwVersion : DP_B02_10_28_04_ip1000a
System Time : Thu Jan 01 00:29:53 1970
Time Zone : GMT
DST : off
Services : physical datalink internet end-to-end applications
$ get ip address
Ip Address Mask IfName BCast Addr MaxReasm
10.90.91.91 255.255.255.0 eth-2 1 65535
127.0.0.1 255.0.0.0 - 1 65535
172.31.16.202 255.255.255.0 eth-0 1 65535
$ get ip route
Rid : 0 Destination : 0.0.0.0
Net Mask : 0.0.0.0 Gateway : 172.31.16.1
Ifname : eth-0 Route Type : IND
Route Orig : LCL Age : 0
ProxyArpStatus : -
$ list
Flash size : 8388608
Flash Block size : 131072
Free Blocks in Flash : 31
Number of Compact Blocks :0
Page Size :4096
Number of Free Pages :0
/nvram/bin/control/
Version : 1 Size(bytes) : 2413915
Time : Wed Sep 05 17:13:36 2007
Permission : RW State : active
Used Blocks : 19
/nvram/bin/dataplane/
Version : 1 Size(bytes) : 385258
Used Blocks : 3
/nvram/bin/dslphy/
Version : 1 Size(bytes) : 263471
Used Blocks : 3
/nvram/cfg/factorydef/
Version : 1 Size(bytes) : 13949
Used Blocks : 1
/nvram/system/
Version : 1 Size(bytes) : 262032
Time :
Permission : SYS State : active
Used Blocks : 2
Version : 1 Size(bytes) : 130964
Time :
Used Blocks : 1
$ ping 10.2.142.162
64 bytes of data from 10.2.142.162, seq=0 ttl=60 rtt =20 msec
64 bytes of data from 10.2.142.162, seq=1 ttl=60 rtt =10 msec
64 bytes of data from 10.2.142.162, seq=2 ttl=60 rtt =10 msec
$ upload src /nvram/system/primcfg dest primcfg ip 10.2.142.162 mode tftp
Uploading the File...
Upload Network error...
##################################### Server##################
[root@rs /tftpboot]# tcpdump -s 1500 src 172.31.16.202
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on em0, link-type EN10MB (Ethernet), capture size 1500 bytes
15:55:40.437645 IP 172.31.16.202.2388 > rs.krasnet.ru.tftp: 29 WRQ "primcfg" octet tsize 262136
15:55:40.452389 IP 172.31.16.202.2388 > rs.krasnet.ru.65459: UDP, length 516
15:55:45.450841 IP 172.31.16.202.2388 > rs.krasnet.ru.65459: UDP, length 516
15:55:50.450420 IP 172.31.16.202.2388 > rs.krasnet.ru.65459: UDP, length 516
15:55:55.450499 IP 172.31.16.202.2388 > rs.krasnet.ru.65459: UDP, length 516
15:56:00.461071 IP 172.31.16.202 > rs.krasnet.ru: ICMP 172.31.16.202 udp port 2388 unreachable, length 36
TFTP server настроен верно. С других IPDSLAM'ов (Zyxel, Huawei, Bosh, Gorenje и т.д.) забираем конфиги. нормально.
То, что по команде list не отображается файл primcfg нормально?
И, вообще, скажите что за фигня?
СообщениеДобавлено: Пн окт 05, 2009 12:02
Какой именно TFTP сервер используется? Стандартный tftpd?
Я использую FreeBSD 6.0 с tftp-hpa-0.40 и все "сливается" нормально.
Попробуйте в директории tftpboot создать пустой файл primcfg c полными правами на чтение и запись и попробовать "слить" конфиг снова.
P.S. CFG1 в листинге DSLAM - это ничто иное как primcfg.
С уважением, Давыдов Денис.
