Текущее время: Чт окт 29, 2026 05:02
СообщениеДобавлено: Сб авг 06, 2011 10:13
По незнанию das-3224 verB1 был прошит не той прошивкой (das-3224 без B1 2.12) . При загрузке виснет, консоль не заводится. Прошу помощи в оживлении девайса. Вот лог загрузки
Welcome to IP DSLAM
Software Release: D.2.12.i1000.ADSL2+.A (COL2.10.2.0.051206) Date: Aug 24 2006
Initializing Memories............. Success
Press F1 to enter Interactive Mode, 'Enter' to skip ... 5 seconds left
Transfering Control to BootTftp binary
Flash Present In System
Flash size read in progress
Flash Address 0x00: 89
Flash Address 0x02: 16
Flash size: 4M
.......Flash size read successful...
g_u32FlashSize : 4194304
g_u32FlashBlockSize: 131072
All the files are in Flash, No TFTP required
System shall come up in normal mode
All the files have been successfully received.....
Active copy of Ctrl Plane Bin was found in flash
Unzipping the Control Plane....................................................
Transferring Control to Ctrl Plane Binary...
Flash size: 4M
psCPInfo->u32FlashSize : 4194304
psCPInfo->u32FlashBlockSize: 131072
Free Memory available in SDRAM-A is 0x2b8200
System coming up in normal mode...
Locking Control Plane Text Start: 0x4923000 End: 0x4f301b0
Allocatiing System Memory fom SDRAM-E
total memory Free in SDRAM E = 196608
total memory Free in SDRAM D = 0
total memory Free in SDRAM B = 409222
Flash size: 4M
g_u32FlashNumBlocks: 32
Flash scanning in progress.............................
No space available in flash for requested device size
The device won't be used
CdbNvm:- Configuration Size is 1961756
CdbNvm:- NVM CFG1 size 262032
CdbNvm:- NVM CFG2 size 262032
NVM_DEV_LOGS open fails
The uncompress location for data plane is 0x400b000
Cin:- DataPlane present in NVRAM
Cin- Uncompressing Dataplane
Uncompressing "DP.bin.gz" (382933->848776) ...... Done
Locking Text Area DP Text Start: 0x4818000 CP Text End : 0x4f301b0
CfgInit: System Coming up from Default Configuration
Valid Crash Dump found: 0x0
FATAL..... System crashed after main and before DP Initialization
Changed the faulty ACTIVE copy of ControlPlane in flash to TRIED
No valid INACTIVE copy of Control Plane present in flash
Control Plane shall now be TFTPied
Updating 12 Crash Records in Flash
Total Number of free records 7 are less than required
Freeing 12 older records in Crash Page
Freeing 12 older records in Crash Page... done
*************** CRASH LOG *******************************
General Crash Info
______________________
crash ID : 40 crash IU : 0
Time of crash : Thu Jan 01 00:00:12 1970
CP Version : COL2.10.2.0.051206
DP Version : DP_B02_10_14_60_ip1000a
System UP Time : 0 days : 0 hours : 0 mins : 12 secs
cause of crash : Crash in CP self Processing
User Crash Info
Control And Status Registers
_______________________________
PSR Reg : 0x949060c4 Wim Reg : 0x2
Single Fault PC : 0x4d1f20c Single Fault nPC : 0x4d1f210
Double Fault PC : 0x0 Double Fault nPC : 0x0
Y Reg MSW : 0x0 Y Reg LSW : 0x12345678
Single Fault Trap Num : 0x29 Double Fault Trap Num : 0xffffffff
Fault Status Reg : 0xc Double Fault Reg : 0xc240
IER : 0x2000 Trap Base Reg : 0x4f32290
Alternate Window # 0x1f
Reg#:Local : In |Reg#:Local : In |
0 : 0x0 : 0x0 | 1 : 0x0 : 0x0
2 : 0x0 : 0x0 | 3 : 0x0 : 0x0
4 : 0x0 : 0x0 | 5 : 0x0 : 0x0
6 : 0x0 : 0x0 | 7 : 0x0 : 0x0
Alternate Window # 0x1e
Alternate Window # 0x1d
Alternate Window # 0x1c
Alternate Window # 0x1b
Alternate Window # 0x1a
Alternate Window # 0x19
Alternate Window # 0x18
Current Standard Window Dump # 0x5
__________________________________
Registers Global Out Local In
0 : 0x0 : 0x33e1 : 0x54fde40 : 0x54fde10
1 : 0xca000000 : 0xca080000 : 0x80000 : 0x0
2 : 0x4f76c00 : 0x30 : 0x54fde10 : 0xf4000
3 : 0x18 : 0xca080000 : 0x0 : 0x152a71b7
4 : 0x54fde10 : 0x86000000 : 0x5d34c00 : 0x0
5 : 0x144805cc : 0x2 : 0x5d34c00 : 0x60
6 : 0x5d35400 : 0x306121a0 : 0x0 : 0x30612208
7 : 0x0 : 0x4f26a4c : 0x1 : 0x4d1f15c
Standard Window Dump # 0x6
0 : 0x0 : 0x54fde10 : 0x54fde4c : 0x0
1 : 0xca000000 : 0x0 : 0x0 : 0x5
2 : 0x4f76c00 : 0xf4000 : 0x54fde10 : 0x54fdec4
3 : 0x18 : 0x152a71b7 : 0x45000301 : 0x1
4 : 0x54fde10 : 0x0 : 0x0 : 0x54fde10
5 : 0x144805cc : 0x60 : 0x10ed1c : 0x54fd570
6 : 0x5d35400 : 0x30612208 : 0x0 : 0x30612270
7 : 0x0 : 0x4d1f15c : 0x0 : 0x4d1e600
Standard Window Dump # 0x7
0 : 0x0 : 0x0 : 0x80000 : 0x54fde10
1 : 0xca000000 : 0x5 : 0x54fde10 : 0x306123a8
2 : 0x4f76c00 : 0x54fdec4 : 0x13 : 0x1018
3 : 0x18 : 0x1 : 0xb : 0x46238c00
4 : 0x54fde10 : 0x54fde10 : 0x306123a8 : 0x51eb851f
5 : 0x144805cc : 0x54fd570 : 0x5d34c00 : 0x51eb8400
6 : 0x5d35400 : 0x30612270 : 0x0 : 0x306122d8
7 : 0x0 : 0x4d1e600 : 0x1 : 0x4d21f30
Standard Window Dump # 0x8
0 : 0x0 : 0x54fde10 : 0x38 : 0x54fd570
1 : 0xca000000 : 0x306123a8 : 0x37 : 0x306123a8
2 : 0x4f76c00 : 0x1018 : 0x51d5fe8 : 0x3
3 : 0x18 : 0x46238c00 : 0x0 : 0x51cbc58
4 : 0x54fde10 : 0x51eb851f : 0x5d34c00 : 0x2c00
5 : 0x144805cc : 0x51eb8400 : 0x5d34c00 : 0x51cbc00
6 : 0x5d35400 : 0x306122d8 : 0x0 : 0x30612340
7 : 0x0 : 0x4d21f30 : 0x1 : 0x4a3b8a4
Standard Window Dump # 0x9
0 : 0x0 : 0x54fd570 : 0x51cbc40 : 0x82dc
1 : 0xca000000 : 0x306123a8 : 0x12 : 0x3
2 : 0x4f76c00 : 0x3 : 0x1 : 0xbbccdd
3 : 0x18 : 0x51cbc58 : 0x0 : 0x3061314c
4 : 0x54fde10 : 0x2c00 : 0x5c923cc : 0x0
5 : 0x144805cc : 0x51cbc00 : 0x4f28d78 : 0x8020000
6 : 0x5d35400 : 0x30612340 : 0x4f28da8 : 0x306123c0
7 : 0x0 : 0x4a3b8a4 : 0x4f28dd8 : 0x4c9e0ec
Standard Window Dump # 0xa
0 : 0x0 : 0x82dc : 0x51ca800 : 0x306131f0
1 : 0xca000000 : 0x3 : 0x500baf8 : 0x0
2 : 0x4f76c00 : 0xbbccdd : 0x4f301b0 : 0x1
3 : 0x18 : 0x3061314c : 0x0 : 0x4f61768
4 : 0x54fde10 : 0x0 : 0x20 : 0x1a9
5 : 0x144805cc : 0x8020000 : 0x4 : 0x9200
6 : 0x5d35400 : 0x306123c0 : 0x0 : 0x30613150
7 : 0x0 : 0x4c9e0ec : 0x0 : 0x4a30468
Standard Window Dump # 0xb
0 : 0x0 : 0x306131f0 : 0xff : 0x8
1 : 0xca000000 : 0x0 : 0x4a2e49c : 0x4f27918
2 : 0x4f76c00 : 0x1 : 0x4a2e4a0 : 0x4f27800
3 : 0x18 : 0x4f61768 : 0x0 : 0x4f27400
4 : 0x54fde10 : 0x1a9 : 0x5d34c00 : 0x4f27818
5 : 0x144805cc : 0x9200 : 0x5d34c00 : 0x0
6 : 0x5d35400 : 0x30613150 : 0x0 : 0x30613280
7 : 0x0 : 0x4a30468 : 0x1 : 0x4a2da2c
Standard Window Dump # 0xc
0 : 0x0 : 0x8 : 0x400b000 : 0x4a2cc00
1 : 0xca000000 : 0x4f27918 : 0x51ca800 : 0x30613330
2 : 0x4f76c00 : 0x4f27800 : 0x4f8f000 : 0x4f30000
3 : 0x18 : 0x4f27400 : 0x4a2cc00 : 0x4a2cc00
4 : 0x54fde10 : 0x4f27818 : 0x30613550 : 0x0
5 : 0x144805cc : 0x0 : 0x0 : 0x49789c8
6 : 0x5d35400 : 0x30613280 : 0x306133b8 : 0x30613808
7 : 0x0 : 0x4a2da2c : 0x30613440 : 0x492cb10
Standard Window Dump # 0xd
0 : 0x0 : 0x4a2cc00 : 0x3e8 : 0x500baf8
1 : 0xca000000 : 0x30613330 : 0x0 : 0x541344c
2 : 0x4f76c00 : 0x4f30000 : 0x4df2000 : 0x100
3 : 0x18 : 0x4a2cc00 : 0x5028b10 : 0x80000000
4 : 0x54fde10 : 0x0 : 0x0 : 0x4c11db7
5 : 0x144805cc : 0x49789c8 : 0x2580 : 0x5d46e00
6 : 0x5d35400 : 0x30613808 : 0x8 : 0x30613918
7 : 0x0 : 0x492cb10 : 0x4000000 : 0x4933388
Standard Window Dump # 0xe
0 : 0x0 : 0x500baf8 : 0x5d35800 : 0x0
1 : 0xca000000 : 0x541344c : 0x5d35800 : 0x0
2 : 0x4f76c00 : 0x100 : 0x5d35800 : 0x20f00
3 : 0x18 : 0x80000000 : 0x0 : 0x4f27400
4 : 0x54fde10 : 0x4c11db7 : 0x0 : 0x4f27818
5 : 0x144805cc : 0x5d46e00 : 0x0 : 0x0
6 : 0x5d35400 : 0x30613918 : 0x0 : 0x306139f0
7 : 0x0 : 0x4933388 : 0x0 : 0x4f19220
Standard Window Dump # 0xf
0 : 0x0 : 0x0 : 0x4923000 : 0x0
1 : 0xca000000 : 0x0 : 0x4f19200 : 0xb
2 : 0x4f76c00 : 0x20f00 : 0x4f19204 : 0x0
3 : 0x18 : 0x4f27400 : 0x940060cf : 0x5d35000
4 : 0x54fde10 : 0x4f27818 : 0x2 : 0xffffffff
5 : 0x144805cc : 0x0 : 0x2580 : 0x0
6 : 0x5d35400 : 0x306139f0 : 0x8 : 0x30613a58
7 : 0x0 : 0x4f19220 : 0xff : 0x0
Standard Window Dump # 0x0
0 : 0x0 : 0x0 : 0x0 : 0x0
1 : 0xca000000 : 0xb : 0x0 : 0x0
2 : 0x4f76c00 : 0x0 : 0x0 : 0x0
3 : 0x18 : 0x5d35000 : 0x0 : 0x0
4 : 0x54fde10 : 0xffffffff : 0x0 : 0x0
5 : 0x144805cc : 0x0 : 0x0 : 0x0
6 : 0x5d35400 : 0x30613a58 : 0x0 : 0x5d35030
7 : 0x0 : 0x0 : 0x0 : 0x4f19b24
Wim Window Dump # 0x1
0 : 0x0 : 0x0 : 0x944060c1 : 0x5b9fd6c
1 : 0xca000000 : 0x0 : 0x5213c28 : 0x5b9fd6c
2 : 0x4f76c00 : 0x0 : 0x5d35000 : 0x5b9fd6c
3 : 0x18 : 0x0 : 0x5d35400 : 0x5b9ecf4
4 : 0x54fde10 : 0x0 : 0x0 : 0x5d34c00
5 : 0x144805cc : 0x0 : 0x5d34c00 : 0x389
6 : 0x5d35400 : 0x5d35030 : 0x0 : 0x5d35030
7 : 0x0 : 0x4f19b24 : 0x1 : 0x4a620f4
Standard Window Dump # 0x2
0 : 0x0 : 0x5b9fd6c : 0x5b9fd6c : 0x5213c28
1 : 0xca000000 : 0x5b9fd6c : 0x5213c28 : 0x51ccefc
2 : 0x4f76c00 : 0x5b9fd6c : 0x5d35000 : 0x5b9ece8
3 : 0x18 : 0x5b9ecf4 : 0x5d35400 : 0xd0f4c
4 : 0x54fde10 : 0x5d34c00 : 0x0 : 0x5d34c00
5 : 0x144805cc : 0x389 : 0x5d34c00 : 0x389
7 : 0x0 : 0x4a620f4 : 0x1 : 0x4a57970
Standard Window Dump # 0x3
0 : 0x0 : 0x5213c28 : 0x5b9fd34 : 0x5ba015c
1 : 0xca000000 : 0x51ccefc : 0x500c170 : 0x5ba015c
2 : 0x4f76c00 : 0x5b9ece8 : 0x5d35000 : 0x5
3 : 0x18 : 0xd0f4c : 0x5d35400 : 0x0
4 : 0x54fde10 : 0x5d34c00 : 0x0 : 0x307cfff0
5 : 0x144805cc : 0x389 : 0x5d34c00 : 0x107f9c
6 : 0x5d35400 : 0x5d35030 : 0x0 : 0x30611cb8
7 : 0x0 : 0x4a57970 : 0x1 : 0x4f22510
Standard Window Dump # 0x4
0 : 0x0 : 0x5ba015c : 0x949060c4 : 0x33e1
1 : 0xca000000 : 0x5ba015c : 0x4d1f20c : 0xca080000
2 : 0x4f76c00 : 0x5 : 0x4d1f210 : 0x30
3 : 0x18 : 0x0 : 0x500d6e0 : 0xca080000
4 : 0x54fde10 : 0x307cfff0 : 0x1448080c : 0x86000000
5 : 0x144805cc : 0x107f9c : 0x1 : 0x2
6 : 0x5d35400 : 0x30611cb8 : 0x0 : 0x306121a0
7 : 0x0 : 0x4f22510 : 0x1 : 0x4f26a4c
Coprocessor Registers dump
CCSR Register : 0xfffff2f3 CCCRC Register : 0xffffffff
CCPR Register : 0xffeffbf3
CCIR Register : 0xffffffff CCIBR Register : 0xffbbfffb
CCOBR Register: 0xfffffde6 CCOR Register : 0xffefffff
Call Stack at the time of crash
StackDepth CallAddress Return Address Frame Ptr Stackptr
12 : 0x4f26a4c :0x4d1f15c :0x30612208 :0x306121a0
11 : 0x4d1f15c :0x4d1e600 :0x30612270 :0x30612208
10 : 0x4d1e600 :0x4d21f30 :0x306122d8 :0x30612270
9 : 0x4d21f30 :0x4a3b8a4 :0x30612340 :0x306122d8
8 : 0x4a3b8a4 :0x4c9e0ec :0x306123c0 :0x30612340
7 : 0x4c9e0ec :0x4a30468 :0x30613150 :0x306123c0
6 : 0x4a30468 :0x4a2da2c :0x30613280 :0x30613150
5 : 0x4a2da2c :0x492cb10 :0x30613808 :0x30613280
4 : 0x492cb10 :0x4933388 :0x30613918 :0x30613808
3 : 0x4933388 :0x4f19220 :0x306139f0 :0x30613918
2 : 0x4f19220 :0x0 :0x30613a58 :0x306139f0
1 : 0x0 :0x4f19b24 :0x5d35030 :0x30613a58
Stack dump at the time of Crash
_______________________________________
NO Stack dump
Task for which stack over flow occur
NO Stack Overflow
*************** END LOG *******************************
Block 31 erase in progress
........Flash block 31 erase successful...
FLASH program starts at ADDR 3e0000
Rebooting........
СообщениеДобавлено: Пн авг 08, 2011 10:22
Прошиваем через загрузчик " нормальной" прошивкой:
После этого сообщения нажать F1 , затем i .
Подсоединить к одному из аплинков TFTP и DHCP сервер с прошивкой формата .bin
Если на нажатие F1 не реагирует, то только в сервис.
С уважением, Гакало Алексей
