Текущее время: Пт окт 30, 2026 23:49
 Заголовок сообщения: DAS4192. Проблема
СообщениеДобавлено: Пн май 12, 2008 15:00
Booting IP-DSLAM...
Testing memory
Boot ROM version: 2.5F0031R55
Creation date: Sep 15 2006, 15:04:28
CPU: MPC8245 - KAHLUA2
Board: BMW, PLD rev: 0x6b, Map B (CHRP)
Timebase: 16.496749 MHz, MEM: 65.986996 MHz, PCI: 32.993498 MHz, CPU: 296.941482 MHz
Attached TCP/IP interface to rtl0.
Attaching network interface lo0... done.
MPC8245 Test... [OK]
RTL8139 Test... [OK]
Memory Test... [OK]
FLASH Test... [OK]
PCI Bus Test... [OK]
I2C Bus Test... [OK]
G767 Test... [OK]
MAX6652 Test... [OK]
M41T00 Test... [OK]
24C02 Test... [OK]
FAN Card
G760A_1 Test... [OK]
G760A_2 Test... [OK]
Line Card #01
G767 Test... [OK]
MAX6652_1 Test... [OK]
MAX6652_2 Test... [OK]
24C02 Test... [OK]
HPI BUS Test... [Failed] (1,2,3,4)
Line Card #02
G767 Test... [OK]
24C02 Test... [OK]
Line Card #03
G767 Test... [OK]
24C02 Test... [OK]
Line Card #04
G767 Test... [OK]
24C02 Test... [OK]
Press any key to stop auto-boot...
0
auto-booting...
File Header: ID=AM0031 Version=v2.0.2 Size=3126582 Total Size=3126662
comparing md5 digest
c3755dfcfebe7df8bfeee1fd33a7c4b5
MD5 digest verification passed
Uncompressing 3126582 bytes...
Loading image... 13533712
Starting at 0x10000...
Attached TCP/IP interface to rtl unit 0
Attaching interface lo0...done
Image file: opCodeB::am0031.enc
Version: v2.0.2 (build 134)
Init System Timer Task .................................... [OK]
Init IGMP Queue ........................................... [OK]
Init Switching Fabric #1 .................................. [OK]
Init DHCP Agent ........................................... [OK]
Init PPPoE Agent .......................................... [OK]
Init AlarmMib ............................................ [OK]
Init Interrupt Service Routine ............................ [OK]
Init IPOA ................................................. [OK]
Init ACL .................................................. [OK]
Init ATM OAM Loopback Task ................................ [OK]
Init LC Booting Task ...................................... [OK]
Init WAN Interface ........................................ [OK]
Retrieve MIBs .............................................
Retrieve Enable All Vlan ................................ [OK]
Retrieve Entity Alarm MIB ............................... [OK]
Retrieve Relay Input MIB ................................ [OK]
Retrieve System IP MIB .................................. [OK]
Retrieve System General MIB ............................. [OK]
Retrieve SNMP Community MIB ............................. [OK]
Retrieve SNMP Trap MIB .................................. [OK]
Retrieve System Information Name MIB .................... [OK]
Retrieve System Information Contact MIB ................. [OK]
Retrieve System Information Location MIB ................ [OK]
Retrieve VLAN Structure MIB ............................. [OK]
Retrieve User Information MIB ........................... [OK]
Retrieve ADSL Line Config Profile MIB ................... [OK]
Retrieve ADSL Line Alarm Config Profile MIB ............. [OK]
Retrieve ADSL Line MIB .................................. [OK]
Retrieve IGMP Snoop MIB ................................. [OK]
Retrieve Card Information MIB ........................... [OK]
Retrieve IP over ATM MIB ................................ [OK]
Retrieve LACP Group MIB ................................. [OK]
Retrieve LACP Port MIB .................................. [OK]
Retrieve LACP MIB ....................................... [OK]
Retrieve IGMP Proxy MIB ................................. [OK]
Retrieve UGE Admin Status MIB ........................... [OK]
Retrieve IP Traffic Profile MIB ......................... [OK]
Retrieve VC VLAN MIB .................................... [OK]
Retrieve Multicast Profile MIB .......................... [OK]
Retrieve Multicast Service Profile MIB .................. [OK]
Retrieve Multicast Eoa MIB .............................. [OK]
Retrieve DHCP Relay Server MIB .......................... [OK]
Retrieve DHCP Option 82 MIB ............................. [OK]
Retrieve DHCP MIB ....................................... [OK]
Retrieve Access Control List MIB ........................ [OK]
Retrieve COS Queue Mapping MIB .......................... [OK]
Retrieve Dot1d STP MIB .................................. [OK]
Retrieve Dot1d STP Port MIB ............................. [OK]
Retrieve SHDSL Extended Alarm MIB ....................... [OK]
Retrieve SHDSL Line Config Profile MIB .................. [OK]
Retrieve SHDSL Line Alarm Config Profile MIB ............ [OK]
Retrieve SHDSL Span MIB ................................. [OK]
Retrieve DHCP BC Control MIB ............................ [OK]
Retrieve Static LA MIB .................................. [OK]
Retrieve PPPoE Option 82 State MIB ...................... [OK]
Retrieve DNS Server MIB ................................. [OK]
Retrieve Time Server MIB ................................ [OK]
Retrieve Secured Host MIB ............................... [OK]
Retrieve Secured Host Admin MIB ......................... [OK]
Retrieve UGE Auto Negotiation Admin MIB ................. [OK]
Retrieve NetBIOS/NetBEUI filter MIB ..................... [OK]
Retrieve DiffServ MIB ................................... [OK]
Retrieve Traffic Policing Profile MIB ................... [OK]
Retrieve Line Port Traffic Policing MIB ................. [OK]
Retrieve Sensor Thresholds MIB .......................... [OK]
Retrieve Cascaded Management Slave MIB .................. [OK]
Retrieve Cascaded Management MIB ........................ [OK]
Init IGMP PROXY ........................................... [OK]
Chassis State:
Slot 1 2 3 4
Inserted [A] [A] [A] [A]
[ERROR] The Line Card 01 's Master DSP is failed!
Boot Line Card 01 ......................................... [FAIL]
Line card 1: link down!
Line Card 1: link up!
[ERROR] The Line Card 02 's Master DSP is failed!
Boot Line Card 02 ......................................... [FAIL]
Line card 2: link down!
Line Card 2: link up!
[ERROR] The Line Card 03 's Master DSP is failed!
Boot Line Card 03 ......................................... [FAIL]
Line card 3: link down!
Line Card 3: link up!
[ERROR] The Line Card 04 's Master DSP is failed!
Boot Line Card 04 ......................................... [FAIL]
Line card 4: link down!
Line Card 4: link up!
Извечный вопрос. Что делать?
СообщениеДобавлено: Вт май 13, 2008 14:27
1. Проверьте правильность установки линейных модулей в шасси.
2. Это происходит при каждом включении питания устройства?
3. Это наблюдается с момента установки линейных модулей и первой загрузки устройства?
С уважением, Давыдов Денис.
СообщениеДобавлено: Вт май 13, 2008 14:44
Устройство находится на удаленном узле.
Какое-то время работало нормально. Потом все пользователи отвалились.
Порты всех подключенных пользователей были в статусе Admin up, Operation down
Поколдовали - ничего не выходит.
Перегрузили и увидели сию картину маслом.
СообщениеДобавлено: Вт май 13, 2008 14:49
Попробуйте извлечь/вставить обратно линейные модули устройства.
Если это не поможет, я запрошу доп. информацию по данному поводу.
Также назовите пожалуйста значения питающего напряжения.
СообщениеДобавлено: Вт май 13, 2008 16:49
Полностью перегрузили DSLAM (вместе с питанием). После этого все загрузилось нормально. При этом передергивали только 1 из линейных модулей.
СообщениеДобавлено: Вт май 13, 2008 17:04
Если проблема возникнет снова - дайте знать.
Возможно также с Вашей стороны потребуется доп. информация в виде выводов некоторых команд.
