Текущее время: Вт окт 27, 2026 00:59
 Заголовок сообщения: Вирусы и безопасность DNS-320L
СообщениеДобавлено: Вс дек 20, 2015 23:58
Добрый день!
Вопрос - есть ли вирусы для данных NAS? Как обезапасить себя?
Ситуация: недавно приобрёл маршрутизатор со встроенным антивирусом (Asus)
И он (антивирус) теперь жалуется на мой NAS DNS-320L (последняя официальная прошивка + Transmision):
"Event number : 1
Alert type : Infected Device Prevention and Blocking
Source : "имя_моего_nas (mac_адрес)"
Destination : 95.165.168.168
Event number : 2
Source : имя_моего_nas (mac_адрес)"
RT-AC87U's AiProtection detected suspicious networking behavior and prevented your device making a connection to a malicious website (see above and the attached log for details).Suggested actions:
1. If you know that the cause of this attempted connection was a proprietary app or program and not a web browser, we recommand that you uninstall it from your device.
2. Ensure your device is up to time in all its operating system patches as well as updates to all apps or programs.
3. You should take this opportunity to check for, and install, any router firmware updates.
4. If you continue to receive such alerts for similar attempted connections, investigation into the cause will be necessary.
Meanwhile, rest assured that AiProtection continues to help keep you safe on the Internet.
You also can link to trend micro website to download security trial software for your client device protection.
http://www.trendmicro.com/"
Как реагировать?
Что за ресурс 95.165.168.168? (бывает 3-4 варианта)
Таких сообщений получаю ~10 за 9 часов работы.
