Текущее время: Сб окт 31, 2026 05:19
 Заголовок сообщения: DNR-326. Ошибка сертификата Java
СообщениеДобавлено: Пн сен 28, 2015 13:37
Здравствуйте, форумчане.
Есть проблема с видеосервером DNR-326. При входе на сервер через браузер на вкладке "LIVE VIDEO" не проигрывается видео, вместо этого выдаётся сообщение Java: "Certificate has been revoked. The application will not be executed".
Скриншот ошибки:
При нажатии "More Information":
java.security.cert.CertificateRevokedException: Certificate has been revoked, reason: KEY_COMPROMISE, revocation date: Thu Sep 03 03:00:00 MSK 2015, authority: CN=VeriSign Class 3 Code Signing 2010 CA, OU=Terms of use at https://www.verisign.com/rpa (c)10, OU=VeriSign Trust Network, O="VeriSign, Inc.", C=US, extension OIDs: []
at com.sun.deploy.security.RevocationChecker.checkOCSP(Unknown Source)
at com.sun.deploy.security.RevocationChecker.check(Unknown Source)
at com.sun.deploy.security.TrustDecider.checkRevocationStatus(Unknown Source)
at com.sun.deploy.security.TrustDecider.getValidationState(Unknown Source)
at com.sun.deploy.security.TrustDecider.validateChain(Unknown Source)
at com.sun.deploy.security.TrustDecider.isAllPermissionGranted(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.isTrustedByTrustDecider(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.getTrustedCodeSources(Unknown Source)
at com.sun.deploy.security.CPCallbackHandler$ParentCallback.strategy(Unknown Source)
at com.sun.deploy.security.CPCallbackHandler$ParentCallback.openClassPathElement(Unknown Source)
at com.sun.deploy.security.DeployURLClassPath$JarLoader.getJarFile(Unknown Source)
at com.sun.deploy.security.DeployURLClassPath$JarLoader.access$800(Unknown Source)
at com.sun.deploy.security.DeployURLClassPath$JarLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at com.sun.deploy.security.DeployURLClassPath$JarLoader.ensureOpen(Unknown Source)
at com.sun.deploy.security.DeployURLClassPath$JarLoader.<init>(Unknown Source)
at com.sun.deploy.security.DeployURLClassPath$3.run(Unknown Source)
at com.sun.deploy.security.DeployURLClassPath.getLoader(Unknown Source)
at com.sun.deploy.security.DeployURLClassPath.getResource(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader$2.run(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.findClassHelper(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadClass0(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source)
at sun.plugin2.applet.Plugin2Manager.initAppletAdapter(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
А вот Certificate Details:
Очевидно, что срок действия сертификата уже истёк, поэтому и ошибка.
Я вообще не пойму, каким образом можно обновить этот сертификат. В документации ни одного упоминания про сертификаты Java. Я пробовал обновить прошивку до 2.20 с британского сайта d-link, на русском сайте доступна только прошивка 2.10. Думал, что может и сертификат новый будет, но обновление не прокатывает. Просто висит процесс обновления бесконечно (проверял целые сутки), а если обновить страницу, то видно, что прошивка прежняя.
Есть идеи, как решить проблему?
P.S. Отключать безопасность Java не хотелось бы.
 Заголовок сообщения: Re: DNR-326. Ошибка сертификата Java
СообщениеДобавлено: Пн сен 28, 2015 18:02
Здесь вроде прошивки и софт новые есть
Только читайте рецензии к прошивкам(там иногда есть рекомендации), а также обращайте внимание на ревизию вашего продукта.
http://tsd.dlink.com.tw/
viewtopic.php?f=13&t=170088&p=934998#p934998
СообщениеДобавлено: Вт сен 29, 2015 15:35
Спасибо за ссылку. Обновил прошивку до последней версии "DNR-326 A2 FW 2.40", дата последнего редактирования 25.09.2015, т.е. совсем недавно. А сертификат всё равно не изменился, та же самая дата и осталась. Такое ощущение, что D-Link сертификат вообще не меняет.
СообщениеДобавлено: Вт сен 29, 2015 16:48
Здравствуйте.
Данный вопрос уже "ушел" к разработчикам. Ожидайте дальнейших обновлений в этой теме.
СообщениеДобавлено: Сб окт 03, 2015 01:09
Аналогичная проблема в windows 10 и dns-325 - заблокирован издатель сертификата из-за отзыва владельцем. По этой причине не устанавливаются DNS325SCRealInstall.msi и DNS325SCPlaybackInstall.msi подгружаемые surveillance center station с сайта dlink. И невозможно просмотреть изображение с камер в браузерах Edge и Internet Explorer. Срок действия сертификатов истек 4 сентября 2015 г.
Все прошивки и версии новые 2015 года.
Последний раз редактировалось norgren Вс окт 04, 2015 14:50, всего редактировалось 1 раз.
СообщениеДобавлено: Сб окт 03, 2015 12:36
А вот уведомление от Chrome:
[i][i]Почему плагины NPAPI не работают в Chrome
Ранее плагины позволяли расширить возможности браузера. Однако теперь большую часть этих функций по умолчанию выполняет HTML5. С 1 сентября 2015 года поддержка таких плагинов в браузере Chrome прекращена.
Чем вызвано это решение
В прошлом многие плагины разрабатывались на основе системы NPAPI. Сейчас эти устаревшие плагины почти не используются, так как могут вызвать проблемы с безопасностью веб-сайта.
Нам важно, чтобы Chrome оставался надежным, быстрым и стабильным браузером, поэтому с 1 сентября 2015 года мы прекращаем поддержку плагинов NPAPI.
После этой даты плагины на основе NPAPI, в том числе Silverlight, Java и Unity, работать не будут. Чтобы и дальше использовать их, выберите другой браузер.
Плагины PPAPI
Мы по-прежнему поддерживаем плагины, которые используют новую безопасную систему Pepper API (PPAPI). К ним относятся, например, предустановленные в Chrome плагины Adobe Flash. Плагины PPAPI автоматически обновляются вместе с браузером Chrome.
[/i][/i]
Просмотр изображения с камер невозможен.
Хотя в новой версии surveillance center 2.02 и при прошивке DNS325 под номером 1.05 заявлена поддержка Chrome и Firefox
СообщениеДобавлено: Пн окт 05, 2015 13:00
Аналогично вопрос у разработчиков.
СообщениеДобавлено: Пн окт 05, 2015 13:01
Плагины PPAPI
[/i][/i]
Хром больше не поддерживает установку плагинов, поэтому работать не будет в этом браузере больше.
СообщениеДобавлено: Пт дек 25, 2015 23:09
ребята, делать-то что с этой проблемой? как хотя бы примерно настроить теперь детектор движения на камере любой?
http://vxd.perm.ru
СообщениеДобавлено: Вс дек 27, 2015 21:17
Аналогичная проблема ( certificate revoked) , но с камерой D933L. Дата окончания сертификата - вообще 2031 год. :roll:
Как ни странно - вылечилось установкой последней Java с сайта Oracle. Версия там сейчас вроде "8u66".
Сайт (или уже программа установки?) сообщил, что моя ОС не вполне подходит этой версии JAVA (у меня XP 32), но именно эта "8u66" java установилась, картинка с камеры появилась, и никакое сообщение о отозванном сертификате больше не беспокоит.
СообщениеДобавлено: Пн дек 28, 2015 10:41
С какой моделью у Вас проблема в сертификате остается?
СообщениеДобавлено: Пн дек 28, 2015 12:47
Видеокамера DCS-933L.
Удалось страшными костылями запустить в IE через mjpeg, в FF по-прежнему отказывается, изменение и внесение локальных IP камер в исключения Java результата не приносят.
Java последняя, обновленная с оф.сайта вчера.
СообщениеДобавлено: Пн дек 28, 2015 14:20
Какая прошивка устройства? Пришлите скриншот экрана в тот момент, когда выдает ошибку/не грузится страница.
СообщениеДобавлено: Вт дек 29, 2015 21:50
Хммм, вот сейчас открыл и оно заработало без всяких алертов и напоминаний.... чудеса!
http://vxd.perm.ru
СообщениеДобавлено: Пн янв 11, 2016 16:10
Отлично. Если будут дополнительные вопросы, обращайтесь.
