Текущее время: Ср ноя 04, 2026 16:52
Начать новую тему Ответить на тему  [ Сообщений: 151 ]  На страницу 1, 2, 3, 4, 5 ... 11  След.
СообщениеДобавлено: Вс май 11, 2008 21:50
H/W Ver.:A1
F/W Ver.:RU_DSL-2500U_3-06-04-3H00.A2pB023g2.d19b
Периодически (не всегда) после разрыва соединение не восстанавливается. Помогает перезагрузка модема. В логе модема когда соединение не восстанавливается спамятся строки:
May 10 21:28:50   daemon   notice   pppd[259]: PPP: Start to connect ...
May 10 21:28:50   daemon   crit   pppd[259]: PPP server detected.
May 10 21:28:53   daemon   notice   pppd[259]: PPP: Start to connect ...
May 10 21:28:54   daemon   crit   pppd[259]: PPP server detected.
May 10 21:28:54   daemon   crit   pppd[259]: PPP session established.
May 10 21:29:06   daemon   notice   pppd[259]: PPP: Start to connect ...
May 10 21:29:06   daemon   crit   pppd[259]: PPP server detected.
May 10 21:29:09   daemon   notice   pppd[259]: PPP: Start to connect ...
May 10 21:29:09   daemon   crit   pppd[259]: PPP server detected.
May 10 21:29:11   user   warn   dnsprobe[675]: dns query failed
May 10 21:29:12   daemon   notice   pppd[259]: PPP: Start to connect ...
May 10 21:29:12   daemon   crit   pppd[259]: PPP server detected.
May 10 21:29:12   daemon   crit   pppd[259]: PPP session established.
May 10 21:29:13   user   warn   dnsprobe[675]: dns query failed
May 10 21:29:15   user   warn   dnsprobe[675]: dns query failed
May 10 21:29:24   daemon   notice   pppd[259]: PPP: Start to connect ...
May 10 21:29:24   daemon   crit   pppd[259]: PPP server detected.
May 10 21:29:24   daemon   crit   pppd[259]: PPP session established.
May 10 21:29:36   daemon   notice   pppd[259]: PPP: Start to connect ...
May 10 21:29:36   daemon   crit   pppd[259]: PPP server detected.
May 10 21:29:39   daemon   notice   pppd[259]: PPP: Start to connect ...
May 10 21:29:39   daemon   crit   pppd[259]: PPP server detected.
May 10 21:29:39   daemon   crit   pppd[259]: PPP session established.
May 10 21:29:47   user   warn   dnsprobe[675]: dns query failed
May 10 21:29:49   user   warn   dnsprobe[675]: dns query failed
May 10 21:29:51   daemon   notice   pppd[259]: PPP: Start to connect ...
May 10 21:29:51   daemon   crit   pppd[259]: PPP server detected.
May 10 21:29:51   daemon   crit   pppd[259]: PPP session established.
May 10 21:29:51   user   warn   dnsprobe[675]: dns query failed
May 10 21:30:03   daemon   notice   pppd[259]: PPP: Start to connect ...
May 10 21:30:03   daemon   crit   pppd[259]: PPP server detected.
May 10 21:30:06   daemon   notice   pppd[259]: PPP: Start to connect ...
May 10 21:30:07   daemon   crit   pppd[259]: PPP server detected.
May 10 21:30:07   daemon   crit   pppd[259]: PPP session established.
May 10 21:30:19   daemon   notice   pppd[259]: PPP: Start to connect ...
May 10 21:30:19   daemon   crit   pppd[259]: PPP server detected.
May 10 21:30:22   daemon   notice   pppd[259]: PPP: Start to connect ...
May 10 21:30:22   daemon   crit   pppd[259]: PPP server detected.
СообщениеДобавлено: Пн май 12, 2008 14:13
TOM_RUS писал(а):
H/W Ver.:A1
Приведите вывод страницы Status > ADSL. Включена ли опция Keep Alive в настройках WAN-интерфейса?
СообщениеДобавлено: Пн май 12, 2008 15:47
Да, включена. В тех. саппорте провайдера (ЮТК-Волгоград) удалось выяснить что они не видят моих попыток переподключения в таких случаях. Пробовали отключать ADSL2+ - ничего не изменилось. Сказали что подвисает сессия на модеме.
P.S. Гарантия у модема кончается 13 июня, незнаю что с ним делать...
Mode:   ADSL2+
Line Coding:   Trellis On
Status:   No Defect
Link Power State:   L0
    Downstream   Upstream
SNR Margin (dB):   7.0    6.8
Attenuation (dB):   19.5    9.6
Output Power (dBm):   12.4    16.2
Attainable Rate (Kbps):   22920    1261
Rate (Kbps):   21278    1253
MSGc (number of bytes in overhead channel message):   52    13
B (number of bytes in Mux Data Frame):   248    13
M (number of Mux Data Frames in FEC Data Frame):   1    16
T (Mux Data Frames over sync bytes):   3    10
R (number of check bytes in FEC Data Frame):   6    8
S (ratio of FEC over PMD Data Frame length):   0.3740    5.6758
L (number of bits in PMD Data Frame):   5455    327
D (interleaver depth):   64    8
Delay (msec):   5    11
Super Frames:   1855170    1855168
Super Frame Errors:   981    77
RS Words:   322799738    7884464
RS Correctable Errors:   478398    405
RS Uncorrectable Errors:   59425    N/A
HEC Errors:   919    3232
OCD Errors:   1    0
LCD Errors:   0    0
Total Cells:   1514449779    453719090
Data Cells:   1224139    4101797
Bit Errors:   0    162708
Total ES:   1198    29
Total SES:   90    12
Total UAS:   65    163
СообщениеДобавлено: Пн май 12, 2008 20:12
Сегодня проблема проявилась 2 раза.
May 12 21:03:48   daemon   crit   pppd[251]: PPP session established.
May 12 21:04:00   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:04:00   daemon   crit   pppd[251]: PPP server detected.
May 12 21:04:00   daemon   crit   pppd[251]: PPP session established.
May 12 21:04:12   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:04:12   daemon   crit   pppd[251]: PPP server detected.
May 12 21:04:12   daemon   crit   pppd[251]: PPP session established.
May 12 21:04:13   user   warn   dnsprobe[981]: dns query failed
May 12 21:04:15   user   warn   dnsprobe[981]: dns query failed
May 12 21:04:17   user   warn   dnsprobe[981]: dns query failed
May 12 21:04:24   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:04:24   daemon   crit   pppd[251]: PPP server detected.
May 12 21:04:27   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:04:27   daemon   crit   pppd[251]: PPP session established.
May 12 21:04:39   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:04:39   daemon   crit   pppd[251]: PPP server detected.
May 12 21:04:39   daemon   crit   pppd[251]: PPP session established.
May 12 21:04:49   user   warn   dnsprobe[981]: dns query failed
May 12 21:04:51   user   warn   dnsprobe[981]: dns query failed
May 12 21:04:51   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:04:51   daemon   crit   pppd[251]: PPP server detected.
May 12 21:04:51   daemon   crit   pppd[251]: PPP session established.
May 12 21:04:53   user   warn   dnsprobe[981]: dns query failed
May 12 21:05:03   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:05:03   daemon   crit   pppd[251]: PPP server detected.
May 12 21:05:04   daemon   crit   pppd[251]: PPP session established.
May 12 21:05:16   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:05:16   daemon   crit   pppd[251]: PPP server detected.
May 12 21:05:16   daemon   crit   pppd[251]: PPP session established.
May 12 21:05:25   user   warn   dnsprobe[981]: dns query failed
May 12 21:05:27   user   warn   dnsprobe[981]: dns query failed
May 12 21:05:28   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:05:28   daemon   crit   pppd[251]: PPP server detected.
May 12 21:05:29   user   warn   dnsprobe[981]: dns query failed
May 12 21:05:31   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:05:31   daemon   crit   pppd[251]: PPP server detected.
May 12 21:05:31   daemon   crit   pppd[251]: PPP session established.
May 12 21:05:43   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:05:43   daemon   crit   pppd[251]: PPP server detected.
May 12 21:05:46   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:05:46   daemon   crit   pppd[251]: PPP server detected.
May 12 21:05:46   daemon   crit   pppd[251]: PPP session established.
May 12 21:05:58   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:05:58   daemon   crit   pppd[251]: PPP server detected.
May 12 21:06:01   user   warn   dnsprobe[981]: dns query failed
May 12 21:06:01   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:06:01   daemon   crit   pppd[251]: PPP session established.
May 12 21:06:03   user   warn   dnsprobe[981]: dns query failed
May 12 21:06:05   user   warn   dnsprobe[981]: dns query failed
May 12 21:06:13   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:06:13   daemon   crit   pppd[251]: PPP server detected.
May 12 21:06:16   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:06:16   daemon   crit   pppd[251]: PPP server detected.
May 12 21:06:16   daemon   crit   pppd[251]: PPP session established.
May 12 21:06:28   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:06:28   daemon   crit   pppd[251]: PPP server detected.
May 12 21:06:29   daemon   crit   pppd[251]: PPP session established.
May 12 21:06:37   user   warn   dnsprobe[981]: dns query failed
May 12 21:06:39   user   warn   dnsprobe[981]: dns query failed
May 12 21:06:41   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:06:41   daemon   crit   pppd[251]: PPP server detected.
May 12 21:06:41   daemon   crit   pppd[251]: PPP session established.
May 12 21:06:41   user   warn   dnsprobe[981]: dns query failed
May 12 21:06:53   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:06:53   daemon   crit   pppd[251]: PPP server detected.
May 12 21:06:53   daemon   crit   pppd[251]: PPP session established.
May 12 21:07:05   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:07:05   daemon   crit   pppd[251]: PPP server detected.
May 12 21:07:08   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:07:08   daemon   crit   pppd[251]: PPP server detected.
May 12 21:07:08   daemon   crit   pppd[251]: PPP session established.
May 12 21:07:13   user   warn   dnsprobe[981]: dns query failed
May 12 21:07:15   user   warn   dnsprobe[981]: dns query failed
May 12 21:07:17   user   warn   dnsprobe[981]: dns query failed
May 12 21:07:20   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:07:20   daemon   crit   pppd[251]: PPP server detected.
May 12 21:07:20   daemon   crit   pppd[251]: PPP session established.
May 12 21:07:32   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:07:32   daemon   crit   pppd[251]: PPP server detected.
May 12 21:07:35   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:07:35   daemon   crit   pppd[251]: PPP server detected.
May 12 21:07:35   daemon   crit   pppd[251]: PPP session established.
May 12 21:07:47   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:07:47   daemon   crit   pppd[251]: PPP server detected.
May 12 21:07:47   daemon   crit   pppd[251]: PPP session established.
May 12 21:07:49   user   warn   dnsprobe[981]: dns query failed
May 12 21:07:51   user   warn   dnsprobe[981]: dns query failed
May 12 21:07:53   user   warn   dnsprobe[981]: dns query failed
May 12 21:07:59   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:08:00   daemon   crit   pppd[251]: PPP server detected.
May 12 21:08:03   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:08:03   daemon   crit   pppd[251]: PPP server detected.
May 12 21:08:06   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:08:06   daemon   crit   pppd[251]: PPP server detected.
May 12 21:08:06   daemon   crit   pppd[251]: PPP session established.
May 12 21:08:18   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:08:18   daemon   crit   pppd[251]: PPP server detected.
May 12 21:08:18   daemon   crit   pppd[251]: PPP session established.
May 12 21:08:25   user   warn   dnsprobe[981]: dns query failed
May 12 21:08:27   user   warn   dnsprobe[981]: dns query failed
May 12 21:08:29   user   warn   dnsprobe[981]: dns query failed
May 12 21:08:30   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:08:30   daemon   crit   pppd[251]: PPP server detected.
May 12 21:08:33   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:08:33   daemon   crit   pppd[251]: PPP server detected.
May 12 21:08:36   daemon   notice   pppd[251]: PPP: Start to connect ...
May 12 21:08:36   daemon   crit   pppd[251]: PPP server detected.
May 12 21:08:36   daemon   crit   pppd[251]: PPP session established.
Mode:   ADSL2+
Status:   No Defect
    Downstream   Upstream
SNR Margin (dB):   7.3    7.2
Attenuation (dB):   20.0    9.6
Output Power (dBm):   12.3    15.9
Attainable Rate (Kbps):   23412    1265
Rate (Kbps):   21141    1253
MSGc (number of bytes in overhead channel message):   51    13
S (ratio of FEC over PMD Data Frame length):   0.3764    5.6758
L (number of bits in PMD Data Frame):   5420    327
Delay (msec):   6    11
Super Frames:   71061    71059
Super Frame Errors:   40    77
RS Words:   12151570    302000
RS Correctable Errors:   5380    411
RS Uncorrectable Errors:   329    N/A
HEC Errors:   35    3265
OCD Errors:   0    0
LCD Errors:   0    0
Total Cells:   57015359    502470523
Data Cells:   4063    4570995
Bit Errors:   0    163989
Total ES:   214    29
Total SES:   10    12
Total UAS:   31    183
ADSL статистика после перезагрузки модема (когда все работает):
Mode:   ADSL2+
Status:   No Defect
    Downstream   Upstream
SNR Margin (dB):   7.2    6.8
Output Power (dBm):   12.4    15.9
Attainable Rate (Kbps):   21420    1269
Rate (Kbps):   21122    1257
S (ratio of FEC over PMD Data Frame length):   0.3767    5.6585
L (number of bits in PMD Data Frame):   5415    328
Delay (msec):   6    11
Super Frames:   9403    9401
Super Frame Errors:   0    77
RS Words:   1608004    39954
RS Correctable Errors:   109    411
RS Uncorrectable Errors:   17    N/A
HEC Errors:   1    3280
OCD Errors:   0    0
LCD Errors:   0    0
Total Cells:   7532065    503079579
Data Cells:   6715    4572336
Bit Errors:   0    164639
Total ES:   1    29
Total SES:   0    12
Total UAS:   16    193
СообщениеДобавлено: Пн май 12, 2008 23:40
Такая же ситуация, на этом модеме. Провайдер тот же(ЮТК-Волгоград). Модуляция:G.DMT; Software Version:RU_DSL-2500U_3-06-04-3H00.A2pB023g2.d19b; Keep Alive включен. При таком зацикливании модема, провайдер не видит запроса на авторизацию(как они говорят). Решает проблему только перезагрузка модема. Знаю еще человека с таким модемом, провайдером и проблемой.
P.S. Хотя бывает работает неделями без перезагрузки.
В режиме Bridging, reconnect происходит нормально.
И постоянно отваливается DNS: dnsprobe[529]: dns query failed
СообщениеДобавлено: Вт май 13, 2008 00:30
У меня почти год работал без проблем, проблема появилась с 25 апреля :(
СообщениеДобавлено: Вт май 13, 2008 10:46
Наверное после смены прошивки на 3H00?
СообщениеДобавлено: Вт май 13, 2008 12:11
Нет, прошивку я поменял с 3B00 на 3H00 пару дней назад, проблема уже была...
СообщениеДобавлено: Вт май 13, 2008 12:32
У меня эта проблема возникла с середины марта. До этого работал нормально. Прошивку так же поменял пару дней назад с 3B00 на 3H00.
Возможно это после введения ЮТК привязки по MAC-адресам.
P.S. Наш провайдер (ЮТК-Волгоград) рвет соединение каждые восемь часов. Так у них billing работает.
СообщениеДобавлено: Чт май 15, 2008 10:03
Прошло 4 дня, ответа нет. Хотите протянуть чтобы гарантия у устройства кончилась? Не выйдет...
СообщениеДобавлено: Чт май 15, 2008 10:18
Попробуйте в разделе Advanced > ADSL отключить режим ADSL2+, оставьте включенной только G.dmt модуляцию. Пронаблюдайте результат.
СообщениеДобавлено: Чт май 15, 2008 12:28
Отключил ADSL2+, перезагрузил модем.
Jan 1 00:00:12   user   warn   kernel: blaadd: blaa_detect entry
Jan 1 00:00:12   user   warn   kernel: adsl: adsl_init entry
Jan 1 00:00:12   user   info   kernel: Broadcom BCMPROCFS v1.0 initialized
Jan 1 00:00:12   user   warn   kernel: Broadcom BCM6338A2 Ethernet Network Device v0.3
Jan 1 00:00:12   user   warn   kernel: Config Internal PHY Through MDIO
Jan 1 00:00:12   user   info   kernel: BCM63xx_ENET: 100 MB Full-Duplex (auto-neg)
Jan 1 00:00:12   user   warn   kernel: eth0: MAC Address: 00:19:5B:C0:A9:1F
Jan 1 00:00:12   user   crit   kernel: eth0 Link UP.
Jan 1 00:00:12   user   warn   kernel: BcmAdsl_Initialize=0xC00673B8, g_pFnNotifyCallback=0xC007E4E4
Jan 1 00:00:12   user   warn   kernel: pSdramPHY=0xA07FFFF8, 0x1B7768 0xDEADBEEF
Jan 1 00:00:12   user   warn   kernel: AdslCoreHwReset: AdslOemDataAddr = 0xA07FA744
Jan 1 00:00:12   user   warn   kernel: dgasp: kerSysRegisterDyingGaspHandler: dsl0 registered
Jan 1 00:00:12   user   warn   kernel: ip_tables: (C) 2000-2002 Netfilter core team
Jan 1 00:00:12   user   warn   kernel: ip_conntrack version 2.1 (61 buckets, 0 max) - 368 bytes per conntrack
Jan 1 00:00:12   user   warn   kernel: ip_conntrack_pptp version 2.1 loaded
Jan 1 00:00:12   user   warn   kernel: ip_nat_pptp version 2.0 loaded
Jan 1 00:00:12   user   warn   kernel: ip_conntrack_h323: init
Jan 1 00:00:12   user   warn   kernel: ip_nat_h323: initialize the module!
Jan 1 00:00:12   user   crit   kernel: ADSL G.994 training
Jan 1 00:00:12   user   crit   kernel: ADSL G.992 started
Jan 1 00:00:12   user   info   kernel: device eth0 entered promiscuous mode
Jan 1 00:00:12   user   info   kernel: br0: port 1(eth0) entering learning state
Jan 1 00:00:12   user   info   kernel: br0: topology change detected, propagating
Jan 1 00:00:12   user   info   kernel: br0: port 1(eth0) entering forwarding state
Jan 1 00:00:12   user   crit   kernel: ADSL G.992 channel analysis
Jan 1 00:00:12   user   debug   syslog: bftpd
Jan 1 00:00:12   user   debug   syslog: tftpd
Jan 1 00:00:12   user   debug   syslog: kill -16 199
Jan 1 00:00:13   user   debug   syslog: pppd
Jan 1 00:00:13   user   debug   syslog: ifconfig nas_8_35 mtu 1492
Jan 1 00:00:14   daemon   notice   pppd[249]: pppd 2.4.1 started by admin, uid 0
Jan 1 00:00:17   user   crit   kernel: ADSL G.992 message exchange
Jan 1 00:00:17   user   crit   kernel: ADSL link up, interleaved, us=1184, ds=12448
Jan 1 00:00:17   user   warn   kernel: ATM Soft SAR: ATM link connected.
Jan 1 00:00:18   user   debug   syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jan 1 00:00:19   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:00:19   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:00:22   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:00:22   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:00:22   daemon   crit   pppd[249]: PPP session established.
Jan 1 00:00:23   daemon   crit   pppd[249]: PPP LCP UP.
Jan 1 00:00:53   daemon   err   pppd[249]: User name and password authentication failed.
Jan 1 00:00:56   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:00:56   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:00:59   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:00:59   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:00:59   daemon   crit   pppd[249]: PPP session established.
Jan 1 00:01:12   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:01:12   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:01:15   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:01:15   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:01:15   daemon   crit   pppd[249]: PPP session established.
Jan 1 00:01:30   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:01:30   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:01:33   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:01:33   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:01:33   daemon   crit   pppd[249]: PPP session established.
Jan 1 00:01:45   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:01:45   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:01:48   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:01:48   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:01:51   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:01:51   daemon   crit   pppd[249]: PPP session established.
Jan 1 00:02:03   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:02:03   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:02:03   daemon   crit   pppd[249]: PPP session established.
Jan 1 00:02:15   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:02:16   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:02:16   daemon   crit   pppd[249]: PPP session established.
Jan 1 00:02:28   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:02:28   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:02:28   daemon   crit   pppd[249]: PPP session established.
Jan 1 00:02:40   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:02:40   daemon   crit   pppd[249]: PPP session established.
Jan 1 00:02:52   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:02:52   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:02:55   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:02:55   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:02:55   daemon   crit   pppd[249]: PPP session established.
Jan 1 00:03:07   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:03:07   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:03:07   daemon   crit   pppd[249]: PPP session established.
Jan 1 00:03:19   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:03:19   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:03:19   daemon   crit   pppd[249]: PPP session established.
Jan 1 00:03:31   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:03:31   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:03:34   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:03:35   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:03:35   daemon   crit   pppd[249]: PPP session established.
Jan 1 00:03:47   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:03:47   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:03:50   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:03:50   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:03:50   daemon   crit   pppd[249]: PPP session established.
Jan 1 00:04:02   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:04:02   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:04:05   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:04:05   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:04:05   daemon   crit   pppd[249]: PPP session established.
Jan 1 00:04:17   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:04:17   daemon   crit   pppd[249]: PPP server detected.
Mode:   G.DMT
Type:   Interleave
Status:   No Defect
    Downstream   Upstream
SNR Margin (dB):   9.1    7.0
Attenuation (dB):   16.0    9.5
Output Power (dBm):   12.2    19.8
Attainable Rate (Kbps):   12416    1340
Rate (Kbps):   12384    1152
K (number of bytes in DMT frame):   388    37
R (number of check bytes in RS code word):   0    0
S (RS code word size in DMT frame):   0.5    1
D (interleaver depth):   2    1
Delay (msec):   0    0
Super Frames:   12684    12682
Super Frame Errors:   1    0
RS Words:   1725150    0
RS Correctable Errors:   0    0
RS Uncorrectable Errors:   0    N/A
HEC Errors:   1    0
OCD Errors:   0    0
LCD Errors:   0    0
Total Cells:   6298956    0
Data Cells:   9000    0
Bit Errors:   0    0
Total ES:   1    0
Total SES:   0    0
Total UAS:   9    0
Перезагрузил еще раз - подключение прошло успешно.
Jan 1 00:00:12   user   info   kernel: PPP generic driver version 2.4.2
Jan 1 00:00:12   user   info   kernel: NET: Registered protocol family 24
Jan 1 00:00:12   user   warn   kernel: Using noop io scheduler
Jan 1 00:00:12   user   warn   kernel: bcm963xx_mtd driver v1.0
Jan 1 00:00:12   user   warn   kernel: brcmboard: brcm_board_init entry
Jan 1 00:00:12   user   warn   kernel: bcm963xx_serial driver v2.0
Jan 1 00:00:12   user   info   kernel: IP: routing cache hash table of 512 buckets, 4Kbytes
Jan 1 00:00:12   user   info   kernel: TCP: Hash tables configured (established 512 bind 1024)
Jan 1 00:00:12   user   info   kernel: NET: Registered protocol family 1
Jan 1 00:00:12   user   info   kernel: NET: Registered protocol family 17
Jan 1 00:00:12   user   notice   kernel: Ebtables v2.0 registered
Jan 1 00:00:12   user   info   kernel: NET: Registered protocol family 8
Jan 1 00:00:12   user   info   kernel: NET: Registered protocol family 20
Jan 1 00:00:12   user   warn   kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 00:00:12   user   info   kernel: Freeing unused kernel memory: 64k freed
Jan 1 00:00:12   user   warn   kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 00:00:12   user   warn   kernel: atmapi: module license 'Proprietary' taints kernel.
Jan 1 00:00:12   user   debug   syslog: kill -16 201
Jan 1 00:00:14   user   debug   syslog: ifconfig nas_8_35 mtu 1492
Jan 1 00:00:17   user   crit   kernel: ADSL link up, interleaved, us=1152, ds=12384
Jan 1 00:00:23   daemon   crit   pppd[249]: Received valid IP address from server. Connection UP.
Jan 1 00:00:24   user   debug   syslog: route add default gw 85.173.64.1 2>/dev/null
Jan 1 00:00:24   user   debug   syslog: iptables -A FORWARD -o ppp_8_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:00:24   user   debug   syslog: iptables -A FORWARD -i ppp_8_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:00:24   user   debug   syslog: echo > /proc/net/ip_conntrack
Jan 1 00:00:24   user   debug   syslog: echo "512" > /proc/sys/net/ipv4/ip_conntrack_max
Jan 1 00:00:24   user   debug   syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Jan 1 00:00:24   user   debug   syslog: iptables -t nat -D POSTROUTING -o ppp_8_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Jan 1 00:00:24   user   debug   syslog: iptables -t nat -A POSTROUTING -o ppp_8_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Jan 1 00:00:24   user   debug   syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 83.239.131.8 2>/dev/null
Jan 1 00:00:24   user   debug   syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 83.239.131.8
Jan 1 00:00:24   user   debug   syslog: /bin/dnsprobe &
Jan 1 00:00:24   user   debug   syslog: upnp -L br0 -W ppp_8_35_1 -D
Jan 1 00:00:24   user   notice   dnsprobe[527]: dnsprobe started!
Jan 1 00:00:25   user   debug   syslog: iptables -t filter -I OUTPUT -o ppp_8_35_1 -d 239.255.255.250 -j DROP 2>/dev/null
Jan 1 00:00:26   user   debug   syslog: iptables -D INPUT -i ppp_8_35_1 -j DROP
Jan 1 00:00:26   user   debug   syslog: iptables -A INPUT -i ppp_8_35_1 -j DROP
Jan 1 00:00:28   user   alert   kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=69.64.59.238 DST=83.239.188.79 LEN=60 TOS=0x00 PREC=0x00 TTL=48 ID=3731 DF PROTO=TCP SPT=33695 DPT=113 WINDOW=5840 RES=0x00 SYN URGP=0
Jan 1 00:00:31   user   alert   kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=69.64.59.238 DST=83.239.188.79 LEN=60 TOS=0x00 PREC=0x00 TTL=48 ID=3732 DF PROTO=TCP SPT=33695 DPT=113 WINDOW=5840 RES=0x00 SYN URGP=0
Jan 1 00:00:37   user   alert   kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=69.64.59.238 DST=83.239.188.79 LEN=60 TOS=0x00 PREC=0x00 TTL=48 ID=3733 DF PROTO=TCP SPT=33695 DPT=113 WINDOW=5840 RES=0x00 SYN URGP=0
Jan 1 00:00:38   user   alert   kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=204.8.34.130 DST=83.239.188.79 LEN=64 TOS=0x00 PREC=0x00 TTL=57 ID=49701 DF PROTO=TCP SPT=51909 DPT=1098 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 00:00:38   user   alert   kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=204.8.34.130 DST=83.239.188.79 LEN=64 TOS=0x00 PREC=0x00 TTL=57 ID=49702 DF PROTO=TCP SPT=51910 DPT=1200 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 00:04:41   user   debug   igmp[834]: iptables -t filter -I FORWARD 1 -i br0 -d 224.0.0.22 -j DROP 2>/dev/null
Jan 1 00:04:41   user   debug   igmp[836]: iptables -t filter -D FORWARD -i br0 -d 224.0.0.22 -j ACCEPT 2>/dev/null
В проблемном случае в логе отсутствут строки
СообщениеДобавлено: Чт май 15, 2008 12:40
Вернул обратно ADSL2+, пока не перезагрузил модем подключиться не смог, после перезагрузки сразу подключился. Не понимаю почему периодически переподключиться без перезагрузки не возможно.
Jan 1 00:00:12   user   info   kernel: Memory: 6056k/7808k available (1255k kernel code, 1732k reserved, 184k data, 64k init, 0k highmem)
Jan 1 00:00:12   user   warn   kernel: Calibrating delay loop... 239.20 BogoMIPS
Jan 1 00:00:12   user   warn   kernel: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Jan 1 00:00:12   user   warn   kernel: Checking for 'wait' instruction... unavailable.
Jan 1 00:00:12   user   info   kernel: NET: Registered protocol family 16
Jan 1 00:00:12   user   warn   kernel: Can't analyze prologue code at 801487a4
Jan 1 00:00:12   user   debug   syslog: kill -16 200
Jan 1 00:00:16   user   crit   kernel: ADSL G.992 started
Jan 1 00:00:20   user   crit   kernel: ADSL G.992 channel analysis
Jan 1 00:00:26   user   crit   kernel: ADSL G.992 message exchange
Jan 1 00:00:26   user   crit   kernel: ADSL link up, interleaved, us=1241, ds=20556
Jan 1 00:00:26   user   warn   kernel: ATM Soft SAR: ATM link connected.
Jan 1 00:00:27   user   debug   syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jan 1 00:00:28   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:00:28   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:00:28   daemon   crit   pppd[249]: PPP session established.
Jan 1 00:00:30   daemon   crit   pppd[249]: PPP LCP UP.
Jan 1 00:00:32   daemon   err   pppd[249]: User name and password authentication failed.
Jan 1 00:00:35   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:00:35   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:00:35   daemon   crit   pppd[249]: PPP session established.
Jan 1 00:00:37   daemon   crit   pppd[249]: PPP LCP UP.
Jan 1 00:00:39   daemon   err   pppd[249]: User name and password authentication failed.
Jan 1 00:00:42   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:00:42   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:00:45   daemon   notice   pppd[249]: PPP: Start to connect ...
Jan 1 00:00:45   daemon   crit   pppd[249]: PPP server detected.
Jan 1 00:00:45   daemon   crit   pppd[249]: PPP session established.
Jan 1 00:00:46   daemon   crit   pppd[249]: PPP LCP UP.
Jan 1 00:00:46   daemon   crit   pppd[249]: Received valid IP address from server. Connection UP.
Jan 1 00:00:47   user   debug   syslog: route add default gw 83.239.148.1 2>/dev/null
Jan 1 00:00:47   user   debug   syslog: iptables -A FORWARD -o ppp_8_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:00:47   user   debug   syslog: iptables -A FORWARD -i ppp_8_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:00:47   user   debug   syslog: echo > /proc/net/ip_conntrack
Jan 1 00:00:47   user   debug   syslog: echo "512" > /proc/sys/net/ipv4/ip_conntrack_max
Jan 1 00:00:47   user   debug   syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Jan 1 00:00:47   user   debug   syslog: iptables -t nat -D POSTROUTING -o ppp_8_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Jan 1 00:00:47   user   debug   syslog: iptables -t nat -A POSTROUTING -o ppp_8_35_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Jan 1 00:00:47   user   debug   syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 83.239.131.8 2>/dev/null
Jan 1 00:00:47   user   debug   syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 83.239.131.8
Jan 1 00:00:48   user   debug   syslog: /bin/dnsprobe &
Jan 1 00:00:48   user   debug   syslog: upnp -L br0 -W ppp_8_35_1 -D
Jan 1 00:00:48   user   notice   dnsprobe[783]: dnsprobe started!
Jan 1 00:00:48   user   debug   syslog: iptables -t filter -I OUTPUT -o ppp_8_35_1 -d 239.255.255.250 -j DROP 2>/dev/null
Jan 1 00:00:49   user   debug   syslog: iptables -D INPUT -i ppp_8_35_1 -j DROP
Jan 1 00:00:49   user   debug   syslog: iptables -A INPUT -i ppp_8_35_1 -j DROP
СообщениеДобавлено: Чт май 15, 2008 13:26
Судя по этим строкам сессия еще "висит" на стороне сервера провайдера. Поэтому подключиться к нему нельзя. Каково примерное расстояние до Вашей АТС?
СообщениеДобавлено: Чт май 15, 2008 13:41
За 5-10 минут можно пешком дойти, сколько это в километрах я сказать затрудняюсь...
Сейчас этот форум просматривают: Google [Bot] и гости: 32
