Текущее время: Ср окт 28, 2026 08:20
СообщениеДобавлено: Чт май 13, 2004 16:03
Почему?
Из этого можно что-то понять?
ggdbg>spy hsmu 0
ggdbg>000004205 HSMU 0: hsmup_cmEvCallFastStartSetup_api: Search for FS capability.
000004205 HSMU: partnerChannelsNum = 1.
000004205 HSMU: == Channel 0
000004205 HSMU: type cmCapAudio
000004205 HSMU: transmit alt channels number = 1.
000004205 HSMU: transmit ch 0: g7231.
000004205 HSMU: receive alt channels number = 1.
000004205 HSMU: receive ch 0: g7231.
000004205 HSMU: Fast Start symmetric channels:
000004205 HSMU: 0: g7231
000004205 HSMU: h323_get_static_cap_name capability name "g7231"
000004205 HSMU 0: CallingPartyId = "TA:10.10.10.10:4865,NAME:gw_pr_Cisco_827-4v,ххххх"
000004205 HSMU 0: Remote caller ID number = ххххх
000004205 HSMU 0: UserUserInfo = "ххххх"
000004205 HSMU 0: remote CID number:"ххххх", name:"O"
000004205 HSMU 0: received H323 Fast Start call, processing ...
000004329 HSMU: Enter call_profile->capabilities
000004329 HSMU: t.38 codec found at profile 6
000004329 HSMU: Exit call_profile->capabilities.
000004329 HSMU 0: Fast start compatibility check.
000004329 HSMU 0: Match found for g7231 (local = 0, offered = 0)
000004329 HSMU 0: selected fast start channel "g7231".
000004329 HSMU 0: cmControlStateFastStart
000004329 HSMU 0: Starting Capabilities Exchange, capabilities_send=0
000004329 HSMU 0: Sending local capabilities.
000004329 HSMU 0: Chan 0i cmEvChannelSetRTCPAddress_msg IP = 10.10.10.10, Port = 7839
000004329 HSMU 0: Chan 0i - cmChannelStateConnected "g7231"
local RTCP = 0, remote RTCP =7839, RTP = 0.0.0.0:0
000004329 hsmup_fast_start_incoming_lc: nw_open(RTP1), call_num=0, port=0, Chan_num(i/o)=1719i
000004329 HSMU 0: Chan 0i: Opened RTP socket = 1, cmChannel = 1719
000004329 hsmup_fast_start_incoming_lc: nw_open(RTCP2), call_num=0, port=1720, chan_num(i/o)=0i
000004329 HSMU 0: Chan 0i: Opened RTCP socket = 2, port 1720
000004329 HSMU 0: Chan 0o cmEvChannelSetRTCPAddress_msg IP = 10.10.10.10, Port = 7841
000004329 HSMU 0: Chan 0o cmEvChannelSetAddress_msg IP = 10.10.10.10, Port = 7840
000004329 HSMU 0: Chan 0o - cmChannelStateConnected "g7231"
local RTCP = 0, remote RTCP =7841, RTP = 10.10.10.10:7840
000004329 HSMU 0: VOICE CONNECTED, coding=g7231, FAST START mode, terminating
000004330 HSMU 0: set timer for 30000 in state hsmup_state_voice_connected
000004334 HSMU 0: cmControlStateTransportConnected, Control channel opened for Fast Start call.
000004353 HSMU 0: Starting Capabilities Exchange, capabilities_send=1
000004353 HSMU: h323_get_static_cap_name capability name "nonStandard"
000004353 HSMU: h323_get_static_cap_name NOT FOUND!
000004354 HSMU: Invalid capability name "hookflash"
000004354 HSMU: h323_get_static_cap_name NOT FOUND!
000004354 HSMU: Invalid capability name "dtmf"
000004354 HSMU: Invalid capability name "basicString"
000004354 HSMU: h323_get_static_cap_name capability name "g7231"
000004354
000004354 Capability Set
000004354 HSMU 0: hsmup_rad_call_capabilities() Ignore regular capability match during Fast Start.
000004354 HSMU 0: CapabilitiesExt_msg
000004372 HSMU 0: cmEvCallMasterSlaveStatus_msg: Local station is Slave
000004372 HSMU 0: cmControlStateConnected, p_call->fast_start_on=1
000004399 HSMU 0: abort timer in state hsmup_state_voice_connected
000004399 HSMU 0: set timer for 10000 in state hsmup_state_fax_channel
000004408 HSMU 0: abort timer in state hsmup_state_fax_channel
000004410 HSMU 0: H.323 release (IF)
000004462 HSMU 0: voice rtp open=0, rtcp open=0, nw_close(voice socked RTP0, RTCP0)
000004462 HSMU 0: nw_close(inchan local RTCP2, RTP1)
000004462 HSMU 0: nw_close(inchan local RTCP65535, RTP65535)
000004462 HSMU 0: nw_close(outchan local RTCP65535)
СообщениеДобавлено: Пт май 14, 2004 09:13
Что удалось выяснить дополнительно...
Если на циске разрешить H245 - тогда отбой после первого звонка НЕ происходит. Но и соединение не устанавливается :о) Д-линк, естественно, не отвечает на H245-запросы и циска по тайм-ауту отбивается.
Только отключаю H245 - происходит отбой после первого звонка...
И еще, заметил что д-линк, почему-то при этом входящем вызове пытается перейти на факсовый кодек. Это еще почему???
Неужто ни у кого мылЕй нет???
