Текущее время: Сб июн 15, 2024 23:25
СообщениеДобавлено: Ср сен 04, 2019 10:56
Все работало несколько лет, вдруг ни с того ни с сего, посредь рабочего дня....
Работает в связке с астериском.
Подскажите куда копать??
Вот лог со шлюза:
04.09.2019,11:50:24,192.168.0.254,???,LOCAL0,NOTICE, 84C9B2CF69E0-sip: Registered [*censored*]
04.09.2019,11:50:25,192.168.0.254,???,LOCAL0,NOTICE, 84C9B2CF69E0-sip: Registered [*censored*]
04.09.2019,11:51:01,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (018221) Something Changed!
04.09.2019,11:51:01,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (018221) <Save>
04.09.2019,11:51:03,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (018224) Save Settings OK
04.09.2019,11:51:03,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (018225) <End SIP>
04.09.2019,11:51:05,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (018238) GwMsgCmd=1()
04.09.2019,11:51:05,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (018238) <Restart>
04.09.2019,11:51:05,192.168.0.254,???,LOCAL0,NOTICE, 84C9B2CF69E0-gw: Reboot
04.09.2019,11:51:34,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (000058) SetWanPortBasedQos
04.09.2019,11:51:41,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: Connect
04.09.2019,11:51:41,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: Idle
04.09.2019,11:51:41,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 1: Connect
04.09.2019,11:51:41,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 1: Idle
04.09.2019,11:51:41,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 2: Connect
04.09.2019,11:51:41,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 2: Idle
04.09.2019,11:51:41,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 3: Disconnect
04.09.2019,11:51:41,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 3: Disable
04.09.2019,11:51:43,192.168.0.254,???,LOCAL0,NOTICE, 84C9B2CF69E0-sip: Registered [*censored*]
04.09.2019,11:51:43,192.168.0.254,???,LOCAL2,INFO, 84C9B2CF69E0-sip: SipLineRegStatus=41210044444
04.09.2019,11:51:43,192.168.0.254,???,LOCAL2,INFO, 84C9B2CF69E0-sip: SipLineRegStatus=41220044444
04.09.2019,11:51:44,192.168.0.254,???,LOCAL0,NOTICE, 84C9B2CF69E0-sip: Registered [*censored*]
04.09.2019,11:51:44,192.168.0.254,???,LOCAL2,INFO, 84C9B2CF69E0-sip: SipLineRegStatus=42220044444
04.09.2019,11:52:12,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 105 CallIn 890********
04.09.2019,11:52:12,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: TrunkDialOut
04.09.2019,11:52:13,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: PSTN Dial 890********
04.09.2019,11:52:51,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: PlayBusyTone
04.09.2019,11:52:53,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: Idle
04.09.2019,11:58:27,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: Disable
04.09.2019,11:58:28,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (004082) Something Changed!
04.09.2019,11:58:51,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (004301) Something Changed!
04.09.2019,11:59:40,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (004781) Something Changed!
04.09.2019,11:59:40,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (004781) <Save>
04.09.2019,11:59:43,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (004784) Save Settings OK
04.09.2019,11:59:43,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (004785) <End SIP>
04.09.2019,11:59:45,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (004799) GwMsgCmd=1()
04.09.2019,11:59:45,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (004799) <Restart>
04.09.2019,11:59:45,192.168.0.254,???,LOCAL0,NOTICE, 84C9B2CF69E0-gw: Reboot
04.09.2019,12:00:13,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (000049) SetWanPortBasedQos
04.09.2019,12:00:21,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: Connect
04.09.2019,12:00:21,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: Disable
04.09.2019,12:00:21,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 1: Connect
04.09.2019,12:00:21,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 1: Idle
04.09.2019,12:00:21,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 2: Connect
04.09.2019,12:00:21,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 2: Idle
04.09.2019,12:00:21,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 3: Disconnect
04.09.2019,12:00:22,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 3: Disable
04.09.2019,12:00:22,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 1: Connect
04.09.2019,12:00:22,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 2: Connect
04.09.2019,12:00:24,192.168.0.254,???,LOCAL0,NOTICE, 84C9B2CF69E0-sip: Registered [*censored*]
04.09.2019,12:00:24,192.168.0.254,???,LOCAL2,INFO, 84C9B2CF69E0-sip: SipLineRegStatus=41020044444
04.09.2019,12:00:24,192.168.0.254,???,LOCAL2,INFO, 84C9B2CF69E0-sip: SipLineRegStatus=42020044444
04.09.2019,12:03:37,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 105 CallIn 890********
04.09.2019,12:03:37,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 1: TrunkDialOut
04.09.2019,12:03:38,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 1: PSTN Dial 890********
04.09.2019,12:04:50,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 1: PlayBusyTone
04.09.2019,12:04:52,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 1: Idle
04.09.2019,12:10:32,192.168.0.254,???,LOCAL0,NOTICE, 84C9B2CF69E0-sip: Registered [*censored*]
04.09.2019,12:10:33,192.168.0.254,???,LOCAL0,NOTICE, 84C9B2CF69E0-sip: Registered [*censored*]
04.09.2019,12:11:14,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (006461) Something Changed!
04.09.2019,12:11:15,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: Idle
04.09.2019,12:11:15,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: Connect
04.09.2019,12:11:45,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (006761) Something Changed!
04.09.2019,12:12:24,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (007142) Something Changed!
04.09.2019,12:12:24,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (007142) <Save>
04.09.2019,12:12:27,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (007146) Save Settings OK
04.09.2019,12:12:27,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (007147) <End SIP>
04.09.2019,12:12:28,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (007160) GwMsgCmd=1()
04.09.2019,12:12:28,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (007160) <Restart>
04.09.2019,12:12:28,192.168.0.254,???,LOCAL0,NOTICE, 84C9B2CF69E0-gw: Reboot
04.09.2019,12:12:59,192.168.0.254,???,LOCAL0,INFO, 84C9B2CF69E0-gw: (000058) SetWanPortBasedQos
04.09.2019,12:13:06,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: Connect
04.09.2019,12:13:06,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: Idle
04.09.2019,12:13:06,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 1: Connect
04.09.2019,12:13:06,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 1: Idle
04.09.2019,12:13:06,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 2: Connect
04.09.2019,12:13:06,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 2: Idle
04.09.2019,12:13:06,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 3: Disconnect
04.09.2019,12:13:06,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 3: Disable
04.09.2019,12:13:07,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: Connect
04.09.2019,12:13:07,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 1: Connect
04.09.2019,12:13:07,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 2: Connect
04.09.2019,12:13:09,192.168.0.254,???,LOCAL0,NOTICE, 84C9B2CF69E0-sip: Registered [*censored*]
04.09.2019,12:13:09,192.168.0.254,???,LOCAL2,INFO, 84C9B2CF69E0-sip: SipLineRegStatus=41210044444
04.09.2019,12:13:09,192.168.0.254,???,LOCAL2,INFO, 84C9B2CF69E0-sip: SipLineRegStatus=41220044444
04.09.2019,12:13:09,192.168.0.254,???,LOCAL2,INFO, 84C9B2CF69E0-sip: SipLineRegStatus=42220044444
04.09.2019,12:23:17,192.168.0.254,???,LOCAL0,NOTICE, 84C9B2CF69E0-sip: Registered [*censored*]
04.09.2019,12:26:03,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 107 CallIn 890********
04.09.2019,12:26:03,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: TrunkDialOut
04.09.2019,12:26:05,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: PSTN Dial 890********
04.09.2019,12:27:39,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: PlayBusyTone
04.09.2019,12:27:40,192.168.0.254,???,LOCAL1,INFO, last message repeated 1 time(s)
04.09.2019,12:27:40,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: Idle
04.09.2019,12:33:26,192.168.0.254,???,LOCAL0,NOTICE, 84C9B2CF69E0-sip: Registered [*censored*]
04.09.2019,12:34:48,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 107 CallIn 890********
04.09.2019,12:34:48,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: TrunkDialOut
04.09.2019,12:34:49,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: PSTN Dial 890********
04.09.2019,12:36:24,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: PlayBusyTone
04.09.2019,12:36:27,192.168.0.254,???,LOCAL1,INFO, last message repeated 1 time(s)
04.09.2019,12:36:27,192.168.0.254,???,LOCAL1,INFO, 84C9B2CF69E0-sip: 0: Idle
04.09.2019,12:43:35,192.168.0.254,???,LOCAL0,NOTICE, 84C9B2CF69E0-sip: Registered [*censored*]
04.09.2019,12:43:36,192.168.0.254,???,LOCAL0,NOTICE, 84C9B2CF69E0-sip: Registered [*censored*]
04.09.2019,12:53:44,192.168.0.254,???,LOCAL0,NOTICE, 84C9B2CF69E0-sip: Registered [*censored*]
а вот лог с slmon-а
Log2541.png [ 83.53 KiB | Просмотров: 2537 ]
СообщениеДобавлено: Пн сен 09, 2019 16:00
Здравствуйте, обычно такие проблемы наблюдаются когда на каком-то участке сети блокируется голосовой трафик - RTP-поток.
