Текущее время: Вт июл 23, 2019 06:37
СообщениеДобавлено: Ср фев 21, 2018 14:49
DES-3200-28F
Boot PROM Version : Build 4.00.002
Firmware Version : Build 4.48.B003
Hardware Version : C1
Флапают каждые 5 сек. все активные 100 Мбит порты.
Command: show log
Index Date       Time     Level   Log Text
24402 2018-02-21 14:40:18 INFO(6) Port 17 link up, 100Mbps FULL duplex
24401 2018-02-21 14:40:18 INFO(6) Port 17 link down
24400 2018-02-21 14:40:12 INFO(6) Port 16 link up, 100Mbps FULL duplex
24399 2018-02-21 14:40:12 INFO(6) Port 16 link down
24398 2018-02-21 14:39:59 INFO(6) Port 14 link up, 100Mbps FULL duplex
24397 2018-02-21 14:39:59 INFO(6) Port 14 link down
24396 2018-02-21 14:39:53 INFO(6) Port 13 link up, 100Mbps FULL duplex
24395 2018-02-21 14:39:53 INFO(6) Port 13 link down
24394 2018-02-21 14:39:47 INFO(6) Port 12 link up, 100Mbps FULL duplex
24393 2018-02-21 14:39:47 INFO(6) Port 12 link down
24392 2018-02-21 14:39:34 INFO(6) Port 10 link up, 100Mbps FULL duplex
24391 2018-02-21 14:39:34 INFO(6) Port 10 link down
24390 2018-02-21 14:39:28 INFO(6) Port 9 link up, 100Mbps FULL duplex
24389 2018-02-21 14:39:28 INFO(6) Port 9 link down
24388 2018-02-21 14:39:22 INFO(6) Port 8 link up, 100Mbps FULL duplex
24387 2018-02-21 14:39:22 INFO(6) Port 8 link down
24386 2018-02-21 14:39:09 INFO(6) Port 6 link up, 100Mbps FULL duplex
24385 2018-02-21 14:39:09 INFO(6) Port 6 link down
24384 2018-02-21 14:38:50 INFO(6) Port 3 link up, 100Mbps FULL duplex
24383 2018-02-21 14:38:50 INFO(6) Port 3 link down
24382 2018-02-21 14:38:44 INFO(6) Port 2 link up, 100Mbps FULL duplex
24381 2018-02-21 14:38:44 INFO(6) Port 2 link down
24380 2018-02-21 14:38:38 INFO(6) Port 1 link up, 100Mbps FULL duplex
24379 2018-02-21 14:38:38 INFO(6) Port 1 link down
24378 2018-02-21 14:37:46 INFO(6) Port 21 link up, 100Mbps FULL duplex
24377 2018-02-21 14:37:46 INFO(6) Port 21 link down
24376 2018-02-21 14:37:40 INFO(6) Port 20 link up, 100Mbps FULL duplex
24375 2018-02-21 14:37:40 INFO(6) Port 20 link down
24374 2018-02-21 14:37:33 INFO(6) Port 19 link up, 100Mbps FULL duplex
24373 2018-02-21 14:37:33 INFO(6) Port 19 link down
24372 2018-02-21 14:37:27 INFO(6) Port 18 link up, 100Mbps FULL duplex
24371 2018-02-21 14:37:27 INFO(6) Port 18 link down
CPU уходит в вечные 100% через какое-то время после ребута
Command: debug show cpu utilization
Five seconds - 100 %         One minute - 100 %         Five minutes -  99 %
Process Name        5Sec %   1Min %   5Min %
GBIC_Pooling            52       46       44
DDM_TIC                 38       42       43
bcmL2X.0                 8        8        8
bcmCNTR.0                1        1        1
Что бы это значило? В ремонт, или где-то косяк с конфигом ?
P.S. Мультикаст и подобная "дрянь" в сети отсутствует, трафик мизерный.
P.P.S Откатил прошивку на Build 4.46.B004 - флапать не перестало, но загрузка CPU за час работы выше 30% не поднималась.
Также исчезли строки GBIC_Pooling и DDM_TIC из дебага. Сейчас так:
Five seconds -  28 %         One minute -  25 %         Five minutes -  25 %
OS_UTIL                 82       75       75
bcmL2X.0                12       10       10
bcmLINK.0                2        2        2
bcmCNTR.0                1        1        1
HISR1                    1        1        1
DRV_ARL_EX               0        3        4
ST_ULINK                 0        3        3
Последний раз редактировалось KovAl59 Пт фев 23, 2018 09:07, всего редактировалось 1 раз.
СообщениеДобавлено: Чт фев 22, 2018 10:45
Здравствуйте
У нас была подобная проблема, причиной была подкороченый/подгоревший sfp модуль
Нашли проблемную SFP при помощи консольника:
подключились к коммутатору COM портом, при перезагрузке смотрим, что выдает при логе загрузки, там будут ошибки и номер порта.
Поменяли sfp и все сразу стало как надо
ISP LuxLite
СообщениеДобавлено: Чт фев 22, 2018 12:40
Похоже, это не наш случай.. У меня тоже были подозрения на дохлый SFP, но..
Заменили коммутатор на 100% аналогичный и с заливкой конфига от проблемного - всё заработало..
"Старый" запустил на столе, прицепил на него два тестовых линка - никаких проблем..
Единственное отличие от рабочего - это количество задействованных портов (на рабочем было 16 активных линков).
Склоняюсь к тому, что проблема аппаратная, возможно что-то связанное с питанием оптических портов.
Без отправки в СЦ возможно это как-то подтвердить/опровергнуть?
СообщениеДобавлено: Пт фев 23, 2018 03:38
ну так набейте в него такое же количество sfp, а не два, и сделайте кольца между ними, чтобы линки поднялись )
или что вы хотите услышать для "подтвердить/опровергнуть"?
/nixx
СообщениеДобавлено: Пт фев 23, 2018 09:06
Ну например, нет ли у коммутатора "индикатора состояния питания" для оптических портов?
Типа как у 3526 - Power Status : Main - Normal, Redundant - Not Present.
СообщениеДобавлено: Сб фев 24, 2018 07:19
У 3526 это же состояние 2х БП (основной и дополнительный) а не статус работы самого БП
СообщениеДобавлено: Пн мар 12, 2018 13:19
День добрый прощу помощи.
DES-3200-28F-C1 была прошивка 4.39.B015
работает уже несколько лет с 2015/12/10
модули все 1G но с самого начала в настройках было выставлено 100мбит - тогда был замечен глюк порты флапали, если скорость порта auto.
11.03.2014 решил обновить на 4.46B008 - и начались приколы снова начали флапать порты.
загрузка прошивки 4.39.B015 проблему не решила - порты продолжают флапать. Загрузка старого(рабочего) конфига также ничего не дает.
Такое ощущение, что в новой прошивке изменен как-то параметр по умолчанию и т.к. его нет в старом конфиге, то проблема не решается возвратом прошивки и конфига.
Что может быть ?
Есть только миг между прошлым и будущим, именно он называется - ping.
СообщениеДобавлено: Пн мар 12, 2018 13:20
порты выставлены принудительно в 100_full ?
config ports 1-24 speed 100_full
СообщениеДобавлено: Пн мар 12, 2018 13:38
да.
show config modified
# PORT
config ports 1-24,26 speed 100_full
 Port      State/          Settings             Connection          Address
           MDIX      Speed/Duplex/FlowCtrl  Speed/Duplex/FlowCtrl   Learning
 1        Enabled   100M/Full/Disabled     100M/Full/None          Enabled
 2        Enabled   100M/Full/Disabled     100M/Full/None          Enabled
 3        Enabled   100M/Full/Disabled     100M/Full/None          Enabled
 4        Enabled   100M/Full/Disabled     100M/Full/None          Enabled
 5        Enabled   100M/Full/Disabled     100M/Full/None          Enabled
[spoiler]
На соседнем коммутаторе стоит 4.46.B006 где таких глюков нет, но там все модули 100мбит которые в 100мбитных портах.
Я перешил тоже не 4.46.B006 - потом сделал system reset, после переразруки залил конфиг от 4.39.B015 - не помогло.
И что интересно команда dir показала что все файлы которые я заливал так и оставились.
Может нужно как-то по другому сбросить свитч ?
PS. флапает, ужас...
3822  2000-01-01 02:07:58 WARN(4) Unauthenticated IP-MAC address and discarded b
                                  y IMPB(IP:<91.234.73.23>, MAC:<84-16-F9-A8-67-
                                  19>, Port<13>)
3821  2000-01-01 02:07:58 INFO(6) Port 24 link up, 100Mbps FULL duplex
3820  2000-01-01 02:07:58 INFO(6) Port 24 link down
3819  2000-01-01 02:07:58 INFO(6) Port 23 link up, 100Mbps FULL duplex
3818  2000-01-01 02:07:58 INFO(6) Port 23 link down
3817  2000-01-01 02:07:58 INFO(6) Port 22 link up, 100Mbps FULL duplex
3816  2000-01-01 02:07:58 INFO(6) Port 22 link down
3815  2000-01-01 02:07:58 INFO(6) Port 19 link up, 100Mbps FULL duplex
3814  2000-01-01 02:07:58 INFO(6) Port 19 link down
3813  2000-01-01 02:07:58 INFO(6) Port 16 link up, 100Mbps FULL duplex
3812  2000-01-01 02:07:58 INFO(6) Port 16 link down
3811  2000-01-01 02:07:58 INFO(6) Port 15 link up, 100Mbps FULL duplex
3810  2000-01-01 02:07:58 INFO(6) Port 15 link down
3809  2000-01-01 02:07:58 INFO(6) Port 14 link up, 100Mbps FULL duplex
3808  2000-01-01 02:07:58 INFO(6) Port 14 link down
3807  2000-01-01 02:07:58 INFO(6) Port 13 link up, 100Mbps FULL duplex
3806  2000-01-01 02:07:58 INFO(6) Port 13 link down
СообщениеДобавлено: Пн мар 12, 2018 13:48
еще не понятно:
команда show ports 1-28 media_type говорит - НИЧЕГО:
DES-3200-28F:admin#show ports 1-28 media_type
Command: show ports 1-28 media_type
 Port     Type           Vendor name/       PN/                SN/
                         OUI                Rev                Date Code
 1       100Base-X              -                  -                  -
 2       100Base-X              -                  -                  -
 3       100Base-X              -                  -                  -
 4       100Base-X              -                  -                  -
 5       100Base-X              -                  -                  -
 6       100Base-X              -                  -                  -
 7       100Base-X              -                  -                  -
 8       100Base-X              -                  -                  -
 9       100Base-X              -                  -                  -
 10      100Base-X              -                  -                  -
 11      100Base-X              -                  -                  -
 12      100Base-X              -                  -                  -
 13      100Base-X              -                  -                  -
 14      100Base-X              -                  -                  -
 15      100Base-X              -                  -                  -
 16      100Base-X              -                  -                  -
 17      100Base-X              -                  -                  -
 18      100Base-X              -                  -                  -
 19      100Base-X              -                  -                  -
 20      100Base-X              -                  -                  -
 21      100Base-X              -                  -                  -
 22      100Base-X              -                  -                  -
 23      100Base-X              -                  -                  -
 24      100Base-X              -                  -                  -
 25  (C) 1000Base-T             -                  -                  -
 25  (F) 1000Base-X             -                  -                  -
 26  (C) 1000Base-T             -                  -                  -
 26  (F) 1000Base-X             -                  -                  -
 27  (C) 1000Base-T             -                  -                  -
 27  (F) 1000Base-X             -                  -                  -
 28  (C) 1000Base-T             -                  -                  -
 28  (F) 1000Base-X             -                  -                  -
что странно ревизия C1 - должна показывать. тем более на соседнем на котором линки не флапают - там все вычитало.
Сейчас монтажники дойдут до свитча, точно скажут все какие там модули стоят. т.к. есть вероятность что часть из модулей 100мбит.... ну и перезагрузят свитч по питанию.
Вопрос таки повторю, как сбросить свитч чтобы все вернуть к заводским настройкам включая файловую систему.?
СообщениеДобавлено: Пн мар 12, 2018 14:43
что выяснили:
1) при прошивке 4.46.B006 - отключили питание свитча - после загрузки - порты вернули данные по команде
show ports media_type
DES-3200-28F:admin#show ports media_type
Command: show ports media_type
                         OUI                Rev                Date Code
 1       SFP LC          OEM/               WDM-155M-1550TX/   Y9CG010039/
                         0 :90:65           A                  091216
         Compatibility: Single Mode (SM),100Mbd, 1550nm
 2       SFP LC          OEM/               WDM-155M-1550TX/   Y9CG010031/
                         0 :90:65           A                  091216
 3       SFP LC          OEM/               SFP-BX-D55/        H500718/
                         0 :0 :0            1.0                090301
         Compatibility: Single Mode (SM),1300Mbd, 1310nm
 4       SFP LC          OEM/               SFP-BX-D55/        H500727/
                         0 :0 :0            1.0                090301
 5       SFP LC          OEM/               SFP-BX-D55/        H500728/
                         0 :0 :0            1.0                090301
 6       SFP LC          OEM/               SFP-BX-D55/        H500717/
                         0 :0 :0            1.0                090301
 7       SFP LC          OEM/               SFP-155-BIDI-155/  S99S020029/
                         0 :90:65           A                  090928
 8       SFP LC          OEM/               WDM-155M-1550TX/   Y9CG010037/
                         0 :90:65           A                  091216
 9       SFP LC          OEM/               SFP-155-BIDI-155/  S99S020028/
                         0 :90:65           A                  090928
 10      SFP LC          OEM/               FE-100LX/          FA9609FEL11/
                         20:20:20           1.0                090616
         Compatibility: Single Mode (SM),100Mbd, 1310nm
 11      SFP LC          OEM/               FE-100LX/          FA9609FEL12/
                         20:20:20           1.0                090616
 12      SFP LC          OEM/               FE-100LX/          FA9609FEL74/
                         20:20:20           1.0                090616
 13      SFP LC          OEM/               FE-100LX/          FA9609FEL13/
                         20:20:20           1.0                090616
 14      SFP LC          OEM/               SFP-155-BIDI-155/  S99S020027/
                         0 :90:65           A                  090928
 15      SFP LC          OEM/               FE-100LX/          FA9609FEL78/
                         20:20:20           1.0                090616
 16      SFP LC          OEM/               GLF-S30-13-C/      YA1D790087/
                         20:20:20           A0                 100121
 17      SFP LC          OEM/               GLF-S30-13-C/      YA1D790083/
                         20:20:20           A0                 100121
 18      SFP LC          OEM/               GLF-S30-13-C/      YA1D790084/
                         20:20:20           A0                 100121
 19      SFP LC          OEM/               FE-100LX/          FA9609FEL14/
                         20:20:20           1.0                090616
 20      SFP LC          OEM/               WDM-155M-1550TX/   Y9CG010035/
                         0 :90:65           A                  091216
 21      SFP LC          OEM/               SFP-155-BIDI-155/  S99S020030/
                         0 :90:65           A                  090928
 22      -               OEM/               SFP-1SM-13-3SC/    U2013006300869/
                         0 :90:65           A0                 201308
 23      SFP LC          OEM/               SFP-WDM1.25G-55/   YC9L610758/
                         0 :90:65           A0                 120924
         Compatibility: Single Mode (SM),1300Mbd, 1550nm
 24      -               OEM/               LS-WGS-3-T15/      LS17050564/
                         0 :0 :0                               170531
 25  (F) SFP LC          OEM/               EOLS-1312-10/      SB34151809/
                         0 :90:65           10.0               110316
         Compatibility: Single Mode (SM),20800Mbd, 1310nm
 28  (F) SFP LC          OEM/               SFP-BX-U31/        H501344/
                         0 :0 :0            1.0                090301
поднялись порты и некоторые флапают некоторые нет.
выяснилось что где модуль 100мбит - и стоит конфиг config ports 18 speed 100_full - порт флапает. как только поставил в режим auto - перестало флапать.
Но не все порты. есть порты которые 100мбит и в режиме 100_full - не флапают.
Явно глюк про прошивке.
Пока остаюсь на 4.46.B006
СообщениеДобавлено: Пн мар 12, 2018 21:29
Maksel писал(а):
что выяснили:
с таким зверинцем разношерстных модулей (я насчитал 9 разных моделей) совершенно неудивительны абсолютно любые глюки.
оставьте все модули одной модели, тогда и смотрите. либо будут глючить все сразу, либо наоборот.
у вас загрузка проца какая при флапах?
а если выдернуть sfp?
а если воткнуть, но не поднимать линки?
аптайм у свитча до перешивки долгий был? он уже ребутился со старой прошивкой с этим набором sfp, или перешили, и первый раз за ~2-3 года ребутнули? (ну то есть может он бы флапал и со старой прошивкой, если бы его ребутнули со всеми теми sfp, что в него натыканы).
разработчики длинка, ничего не говоря в чейнджлоге, последнее время (пару лет или больше) бодро добавляют и меняют в прошивках практически всех свитчей разные вещи по работе с sfp-модулями.
и заливая новую прошивку, в которой fixed что-то безобидное типа igmp querier, может оказаться, что после ребута у вас тупо не встанет какой-нибудь оптический линк, потому что sfp модуль после ребута перестал нравиться свитчу.
а насчет самой прошивки - мы до сих пор сидим на версии 4.37, потому что дальше пошли чюдеса-тормоза помимо sfp, и длинк никак не реагировал на жалобы. и судя по таким вот постам, как ваш - и не перейдем на более свежие, пока нехватки какой-то фичи не ощутим ))
/nixx
СообщениеДобавлено: Ср мар 28, 2018 23:09
свитч с этим набором sfp модулей стоит уже больше 2х лет. и да соответственно перезагружался не раз. глюки начались с новой прошивкой.
Так как свитч на крыше, то сильно не подергаешь sfp.
На счет прошивки - прошил на свой страх и риск все свитчи в сети, больше 100шт, пока вроде новых глюков не замечал. правда 3200-28F-C1 всего один.
СообщениеДобавлено: Пт июн 22, 2018 18:53
Тоже была проблема с флапающимися линками на прошивках выше 4.38.B000. Откатился на 4.37.B014, полёт нормальный.
