Сделал несколько тестов с одним кабелем (тот же самый или нет - не знаю). Для каждого сохранил результат, лог и засек время в секундах сколько ждал в итоге. Первый порт в паре указан для ID=1.
ID1=27 - ID2=28:
OK 27-28 (155):
вывод не сохранился
fail 27-28 (300):
4 2014-04-27 07:40:17 CRIT(2) Unit 1, System started up
3 2014-04-27 07:40:17 CRIT(2) Unit 1, System warm start
2 2014-04-27 07:40:14 INFO(6) Unit 2, MAC: 3c-1e-04-97-12-00 Hot removal.
fail 27-28 (240):
5 2014-04-27 07:45:38 INFO(6) Stacking topology is Chain. Master (Unit 1, MAC: 3C-1E-04-97-10-C0).
4 2014-04-27 07:45:38 CRIT(2) Unit 1, System started up
3 2014-04-27 07:45:38 CRIT(2) Unit 1, System cold start
2 2014-04-27 07:45:36 INFO(6) Unit 2, MAC: 3c-1e-04-97-12-00 Hot removal.
ID1=28 - ID2=28:
OK 28-28 (120):
6 2014-04-27 07:50:45 INFO(6) Stacking topology is Chain. Master (Unit 1, MAC: 3C-1E-04-97-10-C0).
5 2014-04-27 07:50:45 CRIT(2) Unit 1, System started up
4 2014-04-27 07:50:45 CRIT(2) Unit 1, System warm start
3 2014-04-27 07:50:45 INFO(6) Port 2:26 link down
2 2014-04-27 07:50:45 INFO(6) Port 2:25 link down
OK 28-28 (120):
6 2014-04-27 07:54:14 INFO(6) Stacking topology is Chain. Master (Unit 1, MAC: 3C-1E-04-97-10-C0).
5 2014-04-27 07:54:14 CRIT(2) Unit 1, System started up
4 2014-04-27 07:54:14 CRIT(2) Unit 1, System warm start
3 2014-04-27 07:54:14 INFO(6) Port 2:26 link down
2 2014-04-27 07:54:14 INFO(6) Port 2:25 link down
OK 28-28 (120):
6 2014-04-27 07:56:45 INFO(6) Stacking topology is Chain. Master (Unit 1, MAC: 3C-1E-04-97-10-C0).
5 2014-04-27 07:56:45 INFO(6) Port 2:26 link down
4 2014-04-27 07:56:45 INFO(6) Port 2:25 link down
3 2014-04-27 07:56:45 CRIT(2) Unit 1, System started up
2 2014-04-27 07:56:45 CRIT(2) Unit 1, System cold start
ID1=28 - ID2=27:
OK 28-27 (120):
6 2014-04-27 07:59:32 INFO(6) Stacking topology is Chain. Master (Unit 1, MAC: 3C-1E-04-97-10-C0).
5 2014-04-27 07:59:32 CRIT(2) Unit 1, System started up
4 2014-04-27 07:59:32 CRIT(2) Unit 1, System cold start
3 2014-04-27 07:59:32 INFO(6) Port 2:26 link down
2 2014-04-27 07:59:32 INFO(6) Port 2:25 link down
OK 28-27 (120):
6 2014-04-27 08:02:11 INFO(6) Stacking topology is Chain. Master (Unit 1, MAC: 3C-1E-04-97-10-C0).
5 2014-04-27 08:02:11 CRIT(2) Unit 1, System started up
4 2014-04-27 08:02:11 CRIT(2) Unit 1, System warm start
3 2014-04-27 08:02:11 INFO(6) Port 2:26 link down
2 2014-04-27 08:02:11 INFO(6) Port 2:25 link down
OK 28-27 (120):
6 2014-04-27 08:04:34 INFO(6) Stacking topology is Chain. Master (Unit 1, MAC: 3C-1E-04-97-10-C0).
5 2014-04-27 08:04:34 CRIT(2) Unit 1, System started up
4 2014-04-27 08:04:34 CRIT(2) Unit 1, System warm start
3 2014-04-27 08:04:34 INFO(6) Port 2:26 link down
2 2014-04-27 08:04:34 INFO(6) Port 2:25 link down
ID1=27 - ID2=27:
OK 27-27 (120):
6 2014-04-27 08:13:33 INFO(6) Stacking topology is Chain. Master (Unit 1, MAC: 3C-1E-04-97-10-C0).
5 2014-04-27 08:13:33 CRIT(2) Unit 1, System started up
4 2014-04-27 08:13:33 CRIT(2) Unit 1, System warm start
3 2014-04-27 08:13:33 INFO(6) Port 2:26 link down
2 2014-04-27 08:13:33 INFO(6) Port 2:25 link down
OK 27-27 (120):
6 2014-04-27 08:15:55 INFO(6) Stacking topology is Chain. Master (Unit 1, MAC: 3C-1E-04-97-10-C0).
5 2014-04-27 08:15:55 CRIT(2) Unit 1, System started up
4 2014-04-27 08:15:55 CRIT(2) Unit 1, System warm start
3 2014-04-27 08:15:55 INFO(6) Port 2:26 link down
2 2014-04-27 08:15:55 INFO(6) Port 2:25 link down
OK 27-27 (120):
6 2014-04-27 08:18:25 INFO(6) Stacking topology is Chain. Master (Unit 1, MAC: 3C-1E-04-97-10-C0).
5 2014-04-27 08:18:25 CRIT(2) Unit 1, System started up
4 2014-04-27 08:18:25 CRIT(2) Unit 1, System cold start
3 2014-04-27 08:18:25 INFO(6) Port 2:26 link down
2 2014-04-27 08:18:25 INFO(6) Port 2:25 link down
Затем снова повторил тест как в первом варианте. При этом у меня почему то ID=2 стал мастером. В конфиге каждого потом нашел force_master_role state enable. Это странно, ну да ладно. Разобрал, собрал - мастером стал ID1.
ID1=27 - ID2=28:
OK 27-28 (155):
4 2014-04-27 08:23:03 INFO(6) Stacking topology is Chain. Master (Unit 1, MAC: 3C-1E-04-97-10-C0).
3 2014-04-27 08:23:03 CRIT(2) Unit 1, System started up
2 2014-04-27 08:23:03 CRIT(2) Unit 1, System warm start
fail 27-28 (240):
5 2014-04-27 08:28:13 INFO(6) Stacking topology is Chain. Master (Unit 1, MAC: 3C-1E-04-97-10-C0).
4 2014-04-27 08:28:13 CRIT(2) Unit 1, System started up
3 2014-04-27 08:28:13 CRIT(2) Unit 1, System warm start
2 2014-04-27 08:28:11 INFO(6) Unit 2, MAC: 3c-1e-04-97-12-00 Hot removal.
OK 27-28 (120):
6 2014-04-27 08:30:39 INFO(6) Stacking topology is Chain. Master (Unit 1, MAC: 3C-1E-04-97-10-C0).
5 2014-04-27 08:30:39 CRIT(2) Unit 1, System started up
4 2014-04-27 08:30:39 CRIT(2) Unit 1, System cold start
3 2014-04-27 08:30:39 INFO(6) Port 2:26 link down
2 2014-04-27 08:30:39 INFO(6) Port 2:25 link down
fail 27-28 (180):
5 2014-04-27 08:34:48 INFO(6) Stacking topology is Chain. Master (Unit 1, MAC: 3C-1E-04-97-10-C0).
4 2014-04-27 08:34:46 CRIT(2) Unit 1, System started up
3 2014-04-27 08:34:46 CRIT(2) Unit 1, System warm start
2 2014-04-27 08:34:46 INFO(6) Unit 2, MAC: 3c-1e-04-97-12-00 Hot removal.
После этого в данном варианте стек стал собираться всегда. Заменил кабель, первый раз в варианте 27-28 стек
не собрался, затем собрался. Потом все у меня забрали кабели и они уехали для использования по назначению)
Выводы для моего случая:
1. Стек может не собраться только в варианте ID1=27, ID=28
2. Если стек в варианте 27-28 собирается, обычно это происходит дольше, чем в других вариантах
3. В этом варианте иногда нет сообщений о падении портов 25 и 26. Кстати, в них ничего не подключено.
