Текущее время: Вт окт 15, 2019 02:57
Начать новую тему Ответить на тему  [ Сообщений: 269 ]  На страницу Пред.  1 ... 13, 14, 15, 16, 17, 18  След.
 Заголовок сообщения: Re: FAQ по D-link DNS-323 (Transmission и другое)
СообщениеДобавлено: Ср июн 27, 2012 11:00
ошибки нет. Просто не качает. у меня win7
общаюсь с насом через putty/
Права сделал на Volume_1 и Volume_2 - чтение/запись.
Может здесь что видно?
[14:03:12.830] Transmission 2.41 (12961) started (session.c:718)
[14:03:12.830] RPC Server Adding address to whitelist: 127.0.0.1 (rpc-server.c:803)
[14:03:12.830] RPC Server Serving RPC and Web requests on port 127.0.0.1:9091/transmission/ (rpc-server.c:997)
[14:03:12.830] RPC Server Whitelist enabled (rpc-server.c:1001)
[14:03:12.831] UDP Failed to set receive buffer: requested 4194304, got 217088 (tr-udp.c:75)
[14:03:12.831] UDP Please add the line "net.core.rmem_max = 4194304" to /etc/sysctl.conf (tr-udp.c:80)
[14:03:12.831] UDP Failed to set send buffer: requested 1048576, got 217088 (tr-udp.c:86)
[14:03:12.831] UDP Please add the line "net.core.wmem_max = 1048576" to /etc/sysctl.conf (tr-udp.c:91)
[14:03:12.831] DHT Generating new id (tr-dht.c:309)
[14:03:12.831] Using settings from "/mnt/HD_a2/.transmission-daemon" (daemon.c:488)
[14:03:12.831] Saved "/mnt/HD_a2/.transmission-daemon/settings.json" (bencode.c:1721)
[14:03:12.831] Port Forwarding (NAT-PMP) initnatpmp succeeded (0) (natpmp.c:72)
[14:03:12.831] Port Forwarding (NAT-PMP) sendpublicaddressrequest succeeded (2) (natpmp.c:72)
[14:03:14.842] Port Forwarding (UPnP) Found Internet Gateway Device "http://192.168.0.1:4444/wipconn" (upnp.c:113)
[14:03:14.842] Port Forwarding (UPnP) Local Address is "192.168.0.100" (upnp.c:115)
[14:03:14.842] Port Forwarding (UPnP) Port forwarding through "http://192.168.0.1:4444/wipconn", service "urn:schemas-upnp-org:service:WANIPConnection:1". (local address: 192.168.0.100:51413) (upnp.c:221)
[14:03:14.842] Port Forwarding Starting (port-forwarding.c:93)
[14:03:19.872] Port Forwarding Starting (port-forwarding.c:93)
[14:03:35.768] Saved "/mnt/HD/HD_a2/.transmission-daemon/settings.json" (bencode.c:1721)
[14:03:35.768] DHT Not saving nodes, DHT not ready (tr-dht.c:356)
[14:03:35.768] Port Forwarding Stopped (port-forwarding.c:181)
[14:08:38.124] Transmission 2.41 (12961) started (session.c:718)
[14:08:38.124] RPC Server Adding address to whitelist: 127.0.0.1 (rpc-server.c:803)
[14:08:38.124] RPC Server Adding address to whitelist: *.*.*.* (rpc-server.c:803)
[14:08:38.124] RPC Server Serving RPC and Web requests on port 127.0.0.1:9091/transmission/ (rpc-server.c:997)
[14:08:38.124] UDP Failed to set receive buffer: requested 4194304, got 217088 (tr-udp.c:75)
[14:08:38.124] UDP Please add the line "net.core.rmem_max = 4194304" to /etc/sysctl.conf (tr-udp.c:80)
[14:08:38.124] UDP Failed to set send buffer: requested 1048576, got 217088 (tr-udp.c:86)
[14:08:38.125] UDP Please add the line "net.core.wmem_max = 1048576" to /etc/sysctl.conf (tr-udp.c:91)
[14:08:38.125] DHT Generating new id (tr-dht.c:309)
[14:08:38.125] Using settings from "/mnt/HD_a2/.transmission-daemon" (daemon.c:488)
[14:08:38.125] Saved "/mnt/HD/HD_a2/.transmission-daemon/settings.json" (bencode.c:1721)
[14:08:38.125] Port Forwarding (NAT-PMP) initnatpmp succeeded (0) (natpmp.c:72)
[14:08:38.125] Port Forwarding (NAT-PMP) sendpublicaddressrequest succeeded (2) (natpmp.c:72)
[14:08:41.142] Port Forwarding (UPnP) Found Internet Gateway Device "http://192.168.0.1:4444/wipconn" (upnp.c:113)
[14:08:41.142] Port Forwarding (UPnP) Local Address is "192.168.0.100" (upnp.c:115)
[14:08:41.142] Port Forwarding (UPnP) Port forwarding through "http://192.168.0.1:4444/wipconn", service "urn:schemas-upnp-org:service:WANIPConnection:1". (local address: 192.168.0.100:51413) (upnp.c:221)
[14:08:41.142] Port Forwarding Starting (port-forwarding.c:93)
[14:08:45.166] Port Forwarding Starting (port-forwarding.c:93)
[14:09:35.464] DHT Attempting bootstrap from dht.transmissionbt.com (tr-dht.c:247)
[14:11:04.994] Searching for web interface file "/home/nobody/.local/share/transmission/web/index.html" (platform.c:542)
[14:11:04.994] Searching for web interface file "/ffp/share/transmission/web/index.html" (platform.c:542)
[14:11:33.161] Saved "/mnt/HD_a2/.transmission-daemon/torrents/Mashiny.skazki.vypusk.2..2012.O.DVDRip.0d60a5c5df005a53.torrent" (bencode.c:1721)
[14:11:33.161] Mashiny.skazki.vypusk.2..2012.O.DVDRip Pausing (torrent.c:1763)
[14:11:33.161] Saved "/mnt/HD_a2/.transmission-daemon/resume/Mashiny.skazki.vypusk.2..2012.O.DVDRip.0d60a5c5df005a53.resume" (bencode.c:1721)
[14:11:33.161] Mashiny.skazki.vypusk.2..2012.O.DVDRip Queued for verification (verify.c:260)
[14:11:33.161] Mashiny.skazki.vypusk.2..2012.O.DVDRip Verifying torrent (verify.c:218)
[14:11:41.209] Mashiny.skazki.vypusk.2..2012.O.DVDRip Scrape error: Tracker gave HTTP response code 404 (Not Found) (announcer.c:1246)
[14:11:41.209] Mashiny.skazki.vypusk.2..2012.O.DVDRip Retrying scrape in 302 seconds. (announcer.c:1255)
[14:11:42.215] Mashiny.skazki.vypusk.2..2012.O.DVDRip Starting IPv4 DHT announce (poor, 10 nodes) (tr-dht.c:574)
[14:14:37.252] Couldn't create "/home/nobody": Permission denied (utils.c:557)
[14:14:37.252] Couldn't create "/home/nobody/Downloads/Mashiny.skazki.vypusk.2..2012.O.DVDRip": Permission denied (fdlimit.c:360)
[14:14:37.252] Mashiny.skazki.vypusk.2..2012.O.DVDRip tr_fdFileCheckout failed for "/home/nobody/Downloads/Mashiny.skazki.vypusk.2..2012.O.DVDRip/Vershki.i.koreshki.2012.O.DVDRip.avi.part": Permission denied (inout.c:100)
[14:14:37.252] Mashiny.skazki.vypusk.2..2012.O.DVDRip Permission denied (/home/nobody/Downloads/Mashiny.skazki.vypusk.2..2012.O.DVDRip/Vershki.i.koreshki.2012.O.DVDRip.avi) (torrent.c:487)
[14:14:37.252] Error while flushing completed pieces from cache (session.c:539)
[14:14:37.252] Saved "/mnt/HD/HD_a2/.transmission-daemon/resume/Mashiny.skazki.vypusk.2..2012.O.DVDRip.0d60a5c5df005a53.resume" (bencode.c:1721)
[14:14:37.252] Saved "/mnt/HD_a2/.transmission-daemon/stats.json" (bencode.c:1721)
[14:14:38.258] Mashiny.skazki.vypusk.2..2012.O.DVDRip Pausing (torrent.c:1763)
[14:14:38.258] Couldn't create "/home/nobody": Permission denied (utils.c:557)
[14:14:38.258] Couldn't create "/home/nobody/Downloads/Mashiny.skazki.vypusk.2..2012.O.DVDRip": Permission denied (fdlimit.c:360)
[14:14:38.258] Mashiny.skazki.vypusk.2..2012.O.DVDRip tr_fdFileCheckout failed for "/home/nobody/Downloads/Mashiny.skazki.vypusk.2..2012.O.DVDRip/Bychok.smolyanoi.bochok2012.O.DVDRip.avi.part": Permission denied (inout.c:100)
[14:14:38.258] Saved "/mnt/HD/HD_a2/.transmission-daemon/resume/Mashiny.skazki.vypusk.2..2012.O.DVDRip.0d60a5c5df005a53.resume" (bencode.c:1721)
[14:16:42.997] Mashiny.skazki.vypusk.2..2012.O.DVDRip IPv4 DHT announce done (tr-dht.c:542)
[14:16:51.044] Mashiny.skazki.vypusk.2..2012.O.DVDRip Scrape error: Tracker gave HTTP response code 404 (Not Found) (announcer.c:1246)
[14:16:51.045] Mashiny.skazki.vypusk.2..2012.O.DVDRip Retrying scrape in 309 seconds. (announcer.c:1255)
[14:18:44.210] Couldn't save temporary file "/mnt/HD_a2/.transmission-daemon/settings.json.tmp.ZFrEn1": No such file or directory (bencode.c:1734)
[14:18:44.210] DHT Not saving nodes, DHT not ready (tr-dht.c:356)
[14:18:44.211] Port Forwarding Stopped (port-forwarding.c:181)
[14:18:44.211] Mashiny.skazki.vypusk.2..2012.O.DVDRip Removing torrent (torrent.c:1813)
[14:18:44.211] Mashiny.skazki.vypusk.2..2012.O.DVDRip Pausing (torrent.c:1763)
[14:18:44.211] Couldn't create "/home/nobody": Permission denied (utils.c:557)
[14:18:44.211] Couldn't create "/home/nobody/Downloads/Mashiny.skazki.vypusk.2..2012.O.DVDRip": Permission denied (fdlimit.c:360)
[14:18:44.211] Mashiny.skazki.vypusk.2..2012.O.DVDRip tr_fdFileCheckout failed for "/home/nobody/Downloads/Mashiny.skazki.vypusk.2..2012.O.DVDRip/Malchik.spalchik.2012.O.DVDRip.avi.part": Permission denied (inout.c:100)
[14:18:44.211] Couldn't save temporary file "/mnt/HD_a2/.transmission-daemon/stats.json.tmp.xAOJpX": No such file or directory (bencode.c:1734)
[14:20:37.340] Transmission 2.41 (12961) started (session.c:718)
[14:20:37.340] RPC Server Adding address to whitelist: 127.0.0.1 (rpc-server.c:803)
[14:20:37.340] RPC Server Adding address to whitelist: *.*.*.* (rpc-server.c:803)
[14:20:37.340] RPC Server Serving RPC and Web requests on port 127.0.0.1:9091/transmission/ (rpc-server.c:997)
[14:20:37.340] UDP Failed to set receive buffer: requested 4194304, got 217088 (tr-udp.c:75)
[14:20:37.341] UDP Please add the line "net.core.rmem_max = 4194304" to /etc/sysctl.conf (tr-udp.c:80)
[14:20:37.341] UDP Failed to set send buffer: requested 1048576, got 217088 (tr-udp.c:86)
[14:20:37.341] UDP Please add the line "net.core.wmem_max = 1048576" to /etc/sysctl.conf (tr-udp.c:91)
[14:20:37.341] DHT Generating new id (tr-dht.c:309)
[14:20:37.341] Using settings from "/mnt/HD_a2/.transmission-daemon" (daemon.c:488)
[14:20:37.341] Saved "/mnt/HD/HD_a2/.transmission-daemon/settings.json" (bencode.c:1721)
[14:20:37.341] Mashiny.skazki.vypusk.2..2012.O.DVDRip No data found! Ensure your drives are connected or use "Set Location". To re-download, remove the torrent and re-add it. (torrent.c:487)
[14:20:37.341] Loaded 1 torrents (session.c:1937)
[14:20:37.341] Port Forwarding (NAT-PMP) initnatpmp succeeded (0) (natpmp.c:72)
[14:20:37.341] Port Forwarding (NAT-PMP) sendpublicaddressrequest succeeded (2) (natpmp.c:72)
[14:20:39.362] Port Forwarding (UPnP) Found Internet Gateway Device "http://192.168.0.1:4444/wipconn" (upnp.c:113)
[14:20:39.362] Port Forwarding (UPnP) Local Address is "192.168.0.100" (upnp.c:115)
[14:20:39.362] Port Forwarding (UPnP) Port forwarding through "http://192.168.0.1:4444/wipconn", service "urn:schemas-upnp-org:service:WANIPConnection:1". (local address: 192.168.0.100:51413) (upnp.c:221)
[14:20:39.362] Port Forwarding (UPnP) Port forwarding successful! (upnp.c:224)
[14:20:39.362] Port Forwarding Forwarded (port-forwarding.c:93)
[14:21:01.493] DHT Attempting bootstrap from dht.transmissionbt.com (tr-dht.c:247)
[14:22:20.964] Mashiny.skazki.vypusk.2..2012.O.DVDRip Scrape error: Tracker gave HTTP response code 404 (Not Found) (announcer.c:1246)
[14:22:20.964] Mashiny.skazki.vypusk.2..2012.O.DVDRip Retrying scrape in 345 seconds. (announcer.c:1255)
[14:27:25.770] Mashiny.skazki.vypusk.2..2012.O.DVDRip Removing torrent (torrent.c:1813)
[14:27:25.770] Mashiny.skazki.vypusk.2..2012.O.DVDRip Pausing (torrent.c:1763)
[14:27:30.800] Saved "/mnt/HD_a2/.transmission-daemon/torrents/Mashiny.skazki.vypusk.2..2012.O.DVDRip.0d60a5c5df005a53.torrent" (bencode.c:1721)
[14:27:30.800] Mashiny.skazki.vypusk.2..2012.O.DVDRip Queued for verification (verify.c:260)
[14:27:30.800] Mashiny.skazki.vypusk.2..2012.O.DVDRip Verifying torrent (verify.c:218)
[14:28:22.104] Mashiny.skazki.vypusk.2..2012.O.DVDRip Scrape error: Tracker gave HTTP response code 404 (Not Found) (announcer.c:1246)
[14:28:22.104] Mashiny.skazki.vypusk.2..2012.O.DVDRip Retrying scrape in 333 seconds. (announcer.c:1255)
[14:28:42.223] Mashiny.skazki.vypusk.2..2012.O.DVDRip Removing torrent (torrent.c:1813)
[14:28:42.223] Mashiny.skazki.vypusk.2..2012.O.DVDRip Pausing (torrent.c:1763)
[14:28:42.223] Saved "/mnt/HD_a2/.transmission-daemon/torrents/Mashiny.skazki.vypusk.2..2012.O.DVDRip.0d60a5c5df005a53.torrent" (bencode.c:1721)
[14:28:42.223] Mashiny.skazki.vypusk.2..2012.O.DVDRip Queued for verification (verify.c:260)
[14:28:42.223] Mashiny.skazki.vypusk.2..2012.O.DVDRip Verifying torrent (verify.c:218)
[14:28:42.223] Saved "/mnt/HD_a2/.transmission-daemon/torrents/САМАЯ КАЧАЮЩАЯ МУЗЫЧКА В АВТО ТВОЕ 2012.022cb2f4ec273e20.torrent" (bencode.c:1721)
[14:28:42.224] САМАЯ КАЧАЮЩАЯ МУЗЫЧКА В АВТО ТВОЕ 2012 Queued for verification (verify.c:260)
[14:28:42.224] САМАЯ КАЧАЮЩАЯ МУЗЫЧКА В АВТО ТВОЕ 2012 Verifying torrent (verify.c:218)
[14:28:45.241] САМАЯ КАЧАЮЩАЯ МУЗЫЧКА В АВТО ТВОЕ 2012 Starting IPv4 DHT announce (poor, 22 nodes) (tr-dht.c:574)
[14:28:51.277] Mashiny.skazki.vypusk.2..2012.O.DVDRip Scrape error: Tracker gave HTTP response code 404 (Not Found) (announcer.c:1246)
[14:28:51.277] Mashiny.skazki.vypusk.2..2012.O.DVDRip Retrying scrape in 318 seconds. (announcer.c:1255)
[14:28:51.277] САМАЯ КАЧАЮЩАЯ МУЗЫЧКА В АВТО ТВОЕ 2012 Scrape error: Tracker gave HTTP response code 404 (Not Found) (announcer.c:1246)
[14:28:51.277] САМАЯ КАЧАЮЩАЯ МУЗЫЧКА В АВТО ТВОЕ 2012 Retrying scrape in 358 seconds. (announcer.c:1255)
[14:28:54.294] Mashiny.skazki.vypusk.2..2012.O.DVDRip Starting IPv4 DHT announce (poor, 22 nodes) (tr-dht.c:574)
[14:32:36.622] Saved "/mnt/HD_a2/.transmission-daemon/resume/Mashiny.skazki.vypusk.2..2012.O.DVDRip.0d60a5c5df005a53.resume" (bencode.c:1721)
[14:32:36.622] Saved "/mnt/HD_a2/.transmission-daemon/resume/САМАЯ КАЧАЮЩАЯ МУЗЫЧКА В АВТО ТВОЕ 2012.022cb2f4ec273e20.resume" (bencode.c:1721)
[14:32:58.753] САМАЯ КАЧАЮЩАЯ МУЗЫЧКА В АВТО ТВОЕ 2012 IPv4 DHT announce done (tr-dht.c:542)
[14:33:19.888] Mashiny.skazki.vypusk.2..2012.O.DVDRip IPv4 DHT announce done (tr-dht.c:542)
[14:34:12.198] Mashiny.skazki.vypusk.2..2012.O.DVDRip Scrape error: Tracker gave HTTP response code 404 (Not Found) (announcer.c:1246)
[14:34:12.198] Mashiny.skazki.vypusk.2..2012.O.DVDRip Retrying scrape in 940 seconds. (announcer.c:1255)
[14:34:50.424] САМАЯ КАЧАЮЩАЯ МУЗЫЧКА В АВТО ТВОЕ 2012 Scrape error: Tracker gave HTTP response code 404 (Not Found) (announcer.c:1246)
[14:34:50.425] САМАЯ КАЧАЮЩАЯ МУЗЫЧКА В АВТО ТВОЕ 2012 Retrying scrape in 903 seconds. (announcer.c:1255)
СообщениеДобавлено: Сб июл 07, 2012 12:57
Подскажите пожалуйста, купил DNS-320, подключил, начала установку с диска все по инструкции, но он мне выдал IP 169.254.60.240, это же не правильно? Должен быть IP что то типа 192.168.0... также не могу его перепрошить, не нахожу где это можно сделать, в разделе Management----System managemen нет раздела Firmware Upgrade
Подключл его в роутеру D-link Dir -300 но он его не видет. Подскажите как его правильно настроить, или ткните ссылкой где все это есть.
Спасибо!
СообщениеДобавлено: Вс июл 22, 2012 20:40
axelltv писал(а):
http://www.inreto.de/dns323/fun-plug/0. ... -arm-1.txz
uClibc-0.9.33_git-arm
funpkg -i curl-7.21.4-arm-1.txz
funpkg -i uClibc-0.9.33_git-arm-1.txz
Везде где в названии файла arm -это не для DNS323
Для него нужно oabi
Transmissio под Fun_plug 7.0 - нет
Я поставил
1 этап fun_plug 7.0
2 этап:
curl-7.21.4-oarm-1.txz
libevent-2.0.16-oarm-0.txz
Transmission-2.52-oabi-1.txz
3 этап
остановил Transmission
подправил файл настроеек
В итоге скачивание идет. А вот отдача нет. Но я толком настроки не ковырял, возможно можно это поправить.
СообщениеДобавлено: Сб авг 25, 2012 21:41
16 страниц чтения и решение проблемы
Личные финансы под контролем. Эффективный бизнес в Таджикистане.
Как вести здоровый образ жизни на все 100%
Адреса и телефоны гостиниц Душанбе, а также список школ Душанбе
СообщениеДобавлено: Сб сен 22, 2012 02:33
Привет всем!
Такая ситуация: есть 2 диска 1 - 2Tb, 2 - 250Gb.
Есть смысл ставть Fun plug на 250, а хранилище устроить на 2Tb или все установить на 2Tb и оставить только его.
Как меняется производительность если Fun plug стоит на томже диске куда бует все писаться?
Спасибо!
СообщениеДобавлено: Чт ноя 01, 2012 20:33
Люди, сделал все по инструкции, перечитал весь форум, не могу найти решения! Transmission работает, вопросов нет, но не могу выполнить пункт №2 Отключаем доступный telnet(порт 23) и подключаем SSH(порт 22)!
При команде:
usermod /s /ffp/bin/sh root
Получаю ответ
usermod: no flags given
При команде:
/ # store-passwd.sh
Copying files to mtd1...
mount: mounting /dev/mtdblock0 on /sys/mtd1 failed: No such file or directory
cp: cannot create '/sys/mtd1/.': Path does not exist
umount: can't umount /sys/mtd1: No such file or directory
Copying files to mtd2...
mount: mounting /dev/mtdblock1 on /sys/mtd2 failed: No such file or directory
cp: cannot create '/sys/mtd2/.': Path does not exist
umount: can't umount /sys/mtd2: No such file or directory
Done.
При попытке запустить SSH:
sh /ffp/start/sshd.sh start
Получаю ответ:
Starting /ffp/sbin/sshd
/ffp/var/lib/sshd must be owned by root and not group or world-writable.
Руки прямые, но сам проблему решить не могу :(
СообщениеДобавлено: Пт ноя 02, 2012 21:15
Забыл добавить! У меня DNS-325!
Проблему с сохранением пароля вроде решил командой:
vi /ffp/sbin/store-passwd.sh
Далее нажал "Esc" и два раза "Z" (именно заглавную)
Но на большее пока не хватило. Опять тупик на
СообщениеДобавлено: Сб ноя 03, 2012 15:02
Судя по ошибкам, вы не заходите под root на nas. Наверное, какие-то проблемы при настройке ssh. Попробуйте просто удалить ffp и поставить его заново
СообщениеДобавлено: Вт ноя 27, 2012 16:02
Работал Transmission на DNS-323 около 2-х лет. Периодически я обновлял версию Transmission. И вот около двух недель назад случилось странное. прямо в процессе загрузки торрента в Transmission связь с Transmission прервалась. Я пользуюсь transmisson-remote-gui. На DNS-323 установлена прошивка версии 1.10.
И все после этого Transmission умер...
После нескольких неудачных попыток я решил "семь бед один reset"... Снес все что было установлено, все пакеты удалял через консоль. Заново произвел все процедуры, указанные на 1-й странице данной темы. В результате на завершающем этапе получаю следующее:
/mnt/HD_a2 # funpkg -i Transmission-2.73-1.tgz
Installing package Transmission-2.73-1 ...
/mnt/HD_a2 # chmod a+x /ffp/start/transmission.sh
/mnt/HD_a2 # sh /ffp/start/transmission.sh start
Starting transmission-daemon
/mnt/HD_a2 # sh /ffp/start/transmission.sh stop
Stopping transmission-daemon
killall: transmission-daemon: no process killed
/mnt/HD_a2 #
Естественно после окончания всех необходимых манипуляций и команды на запуск демона Transmission, подключиться к нему через web не возможно. Пробовал устанавливать разные версии Transmission от 2.73-1 до 2.50-1 вот отсюда: http://kylek.is-a-geek.org:31337/files/ffp/0.5/ и 2.73-1 вот отсюда: http://forum.dsmg600.info/viewtopic.php?id=2719&p=1
В вопросах работы и настройки таких устройств разбираюсь на уровне пользователя. Поэтому прошу помощи людей разбирающихся в данном вопросе.
СообщениеДобавлено: Сб дек 15, 2012 21:46
что бы не ставить ffp, можно просто скомпилить трансмишн и собрать из него плагин.
СообщениеДобавлено: Вс дек 16, 2012 11:20
/mnt/HD_a2 #
всем ответившим спасибо за оперативность :D :D :D
Проблему решил сам. Правда пришлось переформатировать оба винчестера и списать/записать на них данные.
СообщениеДобавлено: Пн янв 14, 2013 22:31
простой способ настроить Time Machine.
http://andrew.pitt.ca/2011/09/05/time-m ... -easy-way/
настроил за пару минут.
работает с Mac OS X 10.6
по идее должно и н 10.7 и выше.
добавьте в шапку.
DNS-323(HW A1/FW 1.09/fun_plug/fancontrol/Transmission 2.04/2 x SAMSUNG HD154UI) + Apple Airport Extreme + Egreat EG-R1
СообщениеДобавлено: Вт янв 22, 2013 18:00
Всем привет. В Линуксе не силён. Закидывал в корень fun_plug и всё что надо, перегружал NAS, ffp не устанавливается и доступа через telnet нет. Делал из Windows. Пробовал из Ubuntu, fun_plug закидываю на рабочий стол, даю ему все права он открывается.Кидаю обратно на диск NASa там не открывается. Обратно на рабочий стол , теряются права. Немного сумбурно. Но как установить на NAS-315 медиасервер
Не обязательно на 315-й просто сам принцип. Перечитал форум, не нашел :(
http://forum.iconbit.ru/viewtopic.php?f ... 2&start=10
Читаю, начинаю понимать
:idea:
СообщениеДобавлено: Вт фев 12, 2013 10:22
Доброе время суток!
У меня возникла с НАСом следующая проблема
Нас потерялся в сетке, попытка перезагрузить его кнопкой (на передней панели) Не увенчалась успехом, не реагировал, выключаться не хотел. Отрубил отключением из розетки. На нем был собран RAID-1 из двух 1,5 тбайтных дисков. С дисками он отказывается работать, его не видно не в сетке не по вебморде, и подключиться телнетом так же не удается. Без дисков определяется без проблем, позволяет его настраивать и т.д. При попытке воткнуть в него диски по одному так же отказывается появляться и находиться.
Может быть кто сталкивался с данной проблемой или имеет понятие как ее разрешить? Буду премного благодарен.
СообщениеДобавлено: Пн июн 10, 2013 09:37
На DNS-320L всё это можно проделать?
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 0
