System Log
Date/Time Facility Severity Message
Jun 23 03:31:19 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=61.147.107.97 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=108 ID=256 PROTO=TCP SPT=6000 DPT=3306 WINDOW=16384 RES=0x00 SYN URGP=0
Jun 23 03:44:40 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=222.186.21.60 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=115 ID=256 PROTO=TCP SPT=31229 DPT=8080 WINDOW=16384 RES=0x00 SYN URGP=0
Jun 23 03:46:10 syslog info -- MARK --
Jun 23 03:51:11 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=37.190.39.64 DST=85.175.99.254 LEN=52 TOS=0x00 PREC=0x20 TTL=118 ID=26223 DF PROTO=TCP SPT=1626 DPT=12712 WINDOW=8192 RES=0x00 SYN URGP=0
Jun 23 04:00:44 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=60.169.78.88 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=116 ID=256 PROTO=TCP SPT=2002 DPT=8080 WINDOW=16384 RES=0x00 SYN URGP=0
Jun 23 04:14:50 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=136.169.122.32 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=32040 DF PROTO=TCP SPT=58513 DPT=6667 WINDOW=512 RES=0x00 SYN URGP=0
Jun 23 04:21:00 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=61.183.128.6 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=45205 PROTO=TCP SPT=57416 DPT=8123 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 23 04:31:10 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=61.183.128.6 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=15639 PROTO=TCP SPT=57416 DPT=8118 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 23 04:41:53 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=85.101.220.61 DST=85.175.99.254 LEN=60 TOS=0x08 PREC=0x20 TTL=51 ID=31394 DF PROTO=TCP SPT=44431 DPT=23 WINDOW=5808 RES=0x00 SYN URGP=0
Jun 23 04:46:10 syslog info -- MARK --
Jun 23 04:50:18 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=219.132.156.72 DST=85.175.99.254 LEN=60 TOS=0x00 PREC=0x00 TTL=53 ID=38584 DF PROTO=TCP SPT=38306 DPT=23 WINDOW=5840 RES=0x00 SYN URGP=0
Jun 23 05:02:28 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=64.125.239.59 DST=85.175.99.254 LEN=40 TOS=0x08 PREC=0x40 TTL=233 ID=54321 PROTO=TCP SPT=38748 DPT=1337 WINDOW=65535 RES=0x00 SYN URGP=0
Jun 23 05:10:08 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=60.169.78.88 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=116 ID=256 PROTO=TCP SPT=2002 DPT=8080 WINDOW=16384 RES=0x00 SYN URGP=0
Jun 23 05:20:25 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=85.152.68.126 DST=85.175.99.254 LEN=60 TOS=0x08 PREC=0x20 TTL=50 ID=44840 DF PROTO=TCP SPT=60132 DPT=23 WINDOW=14600 RES=0x00 SYN URGP=0
Jun 23 05:31:01 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=198.20.69.98 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=116 ID=43283 PROTO=TCP SPT=1702 DPT=9051 WINDOW=45232 RES=0x00 SYN URGP=0
Jun 23 05:42:06 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=85.105.43.241 DST=85.175.99.254 LEN=60 TOS=0x08 PREC=0x20 TTL=50 ID=27607 DF PROTO=TCP SPT=54860 DPT=23 WINDOW=5808 RES=0x00 SYN URGP=0
Jun 23 05:46:10 syslog info -- MARK --
Jun 23 05:50:53 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=61.176.223.77 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=110 ID=256 PROTO=TCP SPT=6000 DPT=9200 WINDOW=16384 RES=0x00 SYN URGP=0
Jun 23 05:59:58 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=180.118.254.118 DST=85.175.99.254 LEN=60 TOS=0x00 PREC=0x00 TTL=53 ID=34057 DF PROTO=TCP SPT=4453 DPT=23 WINDOW=5840 RES=0x00 SYN URGP=0
Jun 23 06:11:48 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=110.153.0.74 DST=85.175.99.254 LEN=60 TOS=0x00 PREC=0x00 TTL=54 ID=9487 DF PROTO=TCP SPT=1804 DPT=23 WINDOW=5840 RES=0x00 SYN URGP=0
Jun 23 06:24:43 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=61.160.224.128 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=54321 PROTO=TCP SPT=37899 DPT=21 WINDOW=65535 RES=0x00 SYN URGP=0
Jun 23 06:35:26 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=31.131.251.132 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=559 PROTO=TCP SPT=44549 DPT=23 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 23 06:41:02 daemon info pppd[647]: No response to 5 echo-requests
Jun 23 06:41:02 daemon notice pppd[647]: Serial link appears to be disconnected.
Jun 23 06:41:02 daemon info pppd[647]: Connect time 1013.6 minutes.
Jun 23 06:41:02 daemon info pppd[647]: Sent 41633386 bytes, received 702168215 bytes.
Jun 23 06:41:02 daemon warn pppd[647]: Couldn't increase MRU to 1500
Jun 23 06:41:08 daemon crit pppd[647]: Connection terminated....
Jun 23 06:41:08 daemon notice pppd[647]: Modem hangup
Jun 23 06:41:11 daemon info pppd[647]: Sent PADT
Jun 23 06:41:29 daemon info pppd[647]: PPP session is 12264
Jun 23 06:41:29 daemon info pppd[647]: Using interface ppp0_0_35_1
Jun 23 06:41:29 daemon crit pppd[647]: Connect: ppp_0_0_35_1 <--> nas_0_0_35
Jun 23 06:41:29 daemon warn pppd[647]: Couldn't increase MRU to 1500
Jun 23 06:41:38 daemon notice pppd[647]: PAP authentication succeeded
Jun 23 06:41:38 daemon notice pppd[647]: peer from calling number 00:90:1A:A4:DE:0D authorized
Jun 23 06:41:39 daemon notice pppd[647]: local IP address 85.175.99.254
Jun 23 06:41:39 daemon notice pppd[647]: remote IP address 85.175.1.63
Jun 23 06:41:39 daemon notice pppd[647]: primary DNS address 85.175.46.122
Jun 23 06:41:39 daemon notice pppd[647]: secondary DNS address 85.175.46.130
Jun 23 06:41:39 user debug syslog: kill -9 2353
Jun 23 06:41:39 user debug syslog: echo > /var/hosts
Jun 23 06:41:39 user debug syslog: cp /proc/var/fyi/wan/ppp_0_0_35_1/dns /var/fyi/sys/dns
Jun 23 06:41:39 user debug syslog: cp /proc/var/fyi/wan/ppp_0_0_35_1/gateway /var/fyi/sys/gateway
Jun 23 06:41:39 user debug syslog: route add default gw 85.175.1.63 2>/dev/null
Jun 23 06:41:39 user debug syslog: iptables -A FORWARD -o ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jun 23 06:41:39 user debug syslog: iptables -A FORWARD -i ppp_0_0_35_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jun 23 06:41:39 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_35_1 -s 192.168.0.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Jun 23 06:41:39 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_35_1 -s 192.168.0.0/255.255.255.0 -j MASQUERADE
Jun 23 06:41:40 user debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_35_1 -p tcp --dport 30005
Jun 23 06:41:40 user debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_35_1 -p tcp --dport 30005
Jun 23 06:41:40 user debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_35_1 -p udp -s 192.168.0.1/24 --dport 30006
Jun 23 06:41:40 user debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_35_1 -p udp -s 192.168.0.1/24 --dport 30006
Jun 23 06:41:40 user debug syslog: echo 4096 > /proc/sys/net/ipv4/ipfrag_high_thresh
Jun 23 06:41:40 user debug syslog: echo 1024 > /proc/sys/net/ipv4/ipfrag_low_thresh
Jun 23 06:41:40 user debug syslog: echo 5 > /proc/sys/net/ipv4/ipfrag_time
Jun 23 06:41:59 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=60.169.78.88 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=116 ID=256 PROTO=TCP SPT=2002 DPT=8080 WINDOW=16384 RES=0x00 SYN URGP=0
Jun 23 06:45:12 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=43.255.188.135 DST=85.175.99.254 LEN=40 TOS=0x08 PREC=0x20 TTL=236 ID=54321 PROTO=TCP SPT=58441 DPT=22 WINDOW=65535 RES=0x00 SYN URGP=0
Jun 23 06:46:09 syslog info -- MARK --
Jun 23 06:48:20 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=64.126.37.163 DST=85.175.99.254 LEN=60 TOS=0x08 PREC=0x20 TTL=48 ID=37579 DF PROTO=TCP SPT=54180 DPT=23 WINDOW=5840 RES=0x00 SYN URGP=0
Jun 23 06:51:39 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=46.29.248.181 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=19147 PROTO=TCP SPT=45624 DPT=3128 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 23 06:54:51 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=71.6.135.131 DST=85.175.99.254 LEN=40 TOS=0x10 PREC=0x00 TTL=107 ID=47257 PROTO=TCP SPT=49760 DPT=1723 WINDOW=44669 RES=0x00 SYN URGP=0
Jun 23 06:58:34 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=61.160.224.129 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=54321 PROTO=TCP SPT=36086 DPT=1433 WINDOW=65535 RES=0x00 SYN URGP=0
Jun 23 07:04:59 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=60.169.78.88 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=116 ID=256 PROTO=TCP SPT=2002 DPT=8080 WINDOW=16384 RES=0x00 SYN URGP=0
Jun 23 07:13:19 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=60.172.246.67 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=109 ID=256 PROTO=TCP SPT=6000 DPT=1433 WINDOW=16384 RES=0x00 SYN URGP=0
Jun 23 07:28:07 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=60.169.78.88 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=116 ID=256 PROTO=TCP SPT=2002 DPT=8080 WINDOW=16384 RES=0x00 SYN URGP=0
Jun 23 07:34:08 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=85.151.143.179 DST=85.175.99.254 LEN=60 TOS=0x00 PREC=0x00 TTL=55 ID=58492 DF PROTO=TCP SPT=54154 DPT=23 WINDOW=14600 RES=0x00 SYN URGP=0
Jun 23 07:45:03 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=200.32.203.174 DST=85.175.99.254 LEN=60 TOS=0x00 PREC=0x00 TTL=49 ID=41519 DF PROTO=TCP SPT=59750 DPT=23 WINDOW=4380 RES=0x00 SYN URGP=0
Jun 23 07:46:09 syslog info -- MARK --
Jun 23 07:53:37 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=61.160.224.128 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=54321 PROTO=TCP SPT=36734 DPT=22 WINDOW=65535 RES=0x00 SYN URGP=0
Jun 23 08:05:23 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=176.118.49.237 DST=85.175.99.254 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=7903 DF PROTO=TCP SPT=52468 DPT=12712 WINDOW=8192 RES=0x00 SYN URGP=0
Jun 23 08:13:42 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=60.169.78.88 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=116 ID=256 PROTO=TCP SPT=2002 DPT=8080 WINDOW=16384 RES=0x00 SYN URGP=0
Jun 23 08:24:17 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=61.160.223.118 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=108 ID=256 PROTO=TCP SPT=6000 DPT=1433 WINDOW=16384 RES=0x00 SYN URGP=0
Jun 23 08:36:41 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=60.169.78.88 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=116 ID=256 PROTO=TCP SPT=2002 DPT=8080 WINDOW=16384 RES=0x00 SYN URGP=0
Jun 23 08:42:51 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=61.240.144.66 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=35898 PROTO=TCP SPT=60000 DPT=22 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 23 08:46:09 syslog info -- MARK --
Jun 23 08:54:15 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=61.183.128.6 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=53264 PROTO=TCP SPT=53547 DPT=8123 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 23 09:14:12 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=218.77.79.43 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=243 ID=54321 PROTO=TCP SPT=53272 DPT=80 WINDOW=65535 RES=0x00 SYN URGP=0
Jun 23 09:19:14 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=61.240.144.67 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=62882 PROTO=TCP SPT=60000 DPT=5000 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 23 09:22:49 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=60.169.78.88 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=116 ID=256 PROTO=TCP SPT=2002 DPT=8080 WINDOW=16384 RES=0x00 SYN URGP=0
Jun 23 09:34:13 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=61.160.224.130 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=54321 PROTO=TCP SPT=56329 DPT=8090 WINDOW=65535 RES=0x00 SYN URGP=0
Jun 23 09:42:04 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=222.186.50.120 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=115 ID=256 PROTO=TCP SPT=22014 DPT=1433 WINDOW=16384 RES=0x00 SYN URGP=0
Jun 23 09:46:09 syslog info -- MARK --
Jun 23 09:52:41 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=176.98.70.243 DST=85.175.99.254 LEN=48 TOS=0x00 PREC=0x00 TTL=119 ID=16706 DF PROTO=TCP SPT=51044 DPT=56533 WINDOW=8192 RES=0x00 SYN URGP=0
Jun 23 10:08:30 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=60.169.78.88 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=116 ID=256 PROTO=TCP SPT=2002 DPT=8080 WINDOW=16384 RES=0x00 SYN URGP=0
Jun 23 10:12:04 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=46.29.248.181 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=246 ID=53779 PROTO=TCP SPT=57844 DPT=8080 WINDOW=1024 RES=0x00 SYN URGP=0
Jun 23 10:23:32 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=188.138.9.50 DST=85.175.99.254 LEN=40 TOS=0x10 PREC=0x00 TTL=118 ID=54383 PROTO=TCP SPT=34680 DPT=4848 WINDOW=6726 RES=0x00 SYN URGP=0
Jun 23 10:39:21 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=91.76.121.161 DST=85.175.99.254 LEN=52 TOS=0x00 PREC=0x20 TTL=118 ID=25240 DF PROTO=TCP SPT=4766 DPT=12712 WINDOW=8192 RES=0x00 SYN URGP=0
Jun 23 10:46:10 syslog info -- MARK --
Jun 23 10:48:53 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=188.162.132.65 DST=85.175.99.254 LEN=52 TOS=0x08 PREC=0x20 TTL=119 ID=17412 DF PROTO=TCP SPT=28786 DPT=39908 WINDOW=8192 RES=0x00 SYN URGP=0
Jun 23 10:52:59 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=85.97.224.6 DST=85.175.99.254 LEN=60 TOS=0x08 PREC=0x20 TTL=51 ID=38900 DF PROTO=TCP SPT=60149 DPT=23 WINDOW=5808 RES=0x00 SYN URGP=0
Jun 23 11:06:01 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=176.98.70.243 DST=85.175.99.254 LEN=48 TOS=0x00 PREC=0x00 TTL=119 ID=9841 DF PROTO=TCP SPT=59528 DPT=56533 WINDOW=8192 RES=0x00 SYN URGP=0
Jun 23 11:14:36 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=85.197.53.71 DST=85.175.99.254 LEN=60 TOS=0x00 PREC=0x00 TTL=52 ID=53064 DF PROTO=TCP SPT=57225 DPT=23 WINDOW=14600 RES=0x00 SYN URGP=0
Jun 23 11:22:10 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=61.160.194.226 DST=85.175.99.254 LEN=40 TOS=0x00 PREC=0x00 TTL=108 ID=256 PROTO=TCP SPT=6000 DPT=3306 WINDOW=16384 RES=0x00 SYN URGP=0
Jun 23 11:33:41 user alert kernel: Intrusion -> IN=ppp_0_0_35_1 OUT= MAC= SRC=188.162.132.65 DST=85.175.99.254 LEN=52 TOS=0x08 PREC=0x20 TTL=119 ID=26461 DF PROTO=TCP SPT=37922 DPT=39908 WINDOW=8192 RES=0x00 SYN URGP=0
Jun 23 11:39:02 user debug syslog: kill -9 2603
Jun 23 11:39:02 user debug syslog: echo > /var/hosts
Jun 23 11:39:02 user debug syslog: kill -9 2741
Jun 23 11:39:05 daemon debug user: wlctl -i wl0 authe_sta_list > /var/wl_authe
Jun 23 11:39:05 daemon debug user: wlctl -i wl0 assoclist > /var/wl_assoc
Jun 23 11:39:05 daemon debug user: wlctl -i wl0 autho_sta_list > /var/wl_autho
